Old 07-31-2016, 04:13 PM   #1
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
Antenna Cover
I'm re-painting the Argosy and would like to get rid of the old antenna mount. I'm wary of taking it off before I know how I'm going to cover the holes.
Any thoughts?
DryFly is offline   Reply With Quote
Old 07-31-2016, 04:59 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Two suggestions. West Marine has water tight plugs is several sizes to plug holes on boats or you could cover with a piece of light aluminum cut to size, well caulked and riveted.
MICHAEL
AWCHIEF is online now   Reply With Quote
Old 08-05-2016, 03:34 PM   #3
irishmike
irishmike's Avatar
1975 Argosy 24
Issaquah , Washington
I too am going working on a similar project, 24' Argosy, 1975 and in Issaquah! We should share notes @DryFLy!
irishmike is offline   Reply With Quote
Old 08-06-2016, 10:27 AM   #4
DryFly's Avatar
1972 Argosy 20
Well that's cool. PM me if you like
Old 09-21-2016, 06:23 PM   #5
1976 Argosy 26
Charlotte , North Carolina
How do you remove the antenna bas? I turn the screws, and the screws just keep turning and turning...
LarkandLeigh is offline   Reply With Quote
Old 09-21-2016, 07:44 PM   #6
Argonaut20's Avatar
1978 Argosy Minuet 6.0 Metre
1966 17' Caravel
Las Cruces , New Mexico
Try pulling out on the base as you turn the screws. Turn one screw some, then move to the next screw and turn it some, then the next. You might be able to get a plastic blade started under the base to help move the base away from the wall as you work the screws.
1978 Argosy 6 Metre Minuet
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Rooftop Antenna Installation - Spring Mount Cellular Antenna Astw Electronics & Connectivity 4 08-04-2016 08:51 AM
Antenna Removal & Replacement with Cell/Wifi Antenna BoldAdventure Electronics & Connectivity 9 07-04-2016 07:27 PM
Pulling the Air TV Antenna Replace With A Satellite Antenna Chuhhuniban Electronics & Connectivity 9 03-23-2015 12:43 PM
Antenna Gear Set Cover davespann Audio, Video & TV 2 08-24-2003 09:25 AM
