Old 08-24-2008, 04:45 PM   #57
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
1/8 " rivets on the rub rail sounds right. If a 1/8" bit doesn't slide in, there is still part of the rivet there. Drill it out. Probably medium length for the rivet, too.
Sounds like a plan for the vent pipe covers.
Those little drain valves get corroded and hard to turn. Try a pair of pliers as a lever to get the handle to turn. If it is too stubborn, the valve can be removed by unscrewing it from the heater. Replacements can be found at a hardware store or an auto parts store (radiator drain valve).
1966 Airstream Caravel
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Old 08-24-2008, 06:05 PM   #58
Duff23's Avatar
1976 Argosy 26
Oxford , Connecticut
Thanks, I'll drill it.
Yep, but you have to wonder why the designers didn't use the same hole pattern.
I'll try that tomorrow.
Duff23 is offline   Reply With Quote
Old 08-25-2008, 07:45 PM   #59
Duff23's Avatar
1976 Argosy 26
Originally Posted by Inland RV Center, In View Post
The screen fuzzy seal has been used by Airstream, for almost 40 years.
Considering the job it does, it's a lot better than any rubber product or plastic product, and is cheap, especially since is lasts 20 years or more, and makes a positive seal against flying insects.
Airstream used a plastic seal in 1969. At best, it was a joke, but did some what of a job.
What would you suggest as an improvement?
I finally finished a window...the fuzzy seal is great. I officially rescind my previous comment about it being an outdated design.
I also replaced a few rivets and ran a bead of Parr Bond along the rub rail on the front of the trailer. I don't think one of my rivets is doing anything...I couldn't apply enough pressure to compress the back side of the rub rail for the rivet to grab the skin of the trailer. What do you do when this happens?
Also, it looks like the rubber gasket on the outer edge of the front window has fallen in between the window and window frame in a couple of spots. This looks like a good place for water to get in. What should I fill this void with?
Old 08-26-2008, 11:59 AM   #60
Use longer rivets. If the rivet hole has been enlarged, then add rivets close to the problem rivet and then seal in place the rivet that won't stay.
Window gaskets, door gaskets, etc, should be replaced about every 15 to 20 years, depending on the climate.
Sewer vent pipe gaskets should be replaced about every 5 to 6 years.
Old 08-31-2008, 08:50 AM   #61
Duff23's Avatar
1976 Argosy 26
Bathroom plumbing leak
The wheels of progress continue turning ever so slowly...
I haven't talked much about it but my kitchen sink plumbing is finally fixed and leak free, but while pressurizing the water system I heard a leak somewhere under the bathroom floor. I pulled the carpet back and the plywood floor was getting wet from the bottom up. In addition to that the toilet was leaking from the backside.
So now for the two obvious questions:
1. How do I remove the toilet to check for sources of leaks?
2. How do I expose the plumbing under the floor? I'm truly afraid of what I might find under there (i.e. rust).
Thanks in advance!
Old 08-31-2008, 03:55 PM   #62
Argonaut20's Avatar
1966 17' Caravel
Normally, the water system is above the floor so I'd suspect the toilet leak as the culprit for the water you are seeing. Having said that, the toilet is not a biggee to remove. Disconnect the water from the back. Look for (usually) two nuts on bolts coming up from the floor. The nuts may be hidden by covers or otherwise not immediately visible. When the nuts are removed, the toilet lifts up and out. It helps to know the model toilet you have. Scout the Thetford site to see if there isn't a diagram there that will help you see where the fasteners are located.
2006 Toyota Tacoma
Old 09-20-2009, 08:47 PM   #63
Duff23's Avatar
1976 Argosy 26
Alright so it's been awhile (again)....
Okay, I'm back again. My wife might take me out back and shoot me if I don't take the family camping in this thing next spring. I told her that "preserving" the trailer upholds its value but she's not buying it.
So I pulled Lucy out of her shelter and finally got her registered. There's nothing like a trip to the DMV to put a smile on your face. I decided to park her out in the weather for a change. During a heavy rain storm I got inside to look for leaks and noticed the upper vista view had one. I took a look and noticed that the PO went heavy with the silicone on the top edge. I took some of the paint off while stripping the silicone and was wondering about the bare aluminum. Do I need to apply some kind of primer before I seal the window trim up with Vulkem?
Thanks as always,
Duff
Old 09-24-2009, 10:42 AM   #64
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Long Time No See
Duff,
I'm glad to see you're back. I am also glad to hear you had pleasant trip to the DMV. Now that Lucy is registered, why do you have to wait until next spring to go camping. There's still a little time to get out there before the snow flies.
As for your paint question, I would definitely primer, finish paint, and then apply the Vulkem, in that order.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 09-24-2009, 12:01 PM   #65
Usually Sleepy
biggoofball's Avatar
East Haven , Connecticut
Images: 14
I was wondering how Lucy was. And you too. In that order I'm sorry to say. that's a symptom of Aluminitis I think.
biggoofball is offline   Reply With Quote
Old 09-24-2009, 04:16 PM   #66
Alwhisman's Avatar
1978 Argosy Minuet 7.3 Metre
Dayton , Texas
Images: 94
Send a message via Yahoo to Alwhisman
The big brass thing with the bolt in the top is a pressure regulator. It should be set as needed, and it is followed by the pressure relief valve (with the black hose).
.....does anyone know who sells the pressure relief valve?
Alwhisman is offline   Reply With Quote
Old 09-24-2009, 06:08 PM   #67
Argonaut20's Avatar
1966 17' Caravel
Inland RV or Oasis RV most likely. You can also search the web. You might also find them at a plumbing supply house or RV supply near you. They are used on water heaters I believe.
2006 Toyota Tacoma
Old 09-24-2009, 10:02 PM   #68
Alwhisman's Avatar
Dayton , Texas
Images: 94
I tried online and couldn't find them. The water heater valve is different and has a probe that extends past the threaded fitting on the valve...
I'll try the other two
Al
Old 10-01-2009, 07:42 PM   #69
Duff23's Avatar
1976 Argosy 26
Primer and paint...really? What name brand product do you recommend I use for this task?
Old 10-01-2009, 07:46 PM   #70
Duff23's Avatar
1976 Argosy 26
Thanks for wondering. Lucy's bored and I'm busy...the usual story. I'm thinking about finding some proper storage so I can work on her through the winter. I'm glad to see your Aluminitis hasn't cleared up yet.
Do you still Love Lucy? (Youtube clips) Aage Fun & Games 4 07-08-2008 04:26 PM
1971 'Lucy' Sovereign w_burns Member Introductions 8 12-29-2007 09:20 AM
Special Tag for Lucy moosetags Title, VIN & Registration 0 08-19-2006 09:13 PM
