Old 10-09-2009, 07:06 AM   #1
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
50 AMP question
A brief question:
Does the 50 amp plug on an RV
carry 240 volts?
kennethowens is offline   Reply With Quote
Old 10-09-2009, 07:16 AM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Simply put Yes. Take a look here for more information. http://www.myrv.us/Imgs/PDF/50-amp%20Service.pdf
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 10-09-2009, 07:25 AM   #3
1975 Argosy 24
Malakoff , Texas
Are you sure?
Question two:
Does the power supply at RV parks
provide 240 volts to the 50 amp plug?
Old 10-09-2009, 07:51 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
Originally Posted by kennethowens View Post
Are you sure?
Question two:
The National Electric Code governs the application of each electric plug configuration. A 50 amp 240 volt plug will have that voltage on it at the point where it is plugged in.
Now having said that that does not mean that 240 volts will be used on any application inside the trailer. At the panel there will be two 120 volt legs with each leg feeding say 1/2 of the fixtures in the traielr and the other leg feeding the other 1/2.
The only fixtures that would benefit from 240 volts are those that generally require higher power. These include AC, hot water heater, and cloths dryer. Those rigs that come from the factory with a 50 amp supply, if designed correctly will have these fixtures wired for 240 volts.
2004 Excursion 4x4
Old 10-09-2009, 07:58 AM   #5
Grumpycamper's Avatar
2005 16' International CCD
Wimberley , Texas
By no means an expert so pardon the terminology. A 50 amp plug is a 240 volt plug. The four posts are Ground, common, and two 120 volt legs.
Avatar 1954 13' Airlight
Grumpycamper is offline   Reply With Quote
Old 10-09-2009, 08:05 AM   #6
1967 22' Safari
1960 Caravel
Images: 8
Are you sure?
Yes! What HowieE and Grumpycamper said.
Question two:
If an RV park has a 50 amp service plug then there should be the potential of 240 VAC from that plug. That said you should always check the output to make sure your getting the proper voltage.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 10-09-2009, 09:07 AM   #7
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
So it's still OK to use my 50x30 (50a shore receptacle x 30a trailer plug) dogbone when I connect at a campground?
Pat
pmclemore is offline   Reply With Quote
Old 10-09-2009, 09:13 AM   #8
HowieE's Avatar
Images: 12
Pat
If your dog bone was commercially manufactured it should adhear to the codes.
If you made it and only picked up one leg of the 240 system and connected the neutral and ground in the right configuration again you are OK.
2004 Excursion 4x4
Old 10-09-2009, 09:31 AM   #9
1975 Argosy 24
Malakoff , Texas
Thank you for your kind assistance.
Old 10-09-2009, 10:41 AM   #10
banjobill
wmarsha's Avatar
2000 30' Limited
battle ground, , Washington
240VAC is just two legs of 120VAC
If you look up at a utility pole, at the very top, there are usually 3 wires separated by a distance and insulated from the pole. These are the 3 phases of 60 hertz(cycles) electricity that the utility generates. Combinations of those 3 phases result in the various voltage schemes used in commercial, and residential grids. I am ignoring the higher voltages, and industrial applications in this statement.
Most residential applications today use a 240VAC 200 amp SINGLE PHASE service drop from the utility. Most RV's today use either a 240VAC 50 amp service or a 120VAC 30 amp service, again, single phase.
The difference in voltage is acquired thusly: a single phase of power is connected to a step-down transformer; 2 "legs" of 120v AC are created within the transformer and can be combined to get 240VAC. This voltage measurement is made between the "hot" spades of a female connector. If you measure the voltage between each of the "hot" leads to the neutral, you will see a reading of 120VAC. Now, on the 120VAC, obviously there is only one way to get a voltage reading-hot to neutral, which will read 120VAC.
You can get voltage readings between the hot and the grounding conductor-but doing so may cause GFCI's (ground fault circuit interrupters) to operate-as they are supposed to operate when current is sensed on the grounding conductor.
Going back to the 3 wires on the utility pole. They represent the generated power-most generators have armatures divided into segment multiples of 3. This is where 3 phase power comes from-and this is an entirely different beast than what we are discussing here. The utility's neutral is NOT up on top-but rather down the pole about three feet or so-communications wiring (telephone, cable TV) should be below this neutral. Oh, and as an aside, the utility neutral is usually earth grounded on every other pole.
For best Electrical protection and operation, the RV's grounding conductor(s) should not be connected to the RV's neutral. Older RV's (and residences, too) combined the neutral conductors and grounding conductors on the same neutral connector bar. If you wish to upgrade your electrical system, this would be one place to start; separate these two types of conductors and place them on separate connctor bars. ALWAYS de-energize the system you are working on.
wmarsha is offline   Reply With Quote
20 Amp or 30 Amp, that's the question Jim & Susan Electrical - Systems, Generators, Batteries & Solar 60 05-28-2010 01:37 PM
Question about sand & polish ABS Plastic bmklawt Cabinets, Counter Tops & Furnishings 32 03-22-2010 07:20 PM
New Guy & '78 Ambassador Question height General Repair Forum 7 08-26-2009 02:23 PM
30 / 50 AMP Question kleimanr Electrical - Systems, Generators, Batteries & Solar 7 11-03-2007 02:58 PM
Dumb Question regarding the bed & sheets kamadeca 2003 Safari 8 06-23-2003 02:24 PM
