Old 02-04-2007, 04:30 AM   #1
MotorSeven's Avatar
Thorn Hill , Tennessee
'73 Argosy 20.....Bought!
I'll start a new thread on this. Well we drove down and looked at the 20 footer described as "excellent". This is a term subject to interpretation. What we found was a mostly orignal interior, a sound but painted(poorly) exterior....
The good:
light rust on the toungue and bumper
belly pan intact with 20% rivets corroded thru
roof in very good condition
new Coleman Mac last year
axl still has life left...approx 3-4 inches between rim and fender well
good tires
floor solid
water tank intact
newer water pump working
black/grey intact
all windows/screens intact and working(only one locking mech snapped off)
bathroom intact
cushions all there but covered with scary colored materials
all doors,closets,drawers intact and in good condition
new(er) drapes
countertop good
front door/screendoor good
12/110 converter working
lights all working inside and outside(even the tag light)
original awning works and in decent condition!
no rear floor separation/frame straight
very few mildew spots on ceiling/walls
smells........ooohkay for a 34yr old unit
The bad:
fridge not working/interior very good, exterior frame rusted alot
stove door broken on one hinge, other hinge frozen in closed position
furnace does not work/ no fluid in radiatior, lots of rust
water heater rusty, would not fire...kinda scared to try
original propane bottles replaced with newer opd's(good&bad)
plumbing fixtures all need replacing
window seals eventually will need replacement
exterior has several minor dings and scratches(one 10" easy dent), but the worst is a crappy paint job that looked to have been poorley prepped.........
no rock guards
toilet slightly leaking at top when flushing
brakes had no signal to controller(could be the corroded plug)
bathroom/kitchen original 12v lights replaced w/ fluros
missing the hitch and arms for the load leveler system
leaking knife valve on grey/black tank(at leat i hope that is the prob)
battery condition unk, compartment door locked...no key
Soooo, i know i know, what was the price? Well it started a 5k, and after alot of negotiations we settled at $3,250. It was more that i wanted to pay, but it was "here" and there is nothing on it that i don't think i can fix. Towed like a dream behind a full size chevy p/u. Got it home and tossed out the carpet and pulled up the original vinyl. Pulled off the sofa cover(canary yellow) and, viola.....original un-molested sofa ! Didn't get so lucky with the dinette....took off the(King Arthur maroon paisley drapery pattern) covers and found foam in ok shape.
Turns out that there was zero propane in the bottles, so i will clean up the fridge & water heater and try and fire them up. I think the furnace is toast(ha), and the stove questionable. The skylight w/fan looks original, but it would not open(stuck) and the fan did not come on. Toilet gets a re-build.
We are going to get the interion done first, then do the exterior later, because we are retiring and moving to TN next month and will live in the 20 footer while we build an apt in a steel building, which we will live in while we build a log home, which......... . Anyway, after those projects get done, the exterior will get stripped and painted. We plan on dragging the Argosy back and forth to Manitoba quite a bit.
OK...where is the switch for the vent hood?????? My wife and i looked all over and gave up....
I'll shoot some pic's today before too much work gets done and post'em later.
Ahhh, the smell of bleach in the air.......................
RD
MotorSeven is offline   Reply With Quote
Old 02-04-2007, 07:03 AM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
As a former Argosy 20 owner, I can probably help you with some of these issues.
Your switch for your stove vent should be inside the cabinet over the stove, an is a combination lever for the vent and switch for the fan.
Our Argosy axle had plenty of space over the tire, but was frozen in place. We had to replace it, pretty easy to do.
Your furnace may be one of the "recall units". Look for cracked rubber inlet and outlet hoses between the furnace and the side of the trailer.
Old 02-04-2007, 08:19 PM   #3
MotorSeven's Avatar
Ok Overlander, i'll check 2morrow and see.......thanks, and a warning, i may have a few more q's soon . The fender/wheel spacing looks like this.....
RD
Name:	'73 Argosy 20 016 (Small).jpg
Old 02-04-2007, 08:27 PM   #4
MotorSeven's Avatar
Pic's......
As promised.....
Name:	'73 Argosy 20 005 (Small).jpg
ID:	31842   Click image for larger version
Name:	'73 Argosy 20 002 (Small).jpg
Name:	'73 Argosy 20 007 (Small).jpg
Old 02-04-2007, 08:31 PM   #5
MotorSeven's Avatar
More pic's
vinyl floor is on the way up and out........
Name:	'73 Argosy 20 008 (Small).jpg
ID:	31845   Click image for larger version
Name:	'73 Argosy 20 010 (Small).jpg
ID:	31847   Click image for larger version
Name:	'73 Argosy 20 015 (Small).jpg
Old 02-04-2007, 08:57 PM   #6
str8strm's Avatar
1985 34.5' Airstream 345
Tujunga , California
Looks like a fun project. Keep us posted.
Ron and Debbie Lawrence
1985 345 Motorhome...... delightfully tacky......yet unrefined
AIR 7992
str8strm is offline   Reply With Quote
Old 02-06-2007, 07:58 AM   #7
MotorSeven's Avatar
Stove vent...
Terry,
So it has a switch to turn the fan on when the damper is opened....hmmm, i have nothing, so i'll check it for power.
