Join Airstream Forums Today
Old 02-18-2012, 07:39 AM   #15
wasagachris's Avatar
1973 31' Excella 500
1961 30' Sovereign
1947 22' Liner
Durham , Ontario
Send a message via Skype™ to wasagachris
Randall you may be able to source the leak without removing the skins. You can remove the closeouts(inner shrouds) from the wing windows to inspect them. Also the overhead storage cabinet in the end cap can be removed for access to the letters and clearance lights. If the leaks have been going on long enough there may be evidence of their source in a stain trail from the point of entry.
Remove as much as possible including the insulation in the end cap behind the storage compartment and start as low as possible outside with a water hose. This usually takes two people, one to run the hose and the other inside to inspect for the point of entry. Keep running the water until you are sure it isn't getting inside then slowly move up until you find the source of the leak.
Repairing the wing window is a much more complicated matter. The entire window must be removed from the trailer to disassemble the frame. The biggest problem is that the gasket holding the glass to the frame is not available.
You can cut back the gasket with the window in place and then apply a bead of vulkem to seal it up however that will do nothing to remove the standing water and the "discolorization/junk" that is between the frames.
There was a method once posted here to drill into the frame from the bottom and go between the two panes and let the water out. I was unwilling to try that because if you get it wrong you will break the glass.
I replaced my wing windows with NOS(new old stock) ones. It took some time to find them but they are out there. 1 I found on e-bay and the other here in the classifieds.
Airstream sells new ones in single pane only and they are slightly different in size so mods are required to the shell to use them (the new ones are slightly smaller so apatch needs to be made).
1973 Excella 500 31ft Center Bath
1963 Overlander 26 ft
1961 Sovereign 30 ft Custom
1955 Overlander 26 ft
1947 Liner 22 ft.
2010 Ford F450 Crew Cab Dually Diesel
TAC ON-11
Every day is a gift, but does it always have to be a pair of socks.
wasagachris is offline   Reply With Quote
Old 02-19-2012, 08:59 PM   #16
rmoores's Avatar
Killeen , Texas
Smile Sunday report
So lucky for us, we had a rainy day yesterday and we were able to ID some key places where water was getting in. After a little bit of freaking out, calming down and reading where others have been on this forum I think I have a solution figured out. We will order some parbond from vintage trailers, have some guys over on a nice sunny weekend and re-seal the seams on the skins in the places where we are leaking the most. When we order the parbond, I think we are going to order the window and door seals as well as some window hardware to make sure the trailer is pretty leak free. Next up will be flooring and then the bathroom. I am definitely staying motivated by reading how everyone else has tackled similar problems.
I posted some pics on my airstream registry page, if anyone wants to check them out.
Randall
1973 27' Overlander International towed by 2002 GMC Sierra SLE 4x2 4.8L
rmoores is offline   Reply With Quote
Old 02-19-2012, 09:47 PM   #17
Tool Hoarder
marzboy's Avatar
1965 30' Sovereign
West Hills , California
Welcome! Your axles look like they are toast. Besides that all doors windows gaskets etc. VTS has some great silicone remover worked great for me!
Behind every great man, there is a woman rolling her eyes.
My Airstream renovation and camping Blog
My frame and floor restoration thread
marzboy is online now   Reply With Quote
Old 02-24-2012, 05:09 AM   #18
Toledo , Ohio
I read this thread with interest. I also just took position of a '73 Overlander. First question - how can tell if the axels are bad? Do they need to be replaced on age alone?
milroth49 is offline   Reply With Quote
Old 02-24-2012, 06:03 AM   #19
1961 30' Sovereign
1947 22' Liner
Durham , Ontario
You can bet your bottom dollar that if they are original and they probably are they need replacing.
Here is a good article to read regarding axle condition.
