01-29-2018, 10:06 PM
1976 Argosy 28
Clarksville
, Tennessee
A new redux
I looked back at the date I acquired my Argosy trailer. 5-ish years ago. Time to get this project moving.
I dropped the belly pan past the axles a few years back, to inspect the holding tanks and frame. the tanks were holding up (waste gates were promptly replaced) but the rearmost cross member was all but gone. Did some subfloor repairs back there,up front, by the door, rewired some light switches and exterior lights, installed DuraCeramic in the kitchen & lounge area, and a nice floating laminate in the bathroom, hall & bedroom.
The furnace was shot. AC worked (nice and cold) for a spell, then the bearings went out on the blower motor. Water heater was a wash. 8 track player worked.
Then it sat there.
For a few years.
A few weeks ago I blew the dust off of it (more like pressure washed the mildew off the exterior) and that's where this project begins.
Richard
76 Argosy 28 (Unnamed as of yet)
01-29-2018, 10:19 PM
1976 Argosy 28
Clarksville
, Tennessee
From the frame inspection day I knew this was going to be a full monty project.
HOLY CRAP! I've read thread after thread after thread here and it takes TIME, lots of time. And money, and work, and... You know what's involved if you've done it or at least read a few of the detailed start-to-finishes.
Where are we at? Last week, I grabbed up the drill, extra drill bits, the impact driver and started the interior disassembly process. I took the wife's camera along to record video of the process.
End of day one: interior stuff dismantled. The toilet is still mounted and I couldn't readily locate my drain wrench for shower base removal.
Richard
01-29-2018, 10:32 PM
1976 Argosy 28
Clarksville
, Tennessee
Today I freed up some time after a bit of automotive troubleshooting and maintenance and went back at it.
All lights, light switches, wall plugs, fans, etc. were disconnected. Plastic gets quite brittle after 40 years. Univolt and the old, loud, but still functional water pump disconnected.
All burnable wood burnt, save a few curved wall panels for a template.
I have all of this interior aluminum extrusion that needs to go somewhere. I'll not be reusing it and if there is a good home out there that comes across this post and needs it, PM me. I'm not selling it. It's in good condition. I'm giving it away.
Thanks for stopping by. Good night.
Richard
01-31-2018, 09:17 AM
1975 Argosy 28
Springville
, Alabama
If you go back with same floor plan it shouldn't be that bad. I made a few frame/floor/shell/bellypan improvements and changed the floor plan from a rear bath to center bath and added new tanks to sit under the floor in the frame. Not everything in your camper needs to be replaced. Take it from someone who has replaced everything. Most floors are just rotted in a few places and don't necessarily need the whole floor replaced. Much of the wiring is still good and can be spliced onto. The frame will need to repaired but it may not be all that bad. Best wishes and happy remodeling! Post some pics. We all love them! [emoji106]
Matt
01-31-2018, 08:10 PM
1976 Argosy 28
Clarksville
, Tennessee
Today:
I removed all of the extruded metal out of the Argosy, put my PPE on and went to work. Removal of the interior top/center aluminum was interesting, but in no way difficult. All street side interior skins are off, curb side shoulder height and up removed, and all exposed insulation bagged. The skin under the back pano and flat windows were removed. I had a substantial amount of rot back there, but was half-heartedly repaired at some point in the past. I checked out the c-channel down there, since I have read multiple accounts on the forum of folks needing to replace it due to corrosion. Mine seem good. The steel plate back/down there has a fair coat of rust on it. All in all good progress.
I spent a little bit walking around, looking at the wire runs, how the coach is assembled, noted there was a drain for the air conditioner, which was never connected. An educational experience nevertheless. I did notice the factory sealed up all lap joints on the inside of the exterior skin fairly well.
Yep, I know... pictures.
Richard
01-31-2018, 08:48 PM
1976 Argosy 28
Clarksville
, Tennessee
Matt, I follow what you're saying. The layout is changing, so the electrical will also. I'm also going to run dedicated grounds for all 12 volt lights. I don't like the current setup of ground-through-shell. The plumbing also gets re-run to different locations. I plan on checking out the holding tanks again here soon for deterioration. The subfloor is getting swapped out for something a lot less wood. I need to check around town and down in Nashville for a supplier of that stuff Aerowood and/or Malconium put down instead of plywood. There's options out there, I do not want to repair or replace the subfloor after this. I weld for a living, so I can repair the frame or build a new one without worries.
One step at a time.
I read through your thread the other day. Interested in the ceramic paint thermal break idea. After the frame and subfloor work, I'll pick some up and test it on some scrap interior aluminum (not reusing the old interior skins) and see what kind of results present themselves.
Richard
02-03-2018, 08:22 PM
1976 Argosy 28
Clarksville
, Tennessee
A few months back, some hooligans broke out the back window in the Argosy (the flat one, not the panoramic ones). I drilled out the rivets that hold the mitered corners of the frame together, but it is seized together. A quick look down inside the aluminum frame, I see a rusted L bracket that those rivets also went through.
Liberal amounts of Kroil, PB, WD40, Propane torch to heat the area...nada.
What am I missing here? How can I get this frame apart? I could not find an account of anyone struggling with these frames like I seem to be. Any help or advice is welcomed and appreciated.
The photo on the left is what the each corner looks like before drilling the rivets, the right pic is after.
Richard
02-03-2018, 11:33 PM
1975 Argosy 28
Springville
, Alabama
It looks welded together but upon further review they are covered with tremco polyurethane caulk which does not come off except by mechanical means. Which means they are almost welded together. Clamp it down and try a rubber mallet. If your replacing with lexan, you may be able to flex or bend it to fit.
