Old 07-26-2005, 06:59 PM   #15
ArgosyRover's Avatar
OK, here are some pictures,
The root of the problem
Under the gaucho
The streetside, showing the pump. I imagine the pump originaly went under the gaucho but the PO made a little box aft to house it, one of my projects it to put that right.
This little junction box in the bathroom closet houses the polarity light next to the battary box.
I havn't opened it, but can't imagine the trailer light wiring is in here.
Hopefull these are of some help.
Peter
ArgosyRover is offline   Reply With Quote
Old 07-26-2005, 07:20 PM   #16
I do know that on some of the older Argosys they did not use the standard wiring block that most of us are used to seeing in the more popular mid-1970's Argosys.
You will be able to find it along the street side on the inside of the trailer.
If it is not there, then it may very well be further back.
At any rate, you should be able to follow the cable up into the trailer and follow it. That is something an old GM Electrician taught me; "If a cable starts somewhere, it has to end somewhere".
Keep in mind that your trailer is over 30 years old and has probably seen a lot of "repairs" over the years. Sometimes they are improvements and other times they are done without much thought or common sense.
Anon is offline   Reply With Quote
Old 07-26-2005, 07:28 PM   #17
Yikes I see my pictures didn't come through
Here they are as attachments
Under the gaucho
Ithought I could be clever and add the images in-line after uploading them as attachments, then deleting them from the attachments.
The forum software also deleted the images from the server but I saw them because they were in my cache.
Peter
ID:	13555   Click image for larger version
ID:	13557   Click image for larger version
Old 07-26-2005, 07:38 PM   #18
I guess I'll keep digging, but I can't follow the wires from the A frame, they disappear when the frame changes from a channel to a box section underneath the LPG tanks.
Perhaps this is a modification, are they normally C section all the way?
I'll have to see what I can do with the belly pan.
Thanks for all your help everybody. A great first post experience!
I run a Land Rover forum and I really like this one, I'm tempted to use this software.
Peter
Old 07-26-2005, 07:51 PM   #19
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Originally Posted by ArgosyRover
Peter
I don't think that the frame changes are a prior owner modification, my 1979 Safari has a boxed tongue and a c channel frame, my 1954 Liner has a c channel tongue and frame.
Bill
Just my personal opinion
Old 07-26-2005, 08:28 PM   #20
Frames usually do not change.
The owner modification I was referring to is with the electrical from the TV plug not the frame.
Old 07-26-2005, 09:14 PM   #21
Round on both ends
SafeHarbor's Avatar
1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
Hi, Peter,
On my '75 Argosy 28, the hitch cable comes up under the gaucho on the left-hand side and goes under the left-hand side wrap interior wall. You have to remove the front center wall panel inside to see it. Is that what you've already done?
Lamar
SafeHarbor is offline   Reply With Quote
Old 07-26-2005, 09:28 PM   #22
greg176's Avatar
Gabriola Island , British Columbia
The second photo you posted looks promising.Is that not the wiring on the left side above the water tank? My 61 had a hole drilled in the bottom of the wall and the wires came to a junction box about there.Note too that the brake wires will go down through the frame channel and not into the coach.May need to peek under the belly pan.
greg176 is offline   Reply With Quote
Old 07-26-2005, 10:36 PM   #23
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
hmm
Your 24 sounds very simular to my 26 (front dinette, mid twins, rear bath). Our pump is streetside too, with the tank across the front.
I'm in the same boat, starting to have electrical feed problems (from the tow van), I've been tracing what I can see of the wires.,... no junction box noted in the trailer (and I've had it almost all apart recently for my replumbing job).
I'd look in the belly pan streetside by the front (best guess!)
Good luck!
Marc
Old 07-27-2005, 07:41 AM   #24
rluhr's Avatar
1968 17' Caravel
2005 30' Safari
Somewhere , roaming America
If you do check in the belly pan (and I really doubt you'll find the connections there on 70's Argosy), be sure to drill out the rivets and remove the pan intact -- don't cut it.
Former full-timer | AIRSTREAM LIFE magazine | Tour of America (old blog) | Man In The Maze (current blog)
rluhr is offline   Reply With Quote
Old 08-04-2005, 10:01 AM   #25
Retired and Retreaded
edmatlock's Avatar
1972 26' Argosy 26
1978 28' Argosy 28
Oklahoma City , Oklahoma
Send a message via Yahoo to edmatlock
Try to splice on to the wire that you have if you have enough old wire exposed. If you are having trouble, it is probably in the light sockets or electric brakes.
ED MATLOCK
edmatlock is offline   Reply With Quote
Old 08-04-2005, 10:05 AM   #26
edmatlock's Avatar
1972 26' Argosy 26
1978 28' Argosy 28
I have a '72 26' Argosy trailor and there is no juction box on the inside. The wire is in the wall and goes to all the lights and brakes. It was not made to be repaired. Sorry.
ED MATLOCK
Old 08-08-2005, 02:45 PM   #27
I was afraid of that.
There is not enough slack in the existing wires.
It looks like surgery is required
Thanks all
Peter
Old 08-08-2005, 05:38 PM   #28
rluhr's Avatar
1968 17' Caravel
2005 30' Safari
Peter, don't despair. You can easily de-rivet a section of interior wall enough to access the wires, cut them off, and install a proper junction box near the water pump, for new wiring. You'll have to remove the gaucho frame and probably the water tank. But it's really not that hard.
Don't cut the wall sections or the bellypan. Drilling out the pop rivets that hold the interior wall skin in place is simple. Once you've done the job, re-riveting the wall is even easier. You might break some of that plastic edge trim, but replacement material for that has been discussed on this Forums in other threads.
Stripping an Argosy CHRIS CANNON Cleaning, Stripping & Polishing 8 05-11-2017 04:42 PM
Need wiring diagram for a 1975 26 ft Argosy ... Hayseed Airstream Motorhome Forums 9 10-06-2006 10:17 AM
confused Argosy newbie Dave Cole All Argosy Trailers 23 09-15-2006 09:36 PM
Electr. Tongue Jack Wiring?? roessler Jacks, Stabilizers, Lifting and Leveling 12 07-17-2002 11:00 AM
TV Antenna wiring??? tenrsingr Audio, Video & TV 6 05-06-2002 02:16 PM
