Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1973 Overlander
Old 06-13-2008, 09:41 AM   #561
Jim & Susan's Avatar
Profile:  1973 27' Overlander
McDonough , Georgia
Images: 37
Lee, I'll give you a buzz tonight.
Great news! The drug companies are now using graphics in their ED drug ads (not kidding). I guess not everybody fully understands what ED is and how to cope, eh?
www.nesa.org
Air No. 6427
Old 06-29-2008, 04:20 PM   #562
McDonough , Georgia
Images: 37
Air Conditioner stuff
I wanted to update the A/C stuff, but can't decide how much detail to give. I'll just recount a few things and y'all speak up if you need something else.
First, I found a way to properly clean the evaporator coils (or, rather, Dad found a way). Once we had everything apart, inside and out, Dad found a small brass brush that was tossed in the back of the toolbox. Shaped like and about twice the size of a toothbrush. We removed all of that nasty smelling insulation from inside the plenum, soaked everything down with water and then were able to brush most of the gook off the coil.
We're about to have a pretty good thunderstorm, so I'll add more later in case we lose power.
www.nesa.org
Air No. 6427
Old 06-29-2008, 04:58 PM   #563
McDonough , Georgia
Images: 37
We used the little kiddie pool on the floor inside to catch all of the water run off. Once we had brushed off as much of the gook as possible, we soaked the coil down well with Krud Kleaner, Waited a few minutes, flushed with water from the garden hose and repeated that a couple of times. This coil came very clean. The reason that this coil gets so nasty is that the filters used on this thing don’t seem to work very well.
A couple of pics. You can see the squirrel cage fan and the evaporator coil that it blows over, just in front of the fan. The other side of the coil (the part that faces the inside of the camper) is what gets so nasty. Unfortunately, I can’t get a good picture of the inside of the coil.
ID:	62996  Click image for larger version
Name:	Fan and coil.jpg
Name:	Coil Inside.jpg
www.nesa.org
Air No. 6427
Old 06-29-2008, 05:13 PM   #564
McDonough , Georgia
Images: 37
The Condenser Coil on the back side of the unit also needed cleaning. Used pretty much the same method to clean it.
We didn’t bother putting the insulation back in the plenum. It looked to me like it was just sitting there getting nasty and it was only about ½” thick, so it couldn’t be all that effective as insulation. We also sealed the plenum with the aluminum tape to keep the cool air in and keep from pulling dusty, hot air in from the outside.
I have other photos if anybody needs them.
Name:	Krud Kutter.jpg
ID:	62999  Click image for larger version
www.nesa.org
Air No. 6427
Old 06-29-2008, 05:41 PM   #565
Loganville , Georgia
Jim:
How were the nuts & bolts for your shroud? I have only glanced at mine and they look like they are rusted through. Did yours come loose when you went to take the shroud off? My air is working but I bet it is as nasty as yours. I need to get up and take a look.
Brian
SIU Bound is offline   Reply With Quote
Old 06-29-2008, 05:57 PM   #566
McDonough , Georgia
Images: 37
Dang, I had a response typed up and Internet Explorer crapped out on me.
There are only a handful of sheet metal screws that hold the shroud to the ac unit. They were rusted, but came out pretty easy. We replaced them with stainless. If you have the original Armstrong unit, you have to take the aluminum band off the shroud first, then the screws. You may have to take the fan guard off the compressor fan as well, just depends on the type of guard they put on yours.
www.nesa.org
Air No. 6427
Pingbacks are On
Favorite Jerry-Rig? Dave Cole General Repair Forum 52 12-08-2007 12:00 AM
Part Time vs Full Time (Days/Year) InsideOut Community Polls 30 10-23-2005 09:43 AM
Full Time RVer's awsome site! Forrest Link Archive 1 02-10-2003 12:36 PM
Twin rear beds DClark General Interior Topics 15 11-24-2002 08:49 PM
Full timeing Airstreem T/T/ tec12 Our Community 7 11-13-2002 01:13 PM
SEO by vBSEO 3.1.0