Matt
02-04-2018, 02:45 PM
1976 Argosy 28
Clarksville
, Tennessee
Thank you, Matt, for the advice. I'll give it a shot with the mallet. I planned on taking the frame, once apart and cleaned, to a local glass company to get a replacement cut. I've read a lot here about lexan discoloration, scratches, and other uv damage over time. I do not have any personal experience with lexan in an outdoor environment, so I will just put glass back in.
02-14-2018, 01:02 PM
1976 Argosy 28
Clarksville
, Tennessee
The day before yesterday, I finished up removing the curb side interior skins (photo 1), insulation and plastic end caps. The front end cap was the only challenging piece to remove, due to the wires running through it. There was no insulation underneath/ between the wheel well covers. I pulled up the two rearmost subfloor pieces to get a few photos of the damage for y'all. Two of the now exposed outriggers see some cancer (photo 3), the rear-most crossmember apparently needs replacing (photo 2), and some deterioration of the frame rails on both sides needs a good game plan (photos 4 & 5). All of the c channel/ u channel around the perimeter looks great.
I need to move the Argosy to an area a bit more level before I build the gantrys and pull the shell. It is currently mostly level front to rear, but lists 10 degrees to street side.
Richard
02-14-2018, 01:48 PM
1976 Argosy 28
Clarksville
, Tennessee
Some photos of water damage up front: Underneath where the fresh water tank resided (Photos 1,2 & 3). By the water pump (Photo 4).
I don't know what type or name of this sealant the factory used (Photo 5). Pictured here, it sealed behind the fridge. Not pictured in this post, it is on every seam inside of the exterior skin and coating every wire exiting the skin. Tough stuff. It doesn't seem to have deteriorated at all. Any idea what brand it might be, and is anyone using it now days?
Richard
02-14-2018, 04:00 PM
1973 Argosy 24
Grafton
, Ohio
Argosy Project
Lots of progess there,keep up the good work. I believe the orignal seam sealer was Vulkem, not sure if they still make that stuff anymore, 3 years ago I replaced
several exterior panels on my 1973 argosy, I used Trempro 635 from Vintage Trailer Supply. So far no leaks after about 5000 road miles hope this helps.
02-14-2018, 05:13 PM
1975 Argosy 28
Springville
, Alabama
This looks like the average 40 year rehab as far a deterioration goes. Your frame is not that bad. Your course of action depends on your level of perfection and budget.
A. Weld on new angle on the frame, replace the damaged outriggers and weld on a new cross member
B. Build or have someone build a new frame.
You can also use sikaflex 221. Both sikaflex and trempro are polyurethane caulks. I like the sikaflex better. It tends to harden a bit more. I use both.
Keep up the good work.
Matt
02-15-2018, 08:48 AM
1975 Argosy 28
Springville
, Alabama
It amazes me how airstream experimented on our argosy's in the 70's. Mine is a year older-75 28 footer. My frame had 2 2x4s that ran the length of trailer for center support. Yours are metal. Mine also has fiberglass endcaps. Are yours galvanized steel or the fiberglass? I wish there was a way to post my entire thread on the argosy section instead of the floor and frame section. I look forward to following your build.
Matt
02-15-2018, 10:26 PM
1976 Argosy 28
Clarksville
, Tennessee
Backroads, Matt, thanks for the info on the poly caulks.
Matt, a moderator might help you pack up your thread and move it over this direction.
Galvanized end caps on my model.
Richard
03-06-2018, 12:16 PM
1975 Argosy 28
Springville
, Alabama
How's the rebuild going?
Matt
03-07-2018, 01:32 PM
1976 Argosy 28
Clarksville
, Tennessee
Matt, I am out of town on business currently. Just a bit west of you, in Quinton / West Jefferson. I have staked an area to level to park the Argosy. I have to get a feller out to level the dirt and top with gravel. Although I am not physically putting my hands on it right now, I am still ironing out local suppliers for subfloor alternatives, and interior layout rough sketches.
Richard
06-16-2018, 12:15 PM
1976 Argosy 28
Clarksville
, Tennessee
Back home now, I am able to start clearing some land to park the Argosy for its shell off. A great time of year, when the poison ivy, ticks & skeeters are out in abundance. I picked up a few quotes on delivered gravel from a few local businesses. One not far up the road said $15/Ton+$110 for delivery. I'll have 20 tons delivered just for this project, then more at a later date for other projects unrelated.
I changed the location of where I will be doing the shell removal. I have to clear some brush, tear down an old shed, down a few trees and trim a few others. Then the dirt work. It works with the location I plan to build my shop. No need to do the work twice.
Long sleeves and long pants- check.
Deet - check.
Sunscreen - check.
Water - check.
Tools and tunes - check.
Richard
06-16-2018, 09:27 PM
1975 Argosy 28
Springville
, Alabama
Working on the argosy maybe the easy part[emoji12]
Matt
06-19-2018, 09:20 PM
1976 Argosy 28
Clarksville
, Tennessee
Well Matt, I anticipate both getting the land ready for the Argosy and actually working on the trailer to be hard work. I am no stranger to hard work or hot weather working, so I'm well suited. Yesterday and today accomplished quite a bit on the land-clearing front. I'll do some stump grubbing and shed removal tomorrow. Oddly enough, I haven't seen any snakes yet. I'd post pictures, but it's just clearing land.
Richard
