Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Argosy Trailers > All Argosy Trailers
Old 05-13-2008, 06:36 PM   #1
duo_77340
Profile:  1977 Argosy Minuet 6.0 Metre
Centerville , Texas
'77 Argosy Minuet 6.0 Metre
I just purchased this '77 Argosy Minuet 6.0 Metre. I am planning to renovate/remodel for my own personal use. I purchased from the daughter of the original owner. Everything in the unit was original and reported to work when purchased. However, the refrigerator was replaced by the owner with an electric only model, after I purchased it, but I have removed it and a gas/electric model has been ordered. I have decided to convert the front dinette to a bed on a permanent basis and have cut the sofa into two pieces to form a new dinette. I have stripped all carpet out down to the aluminum flooring. I am still undecided on a flooring...considering cork or a vinyl plank...but it will definitely not be carpet. The tambour under the sink was trashed, but I plan to replace it. I have it scheduled for service at a local repair shop, since the black water valve is stuck, and I am not feeling too confident in the longevity of the A/C. I am also going to have the wheel bearings checked, packed and brakes checked. In addition to new tires...they are pretty much shot.
Does anyone have any experience with marmoleum as a countertop replacement? Also, I have not found the TV antenna wire...where might it be located inside the unit?
I do plan to do exterior work...just trying to get the interior completed first.
ID:	60423  Click image for larger version
ID:	60425  Click image for larger version
duo_77340 is offline   Reply With Quote
Old 05-13-2008, 06:49 PM   #2
maxandgeorgia
maxandgeorgia's Avatar
Profile:  1995 30' Limited
Ashland , Missouri
Hello, and welcome to our forum. Your Argosy is the twin of one I hope to find someday. We really admire these trailers. You've gotten off to an energetic start and you have a clear vision of your renovation plans. Thanks for posting pictures, and please, keep us updated! ~G
maxandgeorgia
1995 Airstream Classic Limited 30' ~ Gypsy
Chev Silverado 2500HD Duramax/Allison, 4X4, Crew Cab
WBCCI #5013 AIR #2908
WDCU
Go, Mizzou...Tigers on the prowl!
maxandgeorgia is offline   Reply With Quote
Old 05-13-2008, 07:00 PM   #3
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 58
On my 75 Trade Wind the TV antenna connection was on a plate on the wall in the kitchen area. It has a 12 volt power plug and two small holes about 3/4 of an inch apart. A plug with antenna wire goes in those holes.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 05-13-2008, 07:01 PM   #4
Janet
Janet's Avatar
Profile:  Eastern , Washington
Images: 63
You have a big list.
The tv wire terminates in a wonky looking plug just to the left of the sink (look up) on the underside of the overhead bins.
Try putting 2 bags of ice and a little water into the toilet and driving around for an hour or two - the 'stuck' might be fixed
And welcome to the forum!
77 Argosy Minuet, 6 metre
77 Argosy 24, Rear door
AIR 3181, WBCCI/VAC # 5575
Wally for President
Janet is offline   Reply With Quote
Old 05-13-2008, 10:09 PM   #5
myboyburt
NEU 1VP 2008-2009
myboyburt's Avatar
Profile:  1993 25' Excella
New Boston , New Hampshire
Images: 12
We just purchased our 1977 Argosy Minuet from my sister and her husband.
Last year they ripped out the carpet and installed "Traffic Master" vinyl plank flooring in "ScatterBug" (the name they gave our Argosy). It's beautiful, it adapted to the uneven metal floor and it cleans up well. I recommend it.
Michelle & Leon
WBCCI # 7032 Region 1, New England Unit
Looking for a WBCCI Unit filled with fun loving folks to camp and travel with in the New England area? Well, you've just found it:
myboyburt is offline   Reply With Quote
Old 05-13-2008, 10:37 PM   #6
SmokelessJoe
SmokelessJoe's Avatar
Profile:  1976 Argosy 24
TORONTO and Southwestern , Ontario
Marmoleum
Duo:
This is MARMOLEUM used as a counter top in my Argosy renewal.
I used the same colour on the floor. It’s really marvelous there but I don’t have any real world experience with the counter top yet.
