Old 08-11-2008, 04:27 PM   #1
martinez , California
6.7 meter Argosy weight
Hi,
I have a 1978 6.7 meter Argosy I bought in Roseburg OR last year. According to Airstream with the trailer empty, and with no water on board the hitch weight should be about 310 Lbs. and the trailer weight should be around 3000 lbs. When I took the trailer to a certified scale it weighed at 3780 Lbs., and my Sherline scale weighed the hitch at 600 Lbs. Airstream has no idea how my hitch can have 600 Lbs. on it, unless that's where D.B. Cooper stashed his money. Anybody have any ideas or weights on their Argosy's. I need to find and get rid of the extra weight as unloaded I'm already close to the max GVWR.
Uncle Jack
Uncle Jack is offline   Reply With Quote
Old 08-11-2008, 07:00 PM   #2
Usually Sleepy
biggoofball's Avatar
East Haven , Connecticut
Images: 14
not knowing your trailer, I can only throw some questions out there:
Has it been renovated? New wood floors? New Plywood that is perhaps is too thick? Marble flooring? Granite counter tops? Concrete filled Frame? Microwave? Washer? dryer? Big screen TV? I jest of course. But in a 30 yr old trailer anything can happen.
biggoofball is offline   Reply With Quote
Old 08-11-2008, 07:53 PM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Uncle Jack!
The published empty weight for the Minuet 6.7 Metre is 2,725 pounds with an empty hitch weight of 280 pounds. These weights do not include LP Gas, water in the water tank, nor the weight of any options such as awning(s), air conditioner, larger LP tanks, entertainment center, television antenna, etc.
I would expect a typical ready to travel weight slightly in excess of 3,250 pounds with a hitch weight approaching 600 pounds with a full water tank and full LP tanks.
My 6.0 Metre Minuet typically runs close to 3,100 pounds ready to travel with a bit more than 550 pounds on the hitch.
The figures that you have point to either a standard 22 foot Argosy or a Minuet that has seen significant modification. Does your coach have a single or tandem axle? -- I am wondering if it might be a 7.3 Metre or 24' given the weights (7.3 Metre has an empty weigh ot 3,820 pounds with an empty hitch weight of 510 pounds). If your coach is totally empty, it must have seen some modification. A standard Minuet will have vinyl-clad aluminum cabinetry throughout with plastic laminate tambour for the upper locker doors as well as the under-sink cabinet doors. The only floor covering originally available from the factory was carpeting in a short-shag length. A 6.7 Metre Minuet may have either plywood sub-floor of aluminum composite sub-floor (most appear to have plywood).
Kevin
Kevin D. Allen
AIR #827
How to ship a Argosy?Loaded weight of a 22' Argosy outerbanksdeb Shipping & Export/Import 18 12-17-2011 10:53 PM
Total Weight & Tongue weight of 24' Argosy woody_strohm Our Community 3 12-21-2008 10:25 PM
6 Meter Argosy on ebay Argonaut20 All Argosy Trailers 4 08-03-2007 08:08 PM
Value of a 6 meter Argosy? Ultradog All Argosy Trailers 9 06-27-2006 09:24 AM
77 Argosy weight cdholt All Argosy Trailers 2 09-11-2003 03:29 PM