Does the roof vent have a cut out switch also? Vent lid is stuck, fan does not come on...all look original.
Furnace recall? Yep, the gasket is very cracked. I did get the Surburban to fire up, but i don't think i could sleep worring about that old thing. I may just pull it out and use a Mr.Buddie when dry camping, and a ceramic when on shore power.
I'm hunting parts for the avocado green Magic Chef stove door/hinge/spring. Door is off on one side and stuck on the other, so i'll pull it out today. Other than that it is in pretty good shape.
I fired up the water heater, and was grinning, while it ran....then..."Boof", water everywhere in the bathroom. Turns out the thermostat didn't tell the burner to shut off...expanding scalding water can really blow a flex line! Someone had cut the copper HW line DIRECTLY UNDER THE CONVERTER , and used flex line & hose clamps to go on to the sink. When i found this i just looked at it and thought, "You gotta be kidding me"..........
Any tricks to get the discoloration/stains out of the plactic bathroom sink/surround?
That's it for now....
RD
Old 02-06-2007, 08:25 AM   #8
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Bathtub Refinisher
Originally Posted by MotorSeven
Terry,
RD
Look up "Bathtub Refinishing" in your yellow pages. You can have your sink, shower/tub, toilet all redone and they'll be boooootiful!
Paula
Foiled Again is online now   Reply With Quote
Old 02-06-2007, 08:33 AM   #9
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
RD, I may be able to help you with parts for the stove. I have one that I picked up for parts. It has already given up the stainless steel cover to Juels' Argosy and a burner went to Sequiacoasts' stove. But every thing else is still on it. The oven door is stainless but you can change out the front panels on these ovens very easily. The hinges are in great shape (very little rust) and operate great! the top burner area is in great shape except for the one missing burner the stovetop is stainless with very lite rust and should clean up fine if you want to change the look of your unit. Knobs are fair to good condition. The interior of the oven looks very clean for a '68 trailer it came from. Let me know if you are interested in anything and I will see what I can do for you. Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 02-06-2007, 09:03 AM   #10
sequoiacoast's Avatar
1968 24' Tradewind
Eureka , California
My stove was easy to fix. I also had a hinge that came off the spring, or more accurately the spring had rusted.... When you take the small doors off the side you'll see what I mean.
I have the stove in the classifieds.. too bad we're so far away!
I love the wrap around windows, it looks like a great project!!
sequoiacoast is offline   Reply With Quote
Old 02-06-2007, 09:47 AM   #11
mandolindave's Avatar
Welcome RD, I am a 73/20 Argosy owner
My advice is to think about a new fridge. My 73 era fridge was oozing amonia gas.
I would check the toilet for the water problem. It is hard to get all the water out of the valve and it freezes and breaks during the winter months.
.......................MD
mandolindave is offline   Reply With Quote
Old 02-06-2007, 10:11 AM   #12
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Nice lookin rig, check out my pages for a few hints and ho to's
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 02-06-2007, 08:29 PM   #13
MotorSeven's Avatar
Ok,
The fridge is working very well on 110v. I took the door off and wire brushed the face frame behind the door that was really rusted. It's primed and will get painted 2morrow. I'll check it on propane also.
Hosed down the water heater thermostast connections with WD-40 and it is working correctly.
Thanks for the stove parts "offers' but i broke 3 bits tryng to get the side panels off. The thing is so rusty there is a hole thru from the bottom, so it is going to get deep sixed. I had an idea....what about a 3 burner cook top, with a microwave below??? Cook tops are alot cheaper and we need a micro, but with the limited counter space this may be the way to go.....who really uses an oven while camping???
If anyone needs some '72 Magic Chef stove parts let me know, i'll send them for the cost of shipping.
I'm painting tha inside of the front cap(abs). Home Desperate & Lowes don't carry Krylon(i know that they used too) Fusion. I used a Valspar brand(Lowes) of plastic paint, and i'm not too impressed. The nozzel shoots it out in a spot pattern, instead of a fan pattern, so the finish is spotty. I will try the Rustolem brand(Home Desperate) next, becaue i picked some up tonight.
I'll update some pic's soon........
RD
Old 02-06-2007, 08:48 PM   #14
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
Ok,
RD
That's what I'm going to. I've got my micro in a cupboard right now and we use the oven for storage. This spring I'll punt the stove/oven combo and put a sunken counter top 3 burner in and move the micro below it. There was a thread recently about how many used their oven, though, and it was amazing how many do. We do the majority of our cooking on a portable stainless BBQ set up under the awning and seldom use the stove top. When roughing it the BBQ works fine for a faux oven. For us and our type of cooking at least.
Barry
safari57 is offline   Reply With Quote
Argosy Motorhome Manual & Brochures WANTED Rik Argosy Motorhomes 35 02-27-2019 07:29 PM
Stripping an Argosy CHRIS CANNON Cleaning, Stripping & Polishing 8 05-11-2017 04:42 PM
I just bought a '76 28' Argosy MH!!!! Mr.Motorhome Argosy Motorhomes 3 05-17-2004 09:02 PM
New Argosy owner! barbwire All Argosy Trailers 33 04-15-2003 07:14 PM
