Old 07-19-2007, 01:38 PM   #1
Miami , Florida
Smile Argosy Exterior Cleaning of Mildew
Hi all:
My husband and I have purchased a 1978 27' Argosy that is in need of some TLC. I want to get started cleaning the exterior which apwears to ahve mildew and/or mold on it.
Any cleaning combos anyone has used that they would want to recommend or think I should stya away from? I was going to strat with some bleach and elbow grease. Could we pressure clean safely?
Thanks for your time and thoughts.
teelamaria is offline   Reply With Quote
Old 07-19-2007, 01:44 PM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
I'd probably start with dish detergent about like what you'd make up in a bucket for washing a car. My '74 Argosy has tended to get dark buildup if I've kept it in the shade -- it comes off fairly well. Don't pressure wash these old Airstreams -- you'll find enough leaks without pressure washing and you will cause more leaks in the old seals and caulking if you go that route.
5 meter Langford Nahanni
Old 07-19-2007, 01:45 PM   #3
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Argosy's have steel end caps. The paint tends to fail on these after a while...its this what you are seeing?
I would NOT suggest power washing as it will break off any loose paint - and you will find leaks you never had before. Also, no bleach should be used on aluminum...bad combo!
Have you tried just water & a mild detergent?
Shari
Old 07-19-2007, 01:54 PM   #4
The Painted Pig
Moonshot's Avatar
1979 Argosy Minuet 7.3 Metre
Hailey , Idaho
Images: 14
If you use a pressure washer go with one that can heat the water. I've heard them called "steam jennies" and I used to own one made by Hotsy. The amount of psi from the washer will determine how closely you can get to the surface without risk of knocking off paint chips. Be extra careful around the seams and rivets by increasing the distance between the wand and the skin of the Argosy.
Also, the end caps are a different material (steel) from the rest of the Argosy as you may know and the paint there tends to deteriorate faster. So be extra careful there.
After you finish and get a good coat of wax on that Argosy it will really look spiffy!
Scott
Moonshot is offline   Reply With Quote
Old 07-19-2007, 01:57 PM   #5
The Painted Pig
Moonshot's Avatar
Hailey , Idaho
Images: 14
Well, a couple of good comments came in before I clicked the post button.
I had no problem using a pressure washer on mine, but your mileage may vary and if you don't mind the extra elbow grease it may be best to avoid it based on what Bob and Shari mention.
Scott
Old 07-19-2007, 03:01 PM   #6
newbie
audiobox's Avatar
Fort Wayne , Indiana
Non-toxic mildew solution
If it is truly a mildew problem, which usually shows up inside rather than outside, a strong solution of teatree oil will kill and remove the mold. At least on the inside, it keeps mold from coming back for quite some time.
http://www.septaudio.com
audiobox is offline   Reply With Quote
Old 07-19-2007, 03:42 PM   #7
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
Hello.. Used TSP and a nail brush to scrub ours... check out pics on thread titled Costalotta start to finish... it was really bad
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Argosy Motorhome Manual & Brochures WANTED Rik Argosy Motorhomes 28 05-22-2017 11:45 AM
Stripping an Argosy CHRIS CANNON Cleaning, Stripping & Polishing 8 05-11-2017 04:42 PM
confused Argosy newbie Dave Cole All Argosy Trailers 23 09-15-2006 09:36 PM
New Argosy owner! barbwire All Argosy Trailers 33 04-15-2003 07:14 PM
1985 Argosy MH???? ViewRVs Airstream Motorhome Forums 8 03-21-2002 07:39 PM
