Old 07-17-2011, 07:07 AM   #1
Glang227's Avatar
1976 Argosy 26
Lucan , Ontario
Images: 14
'76 26' Shower Valve
I have lost my shower cartridge during my reno and wondered if anyone knows the model of the shower valve. I know they are moen but that's about it. Thanks for your help
Greg
Glang227 is offline   Reply With Quote
Old 07-23-2011, 08:09 AM   #2
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
Your best bet is to look through the catalogs of RV water fittings to find one that will work for you. There are a bunch of these catalogs online so you can see what they look like and what will fit into the space you have behind the shower. I found the biggest problem was connecting the water to the faucet because of the limited space behind the wall of the shower stall.
1966 Airstream Caravel
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Old 07-24-2011, 05:42 AM   #3
Glang227's Avatar
1976 Argosy 26
Lucan , Ontario
Images: 14
I did some digging, the model is "chateau", which isn't available anymore but moen still makes parts that fit. The cartridge is available at Home depot and the handle is too, the only thing I needed was the sleeve which is available from moen, part # 10066. Don't toss your shower valve unless it is damaged from freezing because you can rebuild it and save yourself a lot of work. As far as the space issue goes I soldered in some pex adapters and used 1/2" pex to connect it, worked really well
Greg
1976 26' Argosy
City/water tank check valve gunner Classic Motorhomes 5 10-03-2011 06:49 AM
2008 Airstream Interstate Black Water Dump Valve Installed touching exhaust pipe!! solar-guy Sprinter and B-van Forum 0 05-09-2011 10:54 AM
Removing shower valve in 74 Argosy 24' twilder Sinks, Showers & Toilets 2 04-02-2011 08:28 PM
1981 Excella II shower valve noreen&sal Sinks, Showers & Toilets 2 03-06-2011 08:06 AM
