Old 05-07-2015, 01:27 PM   #1
1975 Argosy 26
chambersburg , Pennsylvania
A.c. Not cooling, I don't hear compressor engage when I turn up or down. Summer's com
Jimin pa
jimin pa is offline   Reply With Quote
Old 05-07-2015, 01:42 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
First are you sure the power is on?
Next confirm that the relay is pulling in when the thermostat is calling.
Check for voltage on the output side of the relay.
Check that the compressor windings are not open after floating the compressor and using an ohm meter.
If all is good to this point it may be the starter cap.
You will have to open the shroud for some of these tests
2004 Excursion 4x4
Old 05-07-2015, 02:54 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Squirrels chewed up my "reversing valve" wiring. All fixed now!
Peace and Blessings..
Channing
WBCCI# 30676
Goin' down, down, down... Aironius Axles 12 08-23-2014 08:09 AM
Bedroom Lights Don't Turn On/Turn Off and turn back on after a couple minutes. alecg Lights - Interior & Exterior 9 09-01-2010 02:01 PM
Enjoy, Engage, Your Heritage and more...a msut read! PeeWee Off Topic Forum 0 08-18-2009 03:08 PM
AC Fan runs, compressor does not turn on JW84345 Furnaces, Heaters, Fireplaces & Air Conditioning 8 07-06-2009 04:37 PM
