Old 07-07-2013, 08:27 PM   #1
Sprouty's Avatar
1972 23' Safari
1956 16' Bubble
1947 22' Liner
Hillpoint , Wisconsin
2 X 4 floor supports rotted off at rear
My 73 24ft has the very end of the 2x4 supports that run the whole length of the trailer rotted off right at the very back end. I am replacing the sub floor and want to find a way to repair them. What have other done in this situation? I cant see replacing the whole length of 2x4 so I was thinking maybe I could weld a bracket next to the original ones since I plan to repair the cross member at that location anyway and just replace the very last section of the 2X4.
Here are pics.
ID:	190453   Click image for larger version
2 Liners
2 Safaris
2 Flying Clouds
1 Bubble
and a partridge in a pear tree
Sprouty is offline   Reply With Quote
Old 07-07-2013, 08:40 PM   #2
andreasduess's Avatar
1984 34' International
Toronto , Ontario
If you can weld a new bracket, then sistering the 2x4 should not be an issue. Just make sure the sister is long enough to take the weight.
Have you considered swapping wood for metal?
andreasduess is offline   Reply With Quote
Old 07-07-2013, 08:50 PM   #3
Sprouty's Avatar
1972 23' Safari
1956 16' Bubble
1947 22' Liner
I was thinking that maybe an option as well . Just cut off the 2x4 at the last cross member and weld square tubing across the last section to replace the old 2x4. Now I am thinking I might also want to investigate installing a new set of tanks since it only came with a black water tank. If that's the case this would be the time to change the rear section set up anyway. Then the term "opening up a can of worms" popped into my head.
2 Liners
2 Safaris
2 Flying Clouds
1 Bubble
Old 07-07-2013, 08:51 PM   #4
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
Yea, metal would be a better choice. Also it looks like main frame rails are rusted through at the bottom. You can get angle iron or flat plate to help reenforce them, if you don't have the time or money or will just to replace the whole frame rails. You can bolt on metal to reenforce them.
You can look over my posts "rear end separation short term fix". It goes into fixing rear end issues and welding risks.
If you don't want to weld, the you could always drill threw the main rails and you angle iron and bolt them together. That should provide some added strength.
Good luck!
Silverflames is offline   Reply With Quote
Old 07-08-2013, 06:17 AM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Another choice...
Cut 2/4 back past bad part on an angle of 45 degrees. This will give you more"glue face" and Strength.
Put new "sister" as discussed.
Now, glue another piece of good plywood on the bottom of the seam from 6" back from seam to the bracket on frame and "saddle" it around front and rear of metal bracket but do not touch the frame.
This will help stabilize the end of 2/4 and spread load.
I would use something like P2000 construction adhesive for glue... Comes in caulk tube. Make sure you PREDRILL & "glue-n-screw" together!
This way you can construct the "sister patch" and plywood doubler before joining to existing 2/4 stringer. It is easier than trying to hold all pieces in alignment and glue!
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-08-2013, 07:47 AM   #6
Sprouty's Avatar
1972 23' Safari
1956 16' Bubble
1947 22' Liner
So after a night to sleep on it I have a new option. I was thinking I could weld or bolt a new bracket on the front side of the cross member forward of the bad section and then cut the 2x4 to match the new bracket then I can just replace the section between the last two cross members and be done using the original brackets. Here is a drawing ...please pardon how rough it is.
Name:	cross member.jpg
2 Liners
2 Safaris
2 Flying Clouds
1 Bubble
Old 03-12-2014, 08:00 PM   #7
Sprouty's Avatar
1972 23' Safari
1956 16' Bubble
1947 22' Liner
The fix
Here is what I ended up doing. The rear cross member was rotten as well as the hold down plate so I replaced the rear cross member and the hold down plate as wells as the rear section of 2X4. I made the hold down plate out of stainless and had to replace a section of the outer skin that was destroyed by the metal to aluminum interacting. I also replace the floor of course.
I reconfigured the rear skin with an extra piece of aluminum to make a divider to stop water from running off the trunk lid and under the skin in the tail section to prevent tail rot down the road. The factory set up was ridiculous.
ID:	207331   Click image for larger version
ID:	207333   Click image for larger version
2 Liners
2 Safaris
2 Flying Clouds
1 Bubble
Old 03-12-2014, 10:15 PM   #8
1969 29' Ambassador
Looking good! What did you use to paint the rails?
Old 03-13-2014, 05:06 AM   #9
Sprouty's Avatar
1972 23' Safari
1956 16' Bubble
1947 22' Liner
The original frame parts got a coating of POR15. I use automotive primer and paint on the new metal.
2 Liners
2 Safaris
2 Flying Clouds
1 Bubble
