Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Argosy Trailers > All Argosy Trailers
Old 07-06-2008, 09:38 AM   #29
David&Diana
Profile:  1977 Argosy Minuet 6.0 Metre
Winter Park , Florida
Dometic vs Norcold
I had a bad experience with Dometic's customer service on my AC unit. So I really don't want to use their refrigerator. Does anyone have any comments about the Norcold N300 which is a close enough fit for my old RM46E Dometic.
Is there a measurement for the top of the axle to the wheel well that tells you the condition of the axle rubber? Or is there another way to tell the condition?
Dave
ps: guess we are keeping the Argosy
David&Diana is offline   Reply With Quote
Old 07-06-2008, 01:32 PM   #30
Argonaut20
Profile:  1978 Argosy Minuet 6.0 Metre
Las Cruces , New Mexico
For the axle go to pages 1 and 2 of "Information Overload" in this forum. Andy at Inland RV refers to an article on axles that will answer your axle questions. As for the refrigerator, I just finished putting in a Dometic 2351 to replace the RM46. I figured the 46 lasted 30 years so I couldn't go too far wrong with the Dometic. Also, it was on sale at ppl motorhomes. In passing, I doubt any of them will be a drop in fit. Prepare for some modification.
1978 Argosy 6 Metre Minuet
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Old 07-11-2008, 02:46 PM   #31
duo_77340
Centerville , Texas
Pics showing new tambour door and refrigerator.
Putting in the tambour door was somewhat of a pain, but the final result looks good.
ID:	63515  Click image for larger version
duo_77340 is offline   Reply With Quote
Old 07-11-2008, 07:30 PM   #32
Argonaut20
The tambour door looks terrific. What did you do to make it work?
2006 Toyota Tacoma
Old 07-12-2008, 08:19 AM   #33
duo_77340
Centerville , Texas
Eventhough we had Inland RV use the old door as a pattern for the new door, we had to cut the new door down twice to get it in place. Even at that, trying to feed the new door into the track is a challenge and takes patience. LOL
Old 07-18-2008, 04:43 PM   #34
duo_77340
Centerville , Texas
Minuet Returns from more Updates
Today we brought the Argosy home from the shop. We had a new battery charger/converter installed, two new Fantastic fans, a new antenna with cable hookup, valve under bathroom sink removed and replaced with direct pipe, and had the plumbing on the shower drain installed so that the shower now drains out the blakc/grey water outlet. Interior is now complete.
Old 07-18-2008, 06:59 PM   #35
Duff23
Duff23's Avatar
Profile:  1976 Argosy 26
Oxford , Connecticut
Duo, during your tambour door project did you ever manage to expose the entire lower track...including the roll-up part? The under-sink tambour on my '76 Argosy 26 is binding on me and I'd like to clean the entire track but can't figure out how to get into it.
Duff23 is offline   Reply With Quote
Old 07-19-2008, 07:54 AM   #36
duo_77340
Centerville , Texas
Our roll-up part is on the right side of the cabinet in a small compartment. Once the tambour door was removed, the plastic roll-up part was able to be removed, as it is held in place by two screws. We washed this and then replaced.
Old 07-19-2008, 10:03 AM   #37
Duff23
Duff23's Avatar
Great, thanks. My tambour rolls on the right side as well. So does that mean that I have to remove the tambour door in order to get to the roll-up portion of the lower track? If so, how do I remove the tambour?
Old 07-19-2008, 05:30 PM   #38
Argonaut20
I just looked at the tambour door under the sink. I am going to hazard a guess that the tracks for the door are held to the cabinet with two pop rivets, one at either side of the door opening about 1.5 inches down from the door opening. Drilling these out should drop the track and free the door. This is just a guess as I have not removed this door in my own Argosy, but it looks like a good guess to me.
2006 Toyota Tacoma
Old 07-19-2008, 08:36 PM   #39
Duff23
Duff23's Avatar
I was afraid someone would say that....I have yet to drill out a rivet. I'm perfectly capable, just apprehensive. That means I have to go buy a rivet gun to redo whatever I undo. I guess I should have expected that comes with buying a vintage Argosy.
Old 07-19-2008, 09:07 PM   #40
Argonaut20
Be of good cheer. Buy 1/8" drills, put the point in the dimple in the head of the rivet, drill carefully and square to the surface, and the head will pop off. The track will drop when the rivets release. Go to Harbor Freight or Lowes or Home Depot and buy a pop rivet tool and some 1/8" rivets, medium length. When you get the track and scroll cleaned, align the holes in the track, slip the rivet into place, use the tool to pull the rivet. I would guess you will have to color the head of the rivet with a marker as I have yet to find brown rivets.
2006 Toyota Tacoma
Old 07-19-2008, 09:09 PM   #41
Argonaut20
Buy aluminum rivets, not steel.
2006 Toyota Tacoma
Old 07-19-2008, 09:37 PM   #42
Duff23
Duff23's Avatar
Good advice, thanks Argonaut.
A/C for my 6 Metre Minuet wardster All Argosy Trailers 1 12-22-2006 09:53 AM
Price check on '78 Argosy 6 metre Minuet Van All Argosy Trailers 18 05-08-2006 08:01 PM
1977 argosy minuet ... six metre gotair Parts Archive 1 05-01-2004 12:04 AM
Another Minuet 7.3 Metre May Be On-Board! overlander64 All Argosy Trailers 1 04-23-2003 09:42 PM
