Old 12-13-2005, 06:04 AM   #1
mtnman's Avatar
Collettsville , North Carolina
Antenna holes
I removed the TV and radio antennas off my 1979 Argosy, which left 2 holes in my coach. The antenna hole is on top and is about 1 ˝” surrounded by several rivet holes. The radio hole is on the side and is about 1” with 3 small bolt holes around it. Being new to all this I was not sure what kind of antenna or antennas I would need in the future. It will be at least another month or so before I will have the coach to a useable condition. I would like to use it awhile before I decide what I want as far as TV/radio stuff. I don’t even know what is available or offered on a new TT? I would like to use the coach for about 6-8 months before I decide what I want. My question is: what would be a temporary fix to these holes? I presently have the holes covered with duct tape to keep the rain/weather out. Will the duct tape be OK for a while? One friend suggested spraying that foam stuff into the holes to fill the void and then use Sikaflex caulk to seal it? He said this would be easy to undo if I later wanted to go back through these openings. Do I have any other options?
mtnman
mtnman is offline   Reply With Quote
Old 12-13-2005, 06:30 AM   #2
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
High class duct tape
The solid aluminum duct tape works well for atleast several years. I have used it when I want to seal a leak or on the road for temp. repairs. Leaves no residual like the cloth stuff and does not deteriorate in the sun.
Old 12-13-2005, 06:31 AM   #3
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
The proper fix would be to seal that spot with a small square of aluminum by riveting it to the main top skin. Use Vulkum or Sikaflex to seal it from water leaks.
Just my thought..Remember, time has a way of getting away from you...
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 12-13-2005, 06:31 AM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
mtnman,
I would use the Aluminum tape, not regular duct tape. The regular tape deteriorates in sunlight and is a mess to clean off. I use the Aluminum tape for patching a variety of things on a temporary basis. It does not look too bad on an AS either. I would not go the foam route that stuff is a pain to get off.
Aaron
WBCCI #XXXX AIR #2495
Old 12-13-2005, 08:27 AM   #5
mtnman's Avatar
OK, I think I have some of the metal tape, I will change that out. It will still look a little odd on my white argosy thought, but thats fine. Thanks for your help folks.
mtnman
Old 12-14-2005, 07:08 AM   #6
mtnman's Avatar
ciao
53FC
Yes, I actually had the flashing in my hand with the rivet tool and thought, "I may want these holes for a radio or TV later". Thats when I turn to you fellows for a good temp fix.
mtnman
Old 12-16-2005, 04:00 PM   #7
mtnman's Avatar
Drain Valve
Looks like I am going to have to replace the Black water drain valve. It appears to be stuck closed. I think I may hate this job! I been reading some post here. Do the black rubber 4 inch and 3 inch slip on couplins with a clamp on each end work well on drain line?
mtnman
Old 12-17-2005, 04:25 AM   #8
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Looks like I found this too late, check out what I did tho. Had to make a new piece...
http://www.balrgn.com/Airstream/Leak/leak.htm
There are 8 screws that hold the valve together, you may be able to get to them.
I removed the entire header piping to the dump valves. Wound up replacing the interior parts of the valve. But I saved the valve body. Did not have to cut it out and replace. I'd only go with a flex as a LAST resort. Hate to have that stuff leaking out....
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 12-17-2005, 06:04 AM   #9
mtnman's Avatar
balrgn,
Did you use screws or pop-rivets to install the antenna cover?
mtnman
Old 12-17-2005, 06:16 AM   #10
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Originally Posted by mtnman
balrgn,
mtnman
Used 1/8" Pop rivets. Same holes that were there, transfered them into a piece of 1/8" aluminum we cut to the same shape. Filled the void with spray foam. It holds the handle on the inside steady and in the same position.
www.balrgn.com
Old 12-17-2005, 07:31 AM   #11
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
You gotta love those PO's who take off the antennas and don't patch the holes.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 12-17-2005, 08:20 AM   #12
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Wasn't the PO's fault, now way to tell that. The original cast aluminum piece turned into a sponge like material. Must have been slightly different compound than the aluminum skin, causing a dis-similar material issue. I did not find that was the leak path until I bead blasted it and noticed how porous it was.
www.balrgn.com
Old 12-17-2005, 08:45 AM   #13
mtnman's Avatar
balrgn,
Do the side windows on the argosy just slide off after you open them or how do they come off?
mtnman
Old 12-17-2005, 09:21 AM   #14
CanoeStream's Avatar
St. Cloud , Minnesota
Re-read 53FlyingCloud's post!
If they have an Eiffel tower and Venetian canals in Vegas, you sure can get creative if you'd like. A former contributor to these forums had an interesting idea (see post 3): http://www.airforums.com/forum...dish-4048.html
5 meter Langford Nahanni
Motorized TV Antenna Crystaljean22 Mechanics Corner - Engines, Transmission & More... 8 07-16-2007 10:30 AM
Amplified Antenna Connection smily Airstream Motorhome Forums 10 09-03-2005 03:25 PM
fixing the antenna barbwire All Argosy Trailers 16 05-29-2005 01:30 PM
Antenna connection PatCrusse Electrical - Systems, Generators, Batteries & Solar 2 10-10-2002 03:15 PM
Where do you suppose they put the antenna jack -'73 safari ? Chuck 1969 - 1973 Safari 14 06-13-2002 11:34 AM
