Old 08-05-2008, 05:45 PM   #43
Duff23's Avatar
1976 Argosy 26
Oxford , Connecticut
Originally Posted by DEITZ645 View Post
Duff,
Is there any soft spots under the tank? Have you discovered any leaks in the tank that would account for the moisture on the floor?
There is an isolated soft spot (10" x 10") under the water fill. No, I haven't looked for leaks yet.
Then again our tanks are under slung under the floor in the belly pan. Where are the tanks in the Argosy?
The fresh water tank is on top of the floor just forward of the gaucho.
How close are you to having her camp ready and have you name her yet? Our '87 is Savannah and our '06 is Katarina.
That's a good question. I have all the parts to fix the plumbing issues that I know of...I'm working that now.
I have all the parts to redo the windows except for the Super Weatherstrip Adhesive...I'll work the windows when I find the adhesive. Can anyone tell me where to get it locally. Home Depot did not have it.
I purchased two vent pipe covers from Inland...they're in the mail.
I purchased 24 lug studs and 24 lug nuts from Prestige Wheel...they're in the mail. I'll repack the wheel bearings when I do that job.
I found a suitable remnant for the gaucho for $4/yard. Then dropped it all off with the most reasonable upholsterer...I'll have that back on Friday.
The first camping trip is planned for next Saturday...I'm feeling the pinch.
Her name is Lucy, hence the title of this thread.
Thanks for asking.
Duff23 is offline   Reply With Quote
Old 08-05-2008, 06:25 PM   #44
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Look at Minwax wood hardener, available at Home Depot; it stinks a lot, but works like a charm. The smell dissipates pretty quick.
Take a look outside the trailer at the trim that covers where the trailer body meets the lower wrap. Make sure there are no gaps that may introduce water. The basic construction of Airstreams and Argosys are conducive to leaks. The body of the trailer is set on the floor and the belly pan and wrap are installed next and overlap the trailer body on the outside. So any water running down the trailer body will find a gap and end up inside the trailer or bellypan.
Did you get a new pump, or are you rebuilding the original?
Well it looks like you have everything in line, now it is just a matter of finding the time, right?
DOHHHH!!!!
Thanks for asking.
You're welcome.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 08-05-2008, 08:00 PM   #45
Duff23's Avatar
1976 Argosy 26
I'll pick it up tomorrow.
I see a gap that looks just partially filled with silicone and coincidentally right near the filler cap.
I'm going to wait to get the plumbing back together to see if it works.
Oh, and I need to get to DMV to get it registered.
What about the Super Weatherstip Adhesive...any leads?...or perhaps a Home Depot alternative?
Old 08-05-2008, 08:09 PM   #46
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
Try an auto supply store for the adhesive.
1966 Airstream Caravel
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Old 08-06-2008, 06:50 AM   #47
DEITZ645's Avatar
Duff,
GET RID OF THE SILICONE!!! And replace with the correct sealant. Silicone seems to be a no-no on RV's. Do a Google search for...
silicone site:www.airforums.com
and you will find LOTS of threads cursing the stuff and the correct sealant to use...parbond / vulkem.
Good luck at the DMV.
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 08-06-2008, 05:12 PM   #48
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
My 2 cents... the moisture could be from the front window... driving through rain could force the water through, and sit under the freshwater tank? Other than a leak from the tank (which I think unlikely), the window is my thought... or, leaking from the fresh water intake hose which might be cracked?
Checking in from Europe! (No AS noted around here...)
Marc
Old 08-06-2008, 06:45 PM   #49
Duff23's Avatar
1976 Argosy 26
Marc
...but again, it's been sitting under a carport for 4 weeks. In light of the DEITZ's silicone comment I went out and looked the trailer over for gaps and what they are filled with. It looks like I have a combination of silicone (which is easy to spot) and some other stuff which looks more yellowish and not spongy like silicone. Based on what I've read I need to remove all silicone and replace with Vulkem or Parr Bond...but based on the volume of sealing I'll be doing I'll probably choose the Vulkem (comes in big tube).
I also saw some silicone remover on the Vintage Trailer Parts website. Does anyone have experience with that?...or can I make do with something from Home Depot?
Thanks for checking in from across the pond! Remember...drink "bottled" water...I've learned that lesson twice already!
