Finally got around to finishing the brake renewal and bearing lube.
The last bearing that I looked, had cracked pitted outer race. When I removed the race discovered the ugly truth. Some fool, either PO, or mechanic installed a Timken cage into the existing NGK outer race.
So "they" did a quick bearing change. Darn fools and their tools should be separated, permanently.
Now I'll have to consider going back, pulling all the races, to look for mismatch. OTOH since I got the Argosy last year, and the PO made several trips to the Outer Banks, (the old grease verified it), maybe go with, iffen it aint broke don't fix it.
Ideas???