Perhaps more photos on my main thread here:
Contemporizing 1976 Argosy D - opinions please
Best wishes, good luck,
Sergei
SmokelessJoe is online now   Reply With Quote
Old 05-14-2008, 07:07 AM   #7
adore
adore's Avatar
Mont-Laurier , Québec
Check the axle...
From what I see of the tire... the trailer seems pretty low. I would check the axle if I were you before doing any work on the wheel bearings or/and brakes. Your axle may well have to be replaced. I also own a 1977 Minuet and this is what I have to do...
adore is offline   Reply With Quote
Old 05-14-2008, 09:42 AM   #8
cameront120
cameront120's Avatar
Profile:  1972 25' Tradewind
Were the aluminum floors in the Minuets just a single sheet of aluminum, or were they a sandwich panel of some sort? I'm assuming that this floor is structural in nature.
Cameron & the Labradors
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
http://northvancouvermodern.blogspot.com/
cameront120 is online now   Reply With Quote
Old 05-14-2008, 10:09 AM   #9
duo_77340
Centerville , Texas
Thanks to everyone that has replied. I appreciate the information. This helps us out alot.
I will have them look at the axle first.
It is my understanding that the floor is plywood, sandwiched between two sheets of aluminum.
Old 05-14-2008, 08:03 PM   #10
georgezink
1963 19' Globetrotter
Lawrenceville , Georgia
The floor on our '77 six metre is styrofoam sandwiched between two layers of aluminum. The "sandwich" panels are joined together every 4 feet (front to back) with an aluminum spline which is rivited through the two adjoining panels. These rivited floor joints present a problem for flooring options as the rivit heads could "telegraph" through thin sheet products. Plus, the styrofoam sandwich floor seems to have more spring to it.
We're still in the process of remodel/restore and haven't gotten to the floor yet - but it would seem that a floating "click" floor with added underlayment would offer some firmness to the minuet floor as well as address the bumps from the rivit heads. I have found the "click" option in laminates, hardwoods, bamboo, cork, and linoleum. Some have an mdf core, some an hdf core. Some come with a foam or cork backing. Right now, I'm leaning towards click Marmoleum with an hdf core and a cork backing - I've ordered color samples. I would use more cork underlayment during the install.
Hope this helps...
George
flcracker
georgezink is offline   Reply With Quote
Old 05-14-2008, 08:11 PM   #11
kenny2
Profile:  1972 Argosy 20
1979 30' Argosy
Grand Junction , Colorado
Minuet
The floor on our minuet is also the Al/foam sandwich. I picked it up at a good price partially because the PO thought the floor was "rotten".
I installed a laminate floor from Sutherlands (a lumber/hardware chain) about four years ago and it has worked well. Also makes the floor seem firmer.
Replaced the Suburban furnace w an Olympian heater and love it.Quiet and no battery drawdown. Recommend these heaters highly!
kenny2 is offline   Reply With Quote
Old 05-15-2008, 12:19 AM   #12
adore
adore's Avatar
Good suggestions...
I also took the carpet out and installed a laminate floor years ago and nothing has moved. The subfloor took care of the rivets so they didn't cause any problem for the installation and since then. What is size of your Olympian heater and where did you install it?
Old 05-24-2008, 01:49 PM   #13
duo_77340
Centerville , Texas
Dinette
I would like to install a new dinette. I would like to attach the table to the floor instead of using the wall mounts. Is this possible given the aluminum styro sandwich construction?
Old 05-24-2008, 01:58 PM   #14
cameront120
You could drop the belly pan and use a piece of plate steel on the underside and the top of the aluminum sandwich floor through bolted to create blocking onto which a table base could be attached. You could also use wood for the blocking. Pressure treated or treated plywood on the underside and maybe a nice piece of hardwood on the interior side. Basically, I think you need blocking of sorts that will have the integrity to support the table.
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
A/C for my 6 Metre Minuet wardster All Argosy Trailers 1 12-22-2006 09:53 AM
Price check on '78 Argosy 6 metre Minuet Van All Argosy Trailers 18 05-08-2006 08:01 PM
1977 argosy minuet ... six metre gotair Parts Archive 1 05-01-2004 12:04 AM
Another Minuet 7.3 Metre May Be On-Board! overlander64 All Argosy Trailers 1 04-23-2003 09:42 PM
