Old 08-08-2007, 09:24 PM   #1
blondie3265's Avatar
1975 Argosy 22 Rear Door
1962 19' Globetrotter
Vian , Oklahoma
Question Argosy Curtains
Well its time to start working on the new curtains. Me and my mom will be making them. My question is does anyone have photo's of the original pleated drapes? We were hoping to get an idea on the way they're made. Mine has the tabs with elastic, i need to know where they put the tab in. How the front window is divided up, Is it 2 panels or 4. And anything that would help. Thanks
blondie3265 is offline   Reply With Quote
Old 08-08-2007, 09:57 PM   #2
loudruff's Avatar
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
Minuet
My Argosy Minuet 6.7 has 4 panels on the front windows. Unfortunately I don't have pictures that show the originals. The ones there now are the second set of home made ones. I am sure that someone on this forums has "real" originals that they can tell you about. I am about to do the same project for the Minuet. I want to do mine with room darkening linings too. I am still looking for a great fabric that will coordinate with the gauchos which are already redone.
Good luck with your project.
Lou
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
loudruff is offline   Reply With Quote
Old 08-09-2007, 02:38 AM   #3
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
The tabs go between the pleats, it has been 2 years since I put the new ones in our other Argosy....My MOM made ours and they have the room darkening linings.. will post some pics tomorrow...
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 08-09-2007, 01:24 PM   #4
RBolton's Avatar
Belington , West Virginia
My 1975 Argosy 26 has 4 panels. Ten pleats each. The elastic tabs are attached right beside each pleat. There is a velcro tab at the top and bottom of each panel to hold it tight to the adjacent panel. I will try to post pics.
Roger
ID:	42874   Click image for larger version
ID:	42876   Click image for larger version
RBolton is offline   Reply With Quote
Old 08-09-2007, 03:49 PM   #5
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
This is my 24ft Argosy, both front and the curb side in the rear. Everything is two panels except the front which is four panels. Two smaller panels at each side and then two larger panels in the middle.
ID:	42886   Click image for larger version
ID:	42888   Click image for larger version
juel is offline   Reply With Quote
Old 08-10-2007, 11:17 PM   #6
Vian , Oklahoma
Thanks so much for the info!! This will help so much. We had nothing to go by. Well one good thing we do have the old cushions to use as a pattern. So that one will be easy. Going with a new foam and material. Sometime this project can get deeper than we wanted. Thanks again!!!!!
Old 08-11-2007, 12:20 PM   #7
loudruff's Avatar
1989 29' Excella
snaps?
Are there still snaps in the outside corners of the curtains to hold them against the curved walls?? If so, how much fabric is left from the corner to the snap?
As for the foam for the gauchos, if you sign up for the JoAnn Fabric mailings, you get a flyer each month for their sales. In that flyer is usually a coupon for 40% off of an item. I went each month for several months getting a discount on each piece of foam until I had enough...4 pieces. That made a huge savings in the costs. I did the same thing with the fabric. Do you hve JoAnn Fabric stores there?
Lou
Larry and Lou
Air #2695
TAC- OH 2
Old 08-13-2007, 02:19 PM   #8
RBolton's Avatar
Lou. The snaps are at the top and bottom. Here are pics of one of the bottom snaps. They are all the same. At least on mine. Roger
ID:	43135   Click image for larger version
Old 08-13-2007, 04:39 PM   #9
loudruff's Avatar
1989 29' Excella
thanks
Thanks for the pictures. I knew that they had those, however I thought there was much more material between the snap and the edge of the curtains. I am thinking that I will add more width on the curtains so that they will be full enough to cover a little better, even though the velcro is there.
Thanks again!
Larry and Lou
Air #2695
TAC- OH 2
Old 08-13-2007, 04:56 PM   #10
RBolton's Avatar
On the origianl curtains the face of the curtain rolls under and snaps to the wall. So more material between the snap and the edge of the curtain would mean that you had more material doulbled over. That is why, I think, that the snap is so close to the edge.
Old 08-14-2007, 10:04 PM   #11
Vian , Oklahoma
Lou, We don't have a JoAnn's but we have a Hancock! And we had the same ideas on the coupon. We both get the flyers so that's 2 coupons! Thanks Pam
Old 08-23-2007, 12:34 PM   #12
LookingThroughALens
aturner4u's Avatar
1976 Argosy 24
Marietta , Georgia
Images: 20
Thanks for posting these photos. I was wondering what the snaps on the wall were for. Ours no longer has drapes it came with blinds.
In nature, light creates the color. In the picture, color creates the light. --- Hans Hofmann
aturner4u is offline   Reply With Quote
Old 08-29-2007, 09:35 PM   #13
Vian , Oklahoma
Well we bought the curtain material last Saturday. Hancocks was having a big sale so we did good. Now its time to get started making drapes! Thanks for the info on the snaps.
Old 08-29-2007, 10:41 PM   #14
loudruff's Avatar
1989 29' Excella
how much?
How many yards of fabric did you buy? did you also buy the room darkening fabric? Lining fabric? Keep me posted and pass along the tips! I will be doing this too! Good luck with the project. Make sure you post some photos as you go! Thanks in advance.
Lou
Larry and Lou
Air #2695
TAC- OH 2
Argosy Motorhome Manual & Brochures WANTED Rik Argosy Motorhomes 28 05-22-2017 11:45 AM
Stripping an Argosy CHRIS CANNON Cleaning, Stripping & Polishing 8 05-11-2017 04:42 PM
confused Argosy newbie Dave Cole All Argosy Trailers 23 09-15-2006 09:36 PM
New Argosy owner! barbwire All Argosy Trailers 33 04-15-2003 07:14 PM
A new Argosy owner GOTPIKE All Argosy Trailers 28 11-29-2002 11:09 AM
