Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Argosy Trailers > All Argosy Trailers
Old 12-23-2005, 09:09 PM   #1
mtnman's Avatar
Collettsville , North Carolina
'79 Argosy project
Do I need to keep going back to my original thread every time I want to share something with you folks or just start a new one with the new subject?
Any way I got my toilet perch built today, check out the pic!
mtnman
mtnman is offline   Reply With Quote
Old 12-23-2005, 09:13 PM   #2
mtnman's Avatar
I also got my waste valve put in this week, glad that job is over. Now all the water line leaks are repaired and the plumbing is finished!!!!
mtnman
Old 12-23-2005, 09:16 PM   #3
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
OlyPen , Washington
Images: 101
Some folks start a dedicated thread to report ongoing restoration. But if you have a specific issue you can start a new thread about it... for example: if you need info on replacing or repairing pluming, you might post a new thread about it in that sub forum. It's always a good idea to do a search first to see if someone else has encountered your problem and posted answers. You can also post on a thread that someone else has started - provided it's on the same general topic.
Hope this helps. Nice pedestal , by the way.
1964 Globetrotter | 2023 Nissan Armada
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 12-23-2005, 09:35 PM   #4
mtnman's Avatar
Thanks Janet! That helps clear that up. I have about 5 different threads in the All Argosy forum, I will stick with one subject.
mtnman
Old 12-23-2005, 09:42 PM   #5
InsideOut's Avatar
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen , Colorado
Images: 108
You may want to consider putting your topical threads under the sub-forum they are best related to, not just all under Argosy. The reason is it will get many more viewers (both Argosy & Airstream owners) with the potential of answering your question. Even though the outside appearance is different Argosy interiors & systems have many of the same 'issues' (ie. electrical, plumbing, restoration, etc.) as Airstreams, in many ways they are identical. If you post in just Argosy, some Airstream owners will never look there. If your question is something only Argosy related, place it in the Argosy section.
Shari
Just a thought ~
RMVAC | ACI - CO Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 12-24-2005, 07:01 AM   #6
Just an old timer...
85MH325's Avatar
2004 22' Interstate
Tipton , Iowa
Images: 37
Y'know, I'm old enough to remember outhouses, and that's just about the fanciest one I've ever seen! It IS, big enough to make it a two-holer, y'know... where's the Sears and Roebuck catalog gonna go?
Nicely done pedestal!
Roger
havin' to fix my broken Airstreams since 1987...
AIR 2053 Current: 2004 Airstream Interstate "B-Van" T1N DODGE Sprinter
Old 12-24-2005, 08:36 PM   #7
mtnman's Avatar
Toilet is in!!!!!
Old 12-24-2005, 08:41 PM   #8
mtnman's Avatar
What did you do on Christmas Eve? I pack new wheel bearings and worked on the gaucho. I am in the red.
mtnman
Old 12-30-2005, 01:35 PM   #9
The Painted Pig
Moonshot's Avatar
1979 Argosy Minuet 7.3 Metre
Hailey , Idaho
Images: 14
Hello Mtnman,
Nice Argosy! It looks familiar!
I think you and I have the only minuet 7.3 metres on the forums.
Did you replace the black tank when you did your plumbing work? I had to replace mine last year. I had to get one fabricated, Inland RV didn't have a good match in stock.
Scott
Moonshot is offline   Reply With Quote
Old 12-30-2005, 03:08 PM   #10
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Originally Posted by mtnman
Toilet is in!!!!!
Very NICE !
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 01-01-2006, 06:38 AM   #11
mtnman's Avatar
Originally Posted by Moonshot
Hello Mtnman,
Scott
Scott,
I did not replace the black water tank. It was in real good shape. I did clean it out good once I got the waste valve replaced. All works good with no leaks. I did not realize that there were so few minuet 7.3 metres?
mtnman
Old 01-01-2006, 08:53 AM   #12
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 194
79 Argosy project
Greetings mtnman!
mtnman
The Minuets had the shortest production run of any of the Argosy coaches -- late 1977 through 1979 model years. The 6.0 Metre was the most prolific Minuet (based upon observations at various WBCCI and Forums Rallys); while the 6.7 Metre wast the next most popular; with the 7.3 Metre being the lowest production of the three. Thus far, I don't believe that there has been anything other than Minuet 6.0 Metre coaches at the WBCCI International Rallys that I have attended -- I don't recall seeing any 7.3 Metre Minuets at any of the International Rallys that I have attended (1989-2005). In part, I suspect that these numbers may relate to when each of the coaches was introduced -- based upon the sales literature that I have, the 6.0 Metre was the first to be introduced followed quite closely by the 6.7 Metre, and the 7.3 Metre was introduced quite a bit later -- possibly not until late in the 1978 model year (I haven't been able to confirm precise introduction dates for each of the Minuet coaches). As with Airstream, finding specific production numbers for any of the Argosy coaches is extremely difficult at best.
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
Old 01-01-2006, 07:42 PM   #13
mtnman's Avatar
What does the 6, 6.7 & 7.3 stand for? Is that the lenght of the coach?
mtnman
Old 01-01-2006, 07:48 PM   #14
mtnman's Avatar
Wheels are done!
Old 01-01-2006, 07:51 PM   #15
mtnman's Avatar
Here is wife sewing a new gaucho cushion onto the foam mattress.
Old 01-01-2006, 07:55 PM   #16
mtnman's Avatar
one gaucho done! Here is mtnman and his woman!!
Old 01-01-2006, 09:14 PM   #17
Moderator Emeritus
1964 26' Overlander
Anna , Illinois
Images: 194
79 Argosy project
Greetings mtnman!
mtnman
Yes; 6.0, 6.7, and 7.3 refer to the lengths of the coaches in meters. The precise reason why the Minuets were sold in this manner has never been revealed so far as I have been able to determine. The 6.0 Metre Minuet is was typically registered as a 20' coach in the US; while the 6.7 Metre coach was typically registered as a 22' coach; and the 7.3 Metre was typically registerd as a 24' coach.
Kevin
Kevin D. Allen
AIR #827
Old 01-06-2006, 09:10 PM   #18
1960 28' Ambassador
Libertyville , Illinois
Metric Lengths
mtnman:
The 6, 6.7 & 7.3 Metre coding was in fact the length designation for these coaches.
6 M = 19.5 feet
6.7 M = 21.775 feet
7.3 M = 23.725 feet
Short563 is offline   Reply With Quote
Old 01-07-2006, 04:40 PM   #19
mtnman's Avatar
New tires going on!
Old 01-11-2006, 12:48 PM   #20
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
Wow, you've done a good job on the Argosy. I have a 78 24ft Argosy that has those same rims. Do yours have a little orange stripe around them that says Argosy. I see the banana wrap is blue, mine is orange. I've wanted to get an Airstream ever since I sold my 67 Caravel; however, I have fallen in love with the Argosys and can't imagine having anything else. Love what you've done to yours.
juel is offline   Reply With Quote
1993 30' (late 92 model) Excella :: 1993 Airstream Excella1000 arcamedies Airstream Registry Discussions 2 07-28-2012 09:10 AM
Question regarding sleeping & eating in a 1978 28' Argosy.. Rick F Argosy Motorhomes 4 09-01-2011 11:40 PM
Elsa :: 1972 Argosy Argosy 20 bobfowler Airstream Registry Discussions 0 08-19-2011 08:31 AM
Project 24' Argosy in Central CA.. Rick F Argosy Motorhomes 0 08-09-2011 03:06 PM
1973 Argosy / Airstream Camper - $4100 (Newark) 61Ambassador Airstreams on eBay 4 02-13-2011 11:11 AM
