Old 03-18-2016, 03:54 PM   #1
1976 Argosy 26
Denton , North Carolina
1976 Argosy 26 Window/Door Gasket Replacement
We have a '76 Argosy 26 that needs all the gaskets replaced on windows and the entrance door. Could anyone share their experience/process/materials used? Thanks!
jebrant3 is offline   Reply With Quote
Old 03-18-2016, 06:02 PM   #2
. , At Large
The gaskets are the same used on similar year Airstream trailers. large bulb seal for the main door and storage compartment doors, and double lip seal for around the windows.
Old 03-19-2016, 02:40 PM   #3
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
Inland RV has the right materials and will ship to you. You will need the dimensions of the windows you will be doing when you call. Use 3M adhesive (the black weatherstripping type). It's easiest to do with the windows off the trailer.
1966 Airstream Caravel
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Old 08-12-2016, 11:09 AM   #4
1976 24' Argosy 24
1999 30' Excella 1000
White Haven , Pennsylvania
I would add that it is indeed easier if you remove the windows from the trailer. Removing the old weatherstrip adhesive is the real bugaboo. I found that a small air powered angle grinder with the scotch pad discs on it works really good. You need to be carefull with that but it sure beats scraping. Then, just clean up the bit of residue with solvent and your good.
Gkiesel is offline   Reply With Quote
Old 08-18-2016, 10:35 AM   #5
75ArgosyRob's Avatar
1975 Argosy 26
Ripley , West Virginia
I ordered 17' of main door seal from vintage trailer supply. Fast shipping and great products. Get the surface nice and clean. Bam! No more leaks.
75ArgosyRob is offline   Reply With Quote
Idiot question on window gasket replacement drboyd Windows, Doors, Locks & Vents 3 10-19-2012 07:32 PM
Window and Door Gasket Kit? 1976 Sovereign gronlampa Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 08-17-2011 06:22 AM
What window/door gasket lubricant to use? neil ervin Leaks - Weatherstrips, Gaskets, Caulks & Sealants 11 12-31-2007 09:28 AM
Price comparison for door/window gasket sets. millionairstream Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 05-07-2004 04:59 PM
window gasket replacement JayClay Windows & Screens 3 05-05-2003 09:35 AM
