Old 12-24-2007, 11:53 AM   #1
1976 Argosy 24
Santa Clarita , California
Adding Roof Air & New Voltage Regulator to Our 1976 24 T
Holiday Greetings!
Just took possession of our 1976 Argosy in amazing condition. Want to add roof air, but there seem to be many opinions on where to place it (front vent over kitchen, rear vent over twin beds or cut a new whole between them in the roof)! Please let us know which option you have chosen, and if you know where Airstream probably placed the wiring harness (and drain?) in this particular trailer.
If you DO recommend cutting a new whole, how much does that procedure add to the air installation at a reputable retailer (such as an Airstream dealer)?
Finally, what are your recommendations regarding replacing the original voltage regulator/converter? It's making a loud humming noise...
Thanks in advance for assistance!!!
AndyPenny is offline   Reply With Quote
Old 12-24-2007, 12:09 PM   #2
Originally Posted by AndyPenny
Holiday Greetings!
There is only one place to install a roof AC.
The wiring is already in the roof.
I will find out the location of the wiring for you and so advise you.
The hum in the converter simply means that the transformer plates are loose.
You can repot the transformer or replace the converter with a new style. New style converters are solid state, so the only noise they make is if and when the fan comes on, which is a cooling fan.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 12-24-2007, 12:34 PM   #3
2007 25' Safari FB SE
Truckee , California
Hi Andy,
I posted a ? to you regarding what type of hitch i should use over in the bicycle thread i started . would appreciate a reply if you didn't see it. Thanks
Fred
flyfishfred is offline   Reply With Quote
Old 12-24-2007, 12:38 PM   #4
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
I have only one rule... use holes that are already there! If you have work on skin replacement u will find that the roof vents are not just a hole rather a complex working or many components.. There are structual members between the skins, these ac units are heavy and wind resistance places futher stress. If you simply cut a hole in the roof u may do damage to part(s) that are important, not to mention you will need to add many structual members! besides less holes in the roof is better than more! Andy is also correct many trailers are prewired!
todd@VINTREAM.com
vinstream is offline   Reply With Quote
Old 12-24-2007, 12:53 PM   #5
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Andy, Merry Christmas. How is this done...?
Old 12-24-2007, 01:02 PM   #6
Take the transformer out of the univolt.
Get a pint or quart of high temp paint.
Put the transformer in a small container, and pour the paint over the transformer.
Gently shake the container so as to remove any bubbles that may form, or invert the transformer, or both, several times.
Let the transformer soak, for at least a day, if you can.
Remove the transformer, let it drip dry, then reinstall it in the univolt.
The noise will be gone.
Loose laminations cause the hum, since they will be ever so slightly moving when power is applied.
You will fill the voids between the laminations with the pint.
Or, get some cheap earplugs.
Andy Rogozinski
Inland RV Center
Corona, CA
Adding air conditioning air66stream Furnaces, Heaters, Fireplaces & Air Conditioning 21 08-20-2008 02:44 PM
1976 Sovereign Refrig And Roof Vents VinceGrande General Appliance Topics 1 12-21-2007 06:48 PM
check valve & regulator urbanfood Fresh Water Systems 2 07-16-2007 12:33 AM
Adding Air to 1969 Caravel-Help Lone Rangerette 1969-1971 Caravel 15 07-09-2006 10:32 AM
Voltage Regulator Rayk Airstream Motorhome Forums 2 09-16-2003 06:36 PM
