Old 01-24-2014, 05:41 PM   #1
heslinhotel's Avatar
1989 29' Excella
1974 Argosy 26
1999 25' Safari
Youngsville , North Carolina
'74 Argosy 26'
Just bought 74 Argosy 26. The paint scheme is one I have not seen before. Does anyone know what paint schemes were available in 1974?
Thanks Steve
heslinhotel is offline   Reply With Quote
Old 01-24-2014, 07:34 PM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
I think all the '74s came from the factory in "Colonial White" with contrasting color lower wraps to the belly pan and the orange plastic belt-line trim.
— David
Old 01-24-2014, 10:28 PM   #3
1974 Argosy 20
Kooskia , Idaho
What DKB_SATX said I believe is the only original color scheme. My '74 20' Argosy has a slightly off white upper and a tanish lower. I have repainted the upper, but believe the lower is original (and needs repainting now). I put Airstream Blue plastic belt line trim on it and think it looks good. I painted my banana wraps, tongue, and rear compartment a dark metalic gray which is not original but sets things off nicely.
Old 01-24-2014, 11:01 PM   #4
Loomis , California
If you want to go back to the original color scheme, I found the paint codes in the Airstream on-line library. However, they only start with the '75 color schemes. That said, it is the same one that is seen on all the others. The library lists the Argosy Travel Trailer color schemes for 1975-1978 as:
Upper...Dupont Centari, 44534-A, Light Beige
Lower...Dupont Centari, 44721-AM, Metalic Brown
If you give these numbers to your supplier, they should be able to mix an accurate color for you.
Aldo is offline   Reply With Quote
Old 01-25-2014, 04:58 AM   #5
1989 29' Excella
1974 Argosy 26
1999 25' Safari
Paint
Thanks to all, I had a feeling the paint job was a little too complicated for a factory finish. I will try an post a pic.
Old 01-25-2014, 06:01 AM   #6
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
Cool!!!
Skatiero is offline   Reply With Quote
Old 01-25-2014, 08:49 AM   #7
DKB_SATX's Avatar
1976 Argosy 28
That is definitely some '70s stripe work! I wonder if they pulled it with a van with matching stripes...
— David
Old 01-26-2014, 07:38 AM   #8
1989 29' Excella
1974 Argosy 26
1999 25' Safari
I just got a picture in my mind of BA Baracus from the A-Team in his Van
Steve
Old 01-26-2014, 08:33 AM   #9
VtTim's Avatar
Santa Fe , New Mexico
That's a pretty awesome paint job. I'd trade it for my pale cream color any day.
VtTim is offline   Reply With Quote
Old 01-26-2014, 11:20 AM   #10
cincinnati , Ohio
That is one groovy paint job.
Does it make your TV go faster?
RhinoWW is offline   Reply With Quote
Looking for an owners manual for 1976 Argosy 24' btophek All Argosy Trailers 25 08-25-2018 01:46 PM
Any interest in a US (mid west) Argosy salvage / repair yard? Sprouty All Argosy Trailers 3 08-09-2013 07:35 PM
Looking at 24 ft. Argosy crunch27 Member Introductions 6 06-09-2013 07:46 PM
1972 Argosy Exterior Refinish billymyers56 All Argosy Trailers 47 02-04-2013 09:18 PM
1973 Argosy / Airstream Camper - $4100 (Newark) 61Ambassador Airstreams on eBay 4 02-13-2011 11:11 AM
