Old 12-17-2005, 09:24 AM   #15
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
bob
i was going to post the same comment about the salad dish!
john
you call them ferrets, i call them weasels.
Old 12-17-2005, 09:31 AM   #16
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Originally Posted by mtnman
balrgn,
Do the side windows on the argosy just slide off after you open them or how do they come off?
mtnman
Hmm, If you mean to remove the 70's windows, there are brackets that help hold them open, in the bracket there is one screw on each side, you can remove the screw(s) and then this will allow the window to open further. Once you are about level the window will come away from the hinge type assembly.
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 12-17-2005, 09:51 AM   #17
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Another question about the window. On my 75 Trade Wind several of the windows do not loke to stay open. If you mess with the arms they will stay open, but will close if a light wind comes up. What should I be looking for to resolve this?
Richard
Old 12-17-2005, 10:12 AM   #18
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Mine are a pain too. I usually open them from the outside to ensure the pin is seated properly. I did have better results after I silicone sprayed them last fall. Facing the window, you need to move the handle to the outside of the window frame to seat the pins.
www.balrgn.com
Old 12-17-2005, 05:27 PM   #19
mtnman's Avatar
Collettsville , North Carolina
balrgn,
I was looking at your web site, you have some great looking pics? We wanted to know if the bravura toilet will fit in our 24 ft argosy? I read where the bravura toilets were too long and the lid would not stay open?
mtnman
mtnman is offline   Reply With Quote
Old 12-17-2005, 05:29 PM   #20
mtnman's Avatar
balrgn,
I was wondering what you painted your bath sink with too?
mtnman
Old 12-17-2005, 06:02 PM   #21
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
balrgn,
mtnman
We used Por Products White Cote
http://www.por15.com/product.asp?productid=233
Awesome stuff, hard as nails!
www.balrgn.com
Old 12-17-2005, 06:07 PM   #22
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
balrgn,
mtnman
We had a Brauva it fit fine in the Trade Wind, was too tall for us tho. It did not fit in the Argosy, Lid would not open with the storage compartment in the back.
www.balrgn.com
Old 12-17-2005, 06:09 PM   #23
Pschoerrn's Avatar
1971 29' Ambassador
Braunschweig , Germany
Thanks balrgn,
for posting Por 15... I found our stripper today! 24.00 euro per liter is not too cheap but if it helps...
Bjoern
Björn H. Adam
Wolfenbuettel, Germany
AirstreamForumsMember No. AIR 5535
Proud Owner of a 1971 Ambassador 29' called "Dave"
-A stranger is a friend you just haven´t met before!-
unknown irish
davetheairstream
Pschoerrn is offline   Reply With Quote
Old 12-17-2005, 06:57 PM   #24
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Hey how much to do a rear bath? Quart, Gallon? I got one that is going to need it one of these days
Aaron
WBCCI #XXXX AIR #2495
Old 12-17-2005, 07:18 PM   #25
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Aaron
I used just one gallon to do ALL the bath fixtures. Need a primer gun if you spray (1.6 nozzle) Extremely moisture sensitive. Humidity makes it dry FASTER. Have to hold above 65º for 24 hours. I dropped my Portable drill on it installing with a bit in it, no mark! the back.
www.balrgn.com
Old 05-04-2006, 05:12 PM   #26
Geezer
1991 25' Excella
Sapulpa , Oklahoma
The windows on my 76 are held on by a j-hook on the top of the window. To remove I loosened the sliding rods on the sides and lifted the window straight up until the j-hook slipped loose. Getting them back in was much harder. You will see that the J-hook fits in a grove just below the guttering. When replacing I had to get a neighbor to help by pushing up on the middle of the j-hook until it slipped in the slot. Be careful it is easy to pop the rivets if you put too much pressure on the window.
LRPorter is offline   Reply With Quote
Motorized TV Antenna Crystaljean22 Mechanics Corner - Engines, Transmission & More... 8 07-16-2007 10:30 AM
Amplified Antenna Connection smily Airstream Motorhome Forums 10 09-03-2005 03:25 PM
fixing the antenna barbwire All Argosy Trailers 16 05-29-2005 01:30 PM
Antenna connection PatCrusse Electrical - Systems, Generators, Batteries & Solar 2 10-10-2002 03:15 PM
Where do you suppose they put the antenna jack -'73 safari ? Chuck 1969 - 1973 Safari 14 06-13-2002 11:34 AM
