Old 09-03-2006, 09:00 PM   #1
bellevue , Washington
Argosy 20 - Water Tank - '73
I recently purchased a nice '73 in the seattle area. $5200. All is working. Just got done pulling out all the copper and replaced with flexpex 1/2". I just found that the filler spout on the potable has cracks around it and the tank inside is it kind of rank.
How invoved is the removal of that tank? It looks like I will need to disemble the gaucho most of the way. I was going to replacement tanks from all-rite.
http://www.all-rite.com/customtanks.html
Has anyone ever come up with a good plastic weld that would help me seal the cracks?
Thanks, Peter
coodoo99 is offline   Reply With Quote
Old 09-03-2006, 09:16 PM   #2
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
You can weld the tank, but it is likely better to replace it simply because the cracks indicate the plastic is probably fatigued and it will crack again. I used Allrite as supplier for a black water tank and they built it to specification - nice tank.
1966 Airstream Caravel
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Old 09-05-2006, 04:25 PM   #3
highmark's Avatar
1977 24' Argosy 24
Swan Lake , Montana
I have a 1977 Argosy with a front dinette. I had to remove the complete unit to get the fresh water tank out. I just took a screwdriver and drill to remove the screws and pop rivets. There were six rivets that I had to take a hacksaw to as I couldn't get the drill to the job. It only took about 2 hours to remove the entire unit and it went back together quickly and looks like new! Good luck! Highmark
highmark is offline   Reply With Quote
Old 09-10-2006, 11:01 PM   #4
1976 26' Argosy 26
St. Albert , Alberta
Water tank removal
I just removed my gaucho today and can give you three pics for reference and one tip: the front of the gaucho is held to the floor with a bracket (see photo). The PO had put smooth-edge for the carpet right over the bracket screws. Watch for that.
Cheers!
Name:	Under front couch bracket (day two, reduced).jpg
ID:	25813   Click image for larger version
Name:	Water pump in situ (day two, reduced).jpg
Name:	Water tank location (day two, reduced).jpg
Chopper is offline   Reply With Quote
Help... I Need To Install A Gray Water Tank???? kangol Waste Systems, Tanks & Totes 0 04-19-2004 08:10 PM
Low water pressure in Excella murf Fresh Water Systems 7 09-04-2002 07:12 AM
Water tank drain Craig 1978- 1979 Excella 500 8 08-24-2002 09:02 AM
Regarding original water tank clean out - thank you! 60stradewind Fresh Water Systems 0 08-22-2002 12:00 AM
Water Hammer melprice Water Heaters, Filters & Pumps 10 07-30-2002 01:10 PM
