Old 06-01-2008, 11:57 AM   #1
1978 Argosy Minuet 6.0 Metre
Gonzales , Louisiana
'78 Argosy 6 metre Minuet battery compartment door
Hope someone can help me out here. I do not have the key to the
battery compartment door is there some way to get this open without
using the key?
jholder45 is offline   Reply With Quote
Old 06-01-2008, 12:17 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Welcome to the forums!
Several choises here to get the door open.
  1. Find another Airstream owner and try their key, it might work.
  2. Pick the lock (get a locksmith).
  3. Drill it out.
  4. Pop the door open. If yours is like my 75 TW, the arm that holds the door closed is not very strong. Several people have had the battery bounce against the door and force it open on the road. It happened to me, but the good news is I did not loose the battery.
Richard
Old 06-01-2008, 04:27 PM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
In my Aistream I can get to the back of compartment doors from under the bed or closet. If you can, if it is like my airstreams you can loosen the catch with a wrench.
If that doesn't work and Richard's ideas don't work, you can always get a big hammer.
Old 06-01-2008, 07:22 PM   #4
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
Anna , Illinois
Images: 183
Greetings jHolder45!
Welcome to the Forums and the world of Minuet ownership! I can't guarantee that this will work on your Minuet, but it worked on mine when the key wouldn't work in my battery compartment lock. Using an artist's pallette knife (a very flexible, thin bladed paint application tool), I worked the knife between the door and body trim and pushed the lock lever to the unlocked position -- I was then able to install a new cylinder to replace the defective cylinder.
Kevin
Kevin D. Allen
AIR #827
Christine :: 1978 Argosy 7.3 Metre Minuet Alwhisman Airstream Registry Discussions 0 08-19-2011 08:31 AM
1978 Argosy Minuet 6.0 Metre :: 1978 Argosy by Airstream Minuet 6.0 Metre overlander64 Airstream Registry Discussions 0 08-19-2011 08:30 AM
Battery Compartment Door Leak McDonalds Exterior Storage Compartments & Access Doors 4 06-28-2011 07:52 AM
My battery compartment door fell off DougZ Exterior Storage Compartments & Access Doors 0 06-05-2011 06:05 PM
