Old 01-22-2006, 04:44 PM   #1
1978 Argosy Minuet 6.0 Metre
1977 Argosy Minuet 6.0 Metre
Tucson , Arizona
Argosy 6M wheel well damage
Hi this is my first attempt at posting a new thread with pictures so here goes. I have a 77 & 78 6 M Argosy. They both have wheel well damage under the kitchen sink. What is the cause and what is the fix.
ID:	17846   Click image for larger version
cape_bob is offline   Reply With Quote
Old 01-22-2006, 04:57 PM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Li key the damage is one or both things; The lightweight design using a thin experimental plastic, or a blow out in the past life of the trailer that caused the damage. Of course these are just educated guesses on my part...
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 01-22-2006, 05:03 PM   #3
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
I agree. Also - dents from the inside-out can be caused by storing heavy stuff here during transit. we had some of this with our minuet.
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 01-22-2006, 05:14 PM   #4
Tucson , Arizona
Thanks for the input. Let me better explain. On both Argosys the thin white sheet metal is is cutting into the wheel well. Like the wheel well is either coming up or the counter top is going down. I have not taken the wheels off to see if there is damage from a blown tire.
Old 01-22-2006, 06:57 PM   #5
Just a member
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Ok,
Now I think understand, the bulkhead (wall) is cutting into the black plastic of the wheel well, right?
Brett G
Old 01-22-2006, 08:20 PM   #6
Tucson , Arizona
That is correct. The first picture is from my 77 and the second from the 78.
Old 01-22-2006, 10:41 PM   #7
loudruff's Avatar
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
Hi!
We don't have the same size Minuet, so our layout is different. But we found the aluminum floor in our Minuet had a few places where the supports for the counter tops wore through the top layer of aluminum which allowed them to drop as much as a half inch, causing some wrinkles in the wall panels. This might cause the metal cabinet structure to contact your wheel well. You might pull back the carpet. Our fix was to jack up the counter to original height and put a piece of stainless steel over the hole in the floor and attach with rivets.
Good luck!
Larry
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
loudruff is offline   Reply With Quote
Old 01-23-2006, 06:24 AM   #8
Tucson , Arizona
Larry
Thanks for the input. This might be the problem as the calking on the back edge of counter top on the 78 definately misplaced and the counter top is cracked. I'll pull the carpet out and check. I'm planning on putting a laminate wood floor in the trailer anyway.
Argosy Motorhome Manual & Brochures WANTED Rik Argosy Motorhomes 28 05-22-2017 11:45 AM
Stripping an Argosy CHRIS CANNON Cleaning, Stripping & Polishing 8 05-11-2017 04:42 PM
confused Argosy newbie Dave Cole All Argosy Trailers 23 09-15-2006 09:36 PM
A new Argosy owner GOTPIKE All Argosy Trailers 28 11-29-2002 11:09 AM
Wheel Bearing?? - - or - - Brakes?? overlander64 Axles 8 11-24-2002 12:13 AM
