Old 12-22-2006, 07:20 AM   #1
A/C for my 6 Metre Minuet
Does anyone have a rough idea on the cost for a replacement? My original is about shot.
Thanks!
wardster is offline   Reply With Quote
Old 12-22-2006, 09:53 AM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Wardster!
Thanks!
I have had very good luck working with my regular dealer for off-season deals on such things as Air Conditioners. When I had the air conditioner installed in my Minuet (Coleman Mini-Mach), the total installed cost was less than $700 which included cutting the hole in the roof and installing a new circuit breaker for the Air Conditioner. The only down-side to the Mini-Mach is that it does not have provisions for the condesate drain so the condesate drains down the sides -- a greater problem with the Minuet than the Airstream -- I have had no ill-effects from this arrangement with the Airstream, but on the Minuet, have had problem with rust streaks along the sides.
Good luck with your search!
Kevin
Kevin D. Allen
AIR #827
« New To Me | Top | chief 1 »
Argosy Minuet 22' and 24' (1979?) overlander64 All Argosy Trailers 67 10-31-2007 09:17 AM
Minuet Front Window Rock Guards overlander64 All Argosy Trailers 54 12-01-2003 09:13 PM
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 06:11 AM
1971 Armstrog A/C uwe Furnaces, Heaters, Fireplaces & Air Conditioning 2 08-06-2002 05:08 PM
Mediocre A/C Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-07-2002 07:52 PM