Dura Torque Axle
1947 Liner 22 ft.
TAC ON-11
Old 02-24-2012, 08:30 AM   #20
Melody Ranch's Avatar
1956 22' Flying Cloud
1998 30' Limited
1947 22' Liner
Valley View , Texas
Images: 47
You Lucky Dog! Your neighbor is Lance...."Top".....A great Guy to know and beg answers from. He is in Harker Heights or hangin' here on the Forums. Also, save a little time for the restoration rally the first part of June in ABQ. All you question answered, with hands on demos.
Old 02-24-2012, 09:48 PM   #21
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
Central , Texas
Send a message via Yahoo to Top
Neighbors
I don't know if I'd call him lucky, Mr Ranch! I plan to meet Randall in the next few days.
I too highly encourage ANYONE doing a restoration to attend the VRR in ABQ. Even if you know everything, you'll learn something! (and have a whale of a time doing it)
Lance McEwan
Top's Texas Vintage Campers
Central Texas
Top is offline   Reply With Quote
Old 02-25-2012, 08:14 PM   #22
rmoores's Avatar
Killeen , Texas
weekend update
Well, I failed to get some new photos posted last weekend but here are a few...We pulled pretty much everything out of the interior and have some rot on a few pieces of plywood in the front, probably pieces of at least three sheets will need to be replaced.
I am pretty sure axles are original and I am now thinking those will probably be soon, but that is a project that is beyond my garage and expertise at this time. So I will have to figure out where to get them done near me(central texas). Anyone have any suggestions?
Top, Can't wait to get together sometime when our schedules allow it. I also can't wait to get this thing weekend camping worthy to take it to a few rallys.
Probably not going to get much done this weekend but I am going to pick up some parbond and window gaskets this week.
ID:	151955   Click image for larger version
Old 02-25-2012, 08:17 PM   #23
rmoores's Avatar
Killeen , Texas
Marzboy, I saw that you put new axles on your trailer from your blog. How did you go about getting new ones?
Old 02-29-2012, 08:26 AM   #24
Tool Hoarder
marzboy's Avatar
1965 30' Sovereign
I did a lot of rescearch and I went with Axis axles from Colin Hyde. Actually your boy Top was the tipping vote for me. Collins Axles come pre assembled which worked for me because I did it all by my self. And I do mean all of it! Dont do that trust me! Beg a friend, hire undocumented workers, clone yourself,etc. Check out my thread or my blog. Also talk to Lance hes a pretty cool dude. Good luck!
Old 03-04-2012, 01:58 PM   #25
rmoores's Avatar
Killeen , Texas
Exterior Waterproofing
Well, we had a pretty good work day yesterday with the assistance of three friends and a few beers we successfully removed old parbond along major exterior seams and added some sealant on the old roof vents that are in decent shape. Along the way I was able to take a better look at a few of the windows that need replacement/work. Altogether I think three windows need replacement for waterproofing and one additional for cosmetic reasons.
Who has replaced windows in the past? I initially wanted to pay someone to do this because I have never worked with glass or rivets before and didn't want to start with this. But after some more consideration I feel I can handle it with the two on the roof and then work towards the front and then side window.
The olympic rivet kit from vintagetrailer.com seems pretty expensive, but maybe that is what they go for. I just don't know. Any thoughts or suggestions on tackling this project, i.e. removal/installation of the window, finding the replacement glass or removal/installation of the glass in the frame would be appreciated.
Enjoy the photos. The one interior photo is the inside view of the crappiest window.
Until the next time I find time to work on it...
Randall
ID:	152535   Click image for larger version
ID:	152537   Click image for larger version
Vintage Airstream project 73. Work started ready for completion. NR. eBay Watch Airstreams on eBay 0 12-31-2011 06:50 PM
1964 Airstream Travel Trailer - Restoration Started! eBay Watch Airstreams on eBay 0 09-16-2011 01:40 PM
1964 Airstream Travel Trailer - Restoration Started! eBay Watch Airstreams on eBay 0 08-17-2011 09:20 AM
71 Airstream Sovereign . project started eBay Watch Airstreams on eBay 0 08-12-2011 09:30 PM
1964 Airstream Travel Trailer - Restoration Started! eBay Watch Airstreams on eBay 0 07-29-2011 10:20 AM
