Old 07-22-2014, 02:32 PM   #15
Savage68's Avatar
1974 Argosy 22
Hamilton , Montana
Taking the trailer end backshell apart was worth the effort. The wires are very heavy duty and as such are difficult to work.
There were several "whiskers", stray strands that were in danger of shorting or breaking off.
I cut back for fresh wire, crimped spade connectors on minus the plastic covers, which I removed.
Reinstalled the wires per the correct color scheme and voila, it works.
Savage68 is offline   Reply With Quote
Old 08-09-2014, 04:10 PM   #16
1978 31' Excella 500
SOUTH ANHERST , Ohio
7 way plug
Need help I put a new plug 7 way on the 1975 Argosy -- followed the diagram as posted and all was working.
shut down the truck and went back to see how my new tail lamp was working and now my lights will only run my left turn .
Were did I go wrong??? All was working never touched the plug any ideas??
Need help what happen all was working just fine and this,
please help will wait to hear.
Gosman is offline   Reply With Quote
Old 08-09-2014, 04:33 PM   #17
arktos55343's Avatar
1972 25' Tradewind
Hopkins , Minnesota
Perhaps your 7 pin wiring is not compatible with your tow vehicle plug. Use a 12v tester to map and test the connections on the tow vehicle...then you will know if you wired the 7 pin correctly.
arktos55343 is offline   Reply With Quote
Old 08-09-2014, 05:28 PM   #18
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Does everything work right when you start the truck?
Old 08-09-2014, 05:41 PM   #19
1976 31' Sovereign
Oswego , Illinois
AS in 70s did not use standard wiring in 7 pin plug that is standard for vehicles. Sounds like you used diagram that came with new plug, if so many of us have correct wiring for plug.
Old 08-10-2014, 06:54 AM   #20
Yes once I put all the wires in the new 7 way plug and put it to the truck every thing worked perfect.
Went back some time later to see it lite at night did not work ; think I now have a blown fuse in my truck.
were did I go wrong in this hook up? ???? Need help work perfect once and now fuse blown
Help please
Old 08-10-2014, 07:04 AM   #21
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
You should check the wiring in the 7 way plug for hairs shorting between the ground/common terminal and others. While you are there, check to make sure all connections are correct.
As mentioned above. Older coaches were not wired to today's standards. You can use a battery charger to check each circuit while you have the coach unplugged from the TV.
Water pump wiring and proper wiring Supertwin1 Water Heaters, Filters & Pumps 8 05-23-2014 07:05 AM
1965 Safari hitch wiring cut off Eholland Towing, Tow Vehicles & Hitches 6 10-06-2012 05:47 PM
Hitch wiring QuickDraw Hitches, Couplers & Balls 1 10-24-2010 12:30 PM
hitch wiring question Craig Lights - Interior & Exterior 4 07-18-2004 06:09 AM
Is House Wiring the same as Automotive Wiring? swebster Mechanics Corner - Engines, Transmission & More... 7 06-15-2004 06:11 AM
