Old 05-25-2005, 01:47 PM   #1
mkeith54's Avatar
1976 26' Argosy 26
New Florence , Missouri
Send a message via AIM to mkeith54 Send a message via Yahoo to mkeith54
Post 75 24' updates
Well we broke down and started upgrading the major appliances in our trailer. Last week we had a new Carrier 13,500BTU A/C and a new Atwood water heater.
The A/C has posed a couple problems that I have yet to work out. First off the inside unit is not curved to fit the ceiling, so when the unit is tightened up the cover no longer fits correctly. The fix appears to be to add curved spacers to the inner unit and the cover to match the roof line. After our first trip this weekend I'll start working the issue.
The water heater was a direct replacement, the unit was a tighter fit due to the rigid styrofoam insulation. All in All things went very smooth.
This Friday we take off for Pittsburgh, PA, tis is our first trip out in a year an a half as I have been dealing with cancer and am just now feeling up to tackling a trip. We are also planning on attending the International this year for the first time.
Mike Keith
75 Argosy 26'
96 Ford F-250 PowerStroke
mkeith54 is offline   Reply With Quote
Old 05-25-2005, 05:00 PM   #2
maxandgeorgia's Avatar
1995 30' Limited
Ashland , Missouri
Sounds like you are getting busy making that Argosy a 21st Century Baby! I bet you find out just what you need to know for the AC from this group. How wonderful that after the health struggle you've been through that new strength and, with it, travel time are here again for you. Carry the warm thoughts and prayers of the forum with you this weekend Happy camping!
maxandgeorgia
1995 Airstream Classic Limited 30' ~ Gypsy
1978 Argosy Minuet, 6.0~Minnie/GPZWGN
Chev Silverado 2500HD Duramax/Allison, 4X4, Crew Cab
WBCCI #5013 AIR #2908
WDCU
Go, Mizzou...Tigers on the prowl!
maxandgeorgia is offline   Reply With Quote
Old 05-25-2005, 06:01 PM   #3
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Happy Camping, sounds like your in need of a get away!
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 05-25-2005, 08:01 PM   #4
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
I have a 78 24' Argosy that I am doing cosmetic renovation on. It seems the more you do the more you want to do. Haven't started on the appliances yet but that's probably because they still work very well. Gee, does that mean I'm cheap? Have been staining the wood to match the new floor we are going to install "someday". Don't ever stain unless you have no other choice. Replaced the end pieces in the kitchen with new hand made and vinyl covered ones. Learn as you go is the word.
ID:	12404   Click image for larger version
juel is offline   Reply With Quote
Old 05-31-2005, 03:10 PM   #5
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Put water to the Argosy today. Someone did not do a good job with winterizing the Hot water heater. Looked more like a lawn sprinkler
Looks like I'll be searching for a replacement.....
New water line pieced in, (replaced radiator hose) found another section that needs to be replaced under the galley sink as well. The good news? No leaks in the bathroom!!!
ID:	12549   Click image for larger version
www.balrgn.com
Old 06-01-2005, 04:16 PM   #6
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Working the floors
Plugged the Lines to the water heater till a new one is located and installed.
I was amazed that there are no leaks in the lines!!
Started with the floor, check out the progress @ http://www.balrgn.com/Argosy/Argosy.htm
www.balrgn.com
Old 06-04-2005, 07:59 PM   #7
mkeith54's Avatar
1976 26' Argosy 26
Water heater
The Good news for you is the Atwood fits in perfect and the one we got makes hot water faster and uses less fuel than the old one.
Mike
Mike Keith
75 Argosy 26'
We finally got it! cosmotini 2002 - 2005 International 32 12-18-2004 01:36 PM
What's the value? pillageTHENburn General Motorhome Topics 62 09-29-2004 07:26 PM
Baby Pix - 2004 Classic Big Dee 2001 - 2005 Classic 39 02-12-2004 07:09 AM
Organization Experts Needed! Andy R Forum Admin, News and Member Account Info 7 04-10-2003 07:53 PM
