Old 01-20-2014, 08:46 PM   #1
Dan S's Avatar
1975 Argosy 26
Normandy Park , Washington
Accumulator in Argosy
I seems to have a bit of a plumbing knock when running the faucet. Has anyone installed a water accumulator in their Argosy?
Dan
Dan S is offline   Reply With Quote
Old 01-20-2014, 08:51 PM   #2
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
Do have a pressure reducing valve in the system? It sounds like you have too much water pressure.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 01-21-2014, 02:43 PM   #3
1977 Argosy 24
Milltown , Wisconsin
I installed one in my Argosy. What made the biggest noise reduction was a loupe of hose on the intake and pressure side of the pump. It allows the pump to shake and rock, without rattling the pipes. It made things much less noticeable when the pump is running.
ventport is offline   Reply With Quote
Old 01-21-2014, 05:30 PM   #4
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
The piping in my old Safari rattled when the pump was running regardless of the soft mounting, coiled tubing, and strategically placed rubber pads. The only fix was to remove the belly pan to expose the offending bit of plastic tubing that was causing the ruckus. This was not going to happen on my watch so I decided to live with it. Some of the time. I purchased an approximately 1 gallon size residential accumulator tank from Home Depot, installed it way up under the kitchen sink, and did away with the racket, most of the time. Worked flawlessly for 15 years. Jim
Jim Flower is offline   Reply With Quote
