Old 06-21-2011, 05:57 PM   #1
VonLuck's Avatar
1973 Argosy 26
Burbank , California
'73 Argosy black tank gallons?
how many gallons is my black tank and how in the heck do I know when its getting full?
VonLuck is offline   Reply With Quote
Old 06-21-2011, 06:32 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
It's less than 20 gallons (more like 15), and you know it's full by looking into the hole when you open the valve on the toilet.
Old 06-21-2011, 07:42 PM   #3
VonLuck's Avatar
1973 Argosy 26
I thought it would be more for some reason.. How big is my water tank? About the same?
Old 06-21-2011, 07:58 PM   #4
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
According to Airstream's data from back in the day, it's 12 gallons of black (main), 10 gallons of gray (auxiliary.) And 30 gallons of fresh water! I don't know what they expected you to do with the other 8 gallons.
http://service.airstream.com/files/l...e7c0f6c7fc.pdf
David
Old 06-21-2011, 08:14 PM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Capacities
My '74 Argosy has a 12 gallon black and a 10 gallon grey. I'll bet yours is the same.
Old 06-21-2011, 08:19 PM   #6
Well Preserved
1993 21' Sovereign
'74 was the first year for grey tanks. So, unless yours was retrofitted, you only have the black tank.
Old 06-21-2011, 08:21 PM   #7
Well Preserved
1993 21' Sovereign
6 gallons would go in the water heater, leaving only 2 gallons unaccounted for. That would probably stay in the fresh water tank, so the pump didn't run dry.
Old 06-21-2011, 08:25 PM   #8
DKB_SATX's Avatar
1976 Argosy 28
I *thought* '73s didn't have gray, but that PDF I linked to was under '73 Argosy on Airstream's site. I wonder if they just scanned a manual from the wrong year. It lists the same size tanks as my '75 so it seemed realistic enough, and they did some other things first on Argosy trailers (like panorama windows) I thought maybe they started earlier with gray tanks too.
David
Old 06-21-2011, 08:59 PM   #9
VonLuck's Avatar
1973 Argosy 26
Well I dont think i have a grey tank but what the heck do I know. Where would the drain be if i had one?
Old 06-21-2011, 09:04 PM   #10
DKB_SATX's Avatar
1976 Argosy 28
The drain would be the same, but there'd be an extra valve. My 75's black dump handle is inside the bumper locker, and the gray dump handle is on the street side a little forward of the drain.
David
Old 06-22-2011, 04:20 AM   #11
mnmhays's Avatar
1973 Argosy 26
1966 30' Sovereign
Southern , Wisconsin
No gray tank in '73. 15 gallons in the black tank and 30 gallons of FW
All that is gold does not always glitter...those who wander not always are lost....
mnmhays is offline   Reply With Quote
Old 06-22-2011, 07:29 AM   #12
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I don't believe it was AS's intend to size the black and grey water tanks to hold all of the water in the fresh water tank. They simply put tanks in that would fit in the space allocated along with the weight consideration.
One really can't count the 6 gallons in the water heater since the only way to get it ( the 6 gallons) out once it is filled, is to drain it. Most people fill the water heater along with filling the fresh water tank so that both are at max capacity.
Old 06-22-2011, 06:07 PM   #13
VonLuck's Avatar
1973 Argosy 26
Ok my black tank dump gullitine is leaking. Does that mean I gotta take it all apart? Oh yeah no grey tank for sure..
Old 06-22-2011, 07:33 PM   #14
Well Preserved
1993 21' Sovereign
I'm afraid so. Depending on how it was done, either a new valve or a rebuild kit is in your future. If nothing has been glued to the valve, it's a LOT better to replace.
Black Tank Stench --HELP! Blu_Hwy_Lady Waste Systems, Tanks & Totes 17 07-26-2012 12:29 AM
Need Black Tank Information! Janie Q Waste Systems, Tanks & Totes 6 06-07-2011 03:40 PM
No black tank in 62 Tradewind tlsmit1 Waste Systems, Tanks & Totes 1 05-15-2011 04:53 PM
mounting toilet flange on black tank 386kustoms Sinks, Showers & Toilets 3 03-04-2011 07:52 AM
'69 Globetrotter, Black tank for streetside bath dieselpup Waste Systems, Tanks & Totes 9 03-03-2011 06:50 AM
