Old 03-18-2014, 08:59 PM   #1
ArgosyRover's Avatar
Adding a rear compartment.
Hello all,
I've added a rear compartment to my 24' twin.
I don't know how common this is, I couldn't find any other references.
I'm converting to a rear bed so I wanted to use the space under the bed efficiently.
I've actually put a generator locker in the side as well.
A little tricky as the side must be curved.
The reason I'm sharing is that I couldn't find any commercial hatch doors I liked so I made them out of the rather nice aluminum extrusions the interior cabinetry is made from.
There are a few more details on this page of my blog
Best cheers
Peter
Travels with Geordie
ArgosyRover is offline   Reply With Quote
Old 03-18-2014, 09:23 PM   #2
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
Very nicely done. I live the pix of you running the table saw on the beach.
robert claus is offline   Reply With Quote
Old 03-18-2014, 09:50 PM   #3
Thanks Robert,
It was a lovely place to work.
I'm in New Orleans now, also lovely.
Cheers
Old 03-24-2014, 11:12 AM   #4
crunch27's Avatar
1977 Argosy 24
St. Thomas , Ontario
Good luck, Peter. Will be following your blog and updates.
1977 24' Argosy Double Bed
VIN...24.D7V.1086
2012 F150 Lariat 4X4
with 3.5L EcoBoost
crunch27 is offline   Reply With Quote
Old 03-25-2014, 06:15 AM   #5
1981 31' Excella II
New Market , Alabama
What about the structural connections between the shell and the frame? That section you removed is about 90% of the structure back there.
Perry
Old 04-02-2014, 07:36 PM   #6
Hi Perry,
90%?
It just isn't.
The section I removed is between the double ribs both sides which are still solidly anchored to the steel angle and frame.
The only "structure" sheet aluminium offered here was sheer, bracing.
And there is plenty of sheer left in the remaining skin and the diaphragm effect of the bed structure I've added.
Thanks for the concern though.
Cheers
Peter
Old 04-02-2014, 08:16 PM   #7
Kevin245's Avatar
Nice work Peter. Keep us posted on your progress.
Kevin
Eleanor Roosevelt
Old 04-03-2014, 06:24 AM   #8
1981 31' Excella II
On most Airstreams there is a hold down plate that connects the rear of the shell to the rear cross member. There are several bolts that bolt this plate to the frame crossmember. There are also two larger bolts that bolt the thin weak c-channel to the frame rails. Unless you beefed up the two remaining connections to the frame, you have really weakened the structural attachment between the shell and the frame which is already pretty weak. Was there a hold down plate that you removed to put your door in?
Perry
Rear End Sag on 2005 28' CCD tyggeln Repairing/Replacing Floor &/or Frame 7 10-28-2014 05:17 PM
Rear compartment door problem '94 34 footer MR AIRSTREAM Exterior Storage Compartments & Access Doors 3 11-07-2012 06:09 PM
Why no rear dinette on the shorter trailers? snakyjake Boondocking 22 02-15-2012 05:50 PM
P-30 Rear Suspension alfalsetto Airstream Motorhome Forums 18 11-01-2011 07:15 PM
23 FC rear bed, comfortable for dining? scubadog 2009-2015 Flying Cloud 8 06-09-2011 06:52 PM
