Tambour tracks
Well I suspect some purists will cringe but I have gutted my 77 Argosy 6 Metre Minuet's galley and am going to remodel it with modern appliances so I have some 'stuff'.
If anyone needs the two spiral plastic Tambor tracks I have 'em and they are yours for the cost of shipping. Yes they have two pop rivet holes and you can remove them by carefully drilling as has been said before.
I also have the 3 Burner Magic Chef stove and oven combination that came with this unit. The oven appears to not have been used however there is some surface rust on the stainless top and front, elbow grease probably make it look good. Cost of shipping only. I am also going to remove the heater as I don't use it and don't want to go through the effort to test it although it does come on. Again only cost of shipping and the box to put it in. I may post the stove on the general Airstream portion of this forum but since I found you "Argo-nuts" I have enjoyed the posts and learned a lot so first here.
If anyone knows of any other bits from this part of the trailer let me know. I would rather recycle them then throw them out.
Cheers,
Dave
