Old 09-11-2003, 05:26 AM   #1
77 Argosy weight
Can I have help with the weight of a 77 20ft Minuet? It is not listed on the airstream link of trailer weights that I could find. Did this trailer have aluminum floor? Thanks for the info.
cdholt is offline   Reply With Quote
Old 09-11-2003, 05:58 AM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
77 Argosy weight
Greetings!
I don't have the figures for 1977, but the very similar 1978 Minuet 6.0 Metre has an empty weight without options of 2,450 pounds. Recently, the following weights were recorded on my Minuet when travel and vacation ready:
Minuet (6.0 Metre) was fully loaded for a three-week excursion (LP tanks full, water tank full, holding tanks empty), its gross weight was 3,250 pounds (GVWR is 3,500 pounds) and the hitch weight was 550 pounds.
Thus far, I am not aware of any definitive source that has been able to pin down the beginning nor ending dates for the aluminum composite flooring in the Minuet 6.0 Metres. It is not mentioned in any of the literature that I have acquired, and the only way that I learned the true makeup of my floor was when the carpeting was removed to expose the riveted aluminum floor underneath. It does, however, seem that the 6.0 Metre was the primary coach in the Minuet series equipped with the aluminum composite flooring - - I don't remember any comments from owners of 22' or 24' Minuets with the aluminum composite flooring.
Kevin
Kevin D. Allen
AIR #827
Old 09-11-2003, 03:29 PM   #3
loudruff's Avatar
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
Aluminum Floor
We have a 22' 1977/78 Minuet, and it has an aluminum composite floor.
loudruff is offline   Reply With Quote
Total Weight & Tongue weight of 24' Argosy woody_strohm Our Community 3 12-21-2008 10:25 PM
Start of restoration '77 Argosy 20ft barbwire All Argosy Trailers 18 08-15-2004 06:42 PM
'77 Argosy, should I jack because tires flat? saxonsraven1 Mechanics Corner - Engines, Transmission & More... 1 01-26-2004 02:18 PM
Front console for a 77 Argosy saxonsraven Our Community 6 06-23-2003 08:46 PM
rear storage container - 77 Argosy balloonman Bumpers & Bumper Storage 2 05-16-2003 10:28 PM