Old 08-06-2008, 07:29 PM   #50
vhord's Avatar
Images: 96
I haven't used the remover from VTS but what I stock in my hardware store does soften the silicone but you still have to scrape it off. That stuff a b*t*h!
vhord is offline   Reply With Quote
Old 08-10-2008, 04:56 PM   #51
DEITZ645's Avatar
Status Update
Duff,
Any status / progress update? I hope everything is going smoothly.
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 08-10-2008, 08:30 PM   #52
Duff23's Avatar
1976 Argosy 26
Duff,
Progess?...yes, albeit slow. I received the gaucho back from the upholsterer today, I think it looks great...I definitely maintained the retro feel of a vintage coach. I'll show that to you once I finish working the front floor.
I also applied the MinWax Floor Hardener to the soft areas of the floor today...we'll see how that feels once it cures.
I removed the kitchen window in preparation for new guides, fuzzy seal, and D-seal. I had forgotten that I gave my rivet gun to somebody a while back (never thought I'd need it) so I need to go get another one now that I have this project.
I've attached a picture of the sealant used above all six windows on my rig. I'm not sure what it is but it doesn't look like silicone.
I also attached a picture of the seam under the fresh water fill where I think rain water was getting in. I noticed that there is a popped rivet on the metal wrap (what are those metal wrap around bands called?) that's allowing the separation. I'm assuming the correct course of action is to replace the rivet and then seal with Vulkem or Parr Bond (both of which I happened to purchase from my local Airstream dealer in Waterbury, CT, last Friday).
ID:	65430   Click image for larger version
ID:	65432   Click image for larger version
Old 08-11-2008, 04:54 AM   #53
DEITZ645's Avatar
Looking Good
Can’t wait to see the pictures.
You may need two applications. I had a soft spot under the city water line in our ’87 about the size of a hard ball and I used two cans in the entire compartment and it is as hard as stone now.
Never lend out tools
That is the factory vulkem I believe. You can remove and re-seal them with new vulkem, but if they aren’t leaking then you may also want to leave them alone.
This is most definitely where you are getting water leakage. Get that rivet replaced and then seal the gap. The trim strip is called the lower rub strip. The corners are called banana wraps and curved sections under the rub strip are called the lower wrap which extend down to the belly pan.
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 08-11-2008, 09:17 AM   #54
Duff23's Avatar
1976 Argosy 26
Lug Nuts Backordered
Hi all, just a quick question. The lug nuts I had ordered for my Argosy were backordered. At the time I thought it was prudent to buy the bulge type acorn nuts for the extra strength they provide. Now that they're backordered I'm wondering if I should find an alternate supplier for the bulge type nuts or just go with the standard conical seat acorn nut.
Any thoughts?
Duff
Old 08-14-2008, 05:37 AM   #55
DEITZ645's Avatar
Wink No Heel Dragging
Duff,
I think the conical lugs would be OK for Lucy.
I saw in another thread that you are dragging you heals on your project. Well this is you daily dose of encouragement to get out there and get Lucy into camping trim
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 08-24-2008, 12:42 PM   #56
Duff23's Avatar
1976 Argosy 26
Rivets and Vent Pipe Covers
Whew!...it's been a while since I've touched this thing. I was away on vacation up on Campobello Island in Canada. It was supposed to be the inaugural trip with Lucy but that didn't materialize. I saw an endless number of SOB's during the drive (~1000 miles round trip) but not a single Airstream...not ONE! I find that amazing. Anyway, onto the task at hand.
What size rivets are used to fasten the rub strip? I have 1/8" and they don't seem to fit, but maybe the head popped off the rivet leaving the shank in the hole and I need to drill it out before fitting the rivet.
Has anyone experience with the replacement vent pipe covers? They are not the same size as the originals and am wondering what is the best way to proceed. Should I just a) fill in the old holes, b) center the new cover, c) mark the new holes, d) drill out new holes and e) install the new cover?
I finally fixed the copper lines under the kitchen sink and tried filling the lines with water. I had two geysers spewing from the water heater. I flipped the handle on one and it stopped but I couldn't budge the other little T-handle. I'm not familiar with the components of the water heater so I don't know how to describe it. I'll try to post a picture later.
Do you still Love Lucy? (Youtube clips) Aage Fun & Games 4 07-08-2008 04:26 PM
1971 'Lucy' Sovereign w_burns Member Introductions 8 12-29-2007 09:20 AM
Special Tag for Lucy moosetags Title, VIN & Registration 0 08-19-2006 09:13 PM
