Old 02-05-2007, 02:23 PM   #1
1977 24' Argosy 24
SW Florida , Florida
Images: 8
Unhappy '76 Argosy Furnace Needed
My 76 20 foot Argosy has a rust crack in the furnace baffle - that things that looks like a steam-heat radiator. I am a fiddle player in SW Florida and don't need the furnace too much, but I assume this is a noxious fumes AND fire hazard.
What are my alternatives for heat?
Can I find a replacement furnace - new or used? (I will have to do it myself, as fiddlers have yet to be paid enough money to support vintage RV habits, at least around here - I also have this fiddle habit.......and they require new strings, bows to constantly rehair, etc.)
I'd like to have a heat source that is NOT forced air, but then I guess I'd have to be plugged in to electric - right?
Can I weld or solder the crack? It looks like a rust crack, like it's from rustiness and age.
I am rarely on this forum, so email me, please, at vxn@comcast.net. All replies appreciated.
Elisa
Elisa is offline   Reply With Quote
Old 02-05-2007, 03:37 PM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Hello Elisa. One can go in their User CP (control panel) at the upper left and edit options to receive Thread Subscription emails when somebody has replied.
You will see much about mid-1970s Suburban furnaces if you use the search function on carbon monoxide recall. I suspect you are looking at new. You would need a pretty good set of skills to install it yourself. I would think many would have an RV Tech do the installation. The furnace sizes have been modular through the decades and not changed, though vent, electrical & LP line connections have changed position in all likelihood. You can try to get an idea online at campingworld.com, but you'll have to decide how & who does the replacement.
5 meter Langford Nahanni
Old 02-05-2007, 03:41 PM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
You can get a catalytic heater for your coach. No electricity needed,, no fan, just heat.
Old 02-05-2007, 03:53 PM   #4
Certifiable
mistral blue's Avatar
Yes, what Terry said above. Get rid of the furnace and enjoy all the new storage space and lighter Argosy.
P.S. Are you taking the fiddle to Winterhawk this year?
mistral blue is offline   Reply With Quote
Old 02-07-2007, 08:13 AM   #5
1977 24' Argosy 24
Images: 8
Thanks to all of you! I will check out catalytic heaters. Hope it's not something with risk of fumes? I am scared to sleep with any heater on. Winterhawk? What's that? I am happily ensonced in SW Florida - don't want nuttin' with the word "winter" in it!
Elisa
Old 02-07-2007, 08:32 AM   #6
Well Preserved
1993 21' Sovereign
Originally Posted by Elisa
Thanks to all of you! I will check out catalytic heaters. Hope it's not something with risk of fumes? I am scared to sleep with any heater on. Elisa
No real risk of fumes. I have heated a 5 bedroom house with a pair of them, with no problems. It would probably fit best at the end of your counter by the door, where the fridge is.
Old 02-07-2007, 09:59 AM   #7
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
Like this
this is a 8100 Olympian or you could read the thread. heaters, heaters, heaters. While playing Foggy Mt breakdown.
Name:	86 Excella 093.jpg
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 02-07-2007, 11:21 AM   #8
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
There is a lot of information on the Suburbans if you do a search, and how install and where to get a good deal on replacement. People have used the Suburban NT 30 as a replacement which requires a little bit of adaption.
I have found it impossible to get any work done on mine because of liability/ insurance policies.
There are other less common alternatives. The catalytic heaters seem to work good but require an open window so you don't croak yourself on CO2. There is also hydronic (hot water) and even a propane marine fireplace heater. See the archives.
Any interest in a US (mid west) Argosy salvage / repair yard? Sprouty All Argosy Trailers 3 08-09-2013 08:35 PM
1972 Argosy Exterior Refinish billymyers56 All Argosy Trailers 47 02-04-2013 10:18 PM
My Argosy wants to keep its old furnace DKB_SATX All Argosy Trailers 34 05-11-2012 07:06 AM
My furnace blows... out its own flame godaddy64 Furnaces, Heaters, Fireplaces & Air Conditioning 15 12-13-2011 09:15 PM
Replacing a Duo-Therm Furnace - 1968 Randy Gates 1965 - 1969 Globetrotter 4 05-01-2011 12:30 PM
