Old 06-10-2016, 12:02 AM   #1
TrvlnRN's Avatar
1974 Argosy 22
Dallas , Texas
'74 Argosy missing interior KT lock?
In the process of working on my '74 Argosy 22 and realized I don't have a way to lock the foot from the inside. There isn't a deadbolt or any other mechanism to lock the outer door from the inside and the screen door latch can be easily pushed open. Is there a simple repair for this or will I have to replace the entire KT lock?
TrvlnRN is offline   Reply With Quote
Old 06-10-2016, 05:01 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The little threaded lock knob is available as a separate part. Many Airstrewam dealers carry those parts, just check websites or make a couple of phone calls.
Old 06-10-2016, 10:14 AM   #3
fluxcap's Avatar
1977 Argosy Minuet 6.0 Metre
Newnan , Georgia
Yep, Vts has one and I'm sure others sell them as well. http://www.vintagetrailersupply.com/...p/vts-1002.htm
Seems kind of pricey for basically just a small bolt. Could probably find something at the hardware store for $.50.
fluxcap is offline   Reply With Quote
Old 06-10-2016, 04:48 PM   #4
Well Preserved
1993 21' Sovereign
It's what is called a shoulder bolt. A regular bolt is the same diameter from end to end, a shoulder bolt has a larger diameter beyond the threaded area, so it will tighten.
Old 06-11-2016, 03:28 AM   #5
1978 Argosy Minuet 6.7 Metre
1971 27' Overlander
1973 31' Sovereign
Griffin , Georgia
Images: 14
I'm currently restoring my 8th 1970s Airstream and they have all had the KT lock. Most of them have been missing the locking pin for some reason.
I've tried a lot of screws and hardware, but have found that it's worth it to bite the bullet (or screw) and buy the right pin.
Vintagetrailersupply.com has it for $35 dollars..
paddle whisp is offline   Reply With Quote
Old 06-11-2016, 10:50 AM   #6
1977 31' Sovereign
Lynnwood , Washington
I've got a round head machine screw in mine; something like an 8-32 X 1" or 1-1/2". It might be a 6-32. I can't really tell.
Tom
TomKirk is offline   Reply With Quote
Missing title, missing VIN in Texas. kristinatx Title, VIN & Registration 33 02-22-2016 08:54 AM
Door Lock Loose interior Lock Pin.. Bootsinister Doors & Locks 12 10-08-2012 10:19 AM
HELP, I'm Spinning with no control....Key spins in lock...what's missing??? WILDRTEXAS Doors & Locks 15 09-13-2009 03:58 PM
1974 missing lock assy, workaround option?? j_c_c Doors & Locks 0 08-04-2009 06:56 PM
Missing Key for Potable Water Lock Door Streamer1 Doors & Locks 16 03-25-2007 08:00 PM
