05-06-2018, 09:10 AM
#421
2014 25' Flying Cloud
Cuddebackville
, New York
Originally Posted by OTRA15
Thanks the product description says the black chocks have rubber on the bottom FWIW.
SSM do your chocks have the rubber on the bottoms?
Mine have rubber plugs on the top of the black chocks. It grips very well to the bottom of the yellow ramp.
Seems to me a piece of grippy rubber (like the stair tread I mentioned) would work. I just haven't tried mine yet.
2019 Ford Expedition Platinum
05-07-2018, 05:15 PM
#422
2012 27' Flying Cloud
W
, New England
Originally Posted by Wayne&Sam
Does the tire spin on the Camco or does the Camco slide on the ground? Or both?
The Camco slides on the ground. Not happy....
#423
W
, New England
Originally Posted by DBinSD
I agree, try some old carpet strip or foam under them.
Used a tread. Didn't help [emoji35]
05-07-2018, 05:18 PM
#424
W
, New England
Snip....
Yes. But that's just the chocks. The actual levelers slide like crazy. Different angle than the red ones. Very disappointed. [emoji53]
05-07-2018, 06:00 PM
#425
Cuddebackville
, New York
Even on gravel? It seems like after they used a bit and the bottoms roughed up they could be better.
05-07-2018, 06:15 PM
#426
W
, New England
Yeah. Gravel this weekend. Terrible. [emoji20]
05-07-2018, 06:19 PM
#427
Cuddebackville
, New York
The way the rubber spots on the chocks stick to the ramps I think a grippy rubber mat ought to work.
05-07-2018, 11:19 PM
#428
2017 23' Flying Cloud
Parker
Here is a solution that should work as good as the red curved ones, looks like a direct competitor to Andersen’s , I would go with these....
https://www.amazon.com/Beech-Lane-Ca.../dp/B078TMK6ZD
Troutboy
05-07-2018, 11:22 PM
#429
Living Riveted since 2013
2016 Interstate Lounge Ext
Green Cove Springs
Tire is willing to roll up on the yellow ramp, but the ramp keeps slipping against the ground, out from under the tire. Yellow ramps slide on most anything. We added friction tape to the bottom of the yellow ramps, which appeared to help on pavement, though it most definitely did not help on dirt. Have yet to try them on gravel, but it doesn't look promising.
Regarding friction tape, after leaving our paved but badly out-of-level camping spot and picking up the yellow ramps, I found the tape had slid around on the ramp while parked. I had also noticed what appeared to be some minor shifting of the yellow ramps after parking and stabilizing, but wasn't 100% sure. However, when we broke camp, we realized one of the ramps had actually done so as the friction tape slid and bunched up under that ramp. (sigh)
Red ramps aren't perfect either, but because of their longer and more gradual ramp, they don't slide quite as eagerly as the yellow ones. Red ramps will still slide under many conditions, mind you, just not quite as much or quite as often as the yellow ones.
At this point, when it's obvious a single Lynx block will do the job, we just drop one under each trailer wheel and pull up onto that. Much easier than a ramp when we don't need much height to get leveled. However, ramps that don't slide are more convenient than building a pyramid of Lynx blocks when we know we're going to need 3-4 blocks of elevation under each wheel.
05-07-2018, 11:31 PM
#430
Salem
, Oregon
Hi, I would try these. Amazon and Lowes. Self stick rubber treads.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
05-07-2018, 11:33 PM
#431
Walnut Creek
The latest Camping World flyer has the Camcos and the red defacers are no where to be seen.
05-07-2018, 11:34 PM
#432
Green Cove Springs
Looks promising, we'll hope to give those treads a try.
05-08-2018, 01:47 AM
#433
Sag Harbor
, New York
Phew . . . making 2x8 wood blocks look pretty easy IMO!
Keep It Simple, Stu.
05-08-2018, 03:57 AM
#434
W
, New England
Had those - didn't help on the gravel.
I think I still have my legos....
05-08-2018, 05:23 AM
#435
Cuddebackville
, New York
Originally Posted by Troutboy
Interesting. The listing notes it includes friction tape to put on the TOP of the leveler and to never put it on the bottom. That could mean with the added friction the rotation of the tire helps to draw the leveler under the it in stead of spitting it out.
If this holds true, I may not be so stupid after all. Nah.
05-08-2018, 05:27 AM
#436
2020 27' International
Tuttle
, Oklahoma
I wonder if spray paint would cover red plastic. Keep the functionality, delete the advertising.
05-08-2018, 07:46 AM
#437
Green Cove Springs
Owner of Andersen Hitches vandalizes in Arches NP
Definitely interesting, though it really does seem all the slipping is going on *under* the ramps, not between the ramp & tire. Easy enough to try, I guess.
I also saw a thread where some AF members had put a pattern of hex-head stainless screws into the bottom of their red ramps which worked like a studded tire, improving the ramps’ traction against the ground. Might try that with the yellow ramps, though I wonder what that would do to the grey chocks we put under the yellow ramps to lock them in position.
05-08-2018, 04:01 PM
#438
Sag Harbor
, New York
Any chance this leveling discussion could move over the the "Leveling Post-Andersen" thread?
http://www.airforums.com/forums/f457...en-180503.html
In theory there will be an indictment issued against Ryan Andersen, hopefully sooner rather than later!
05-09-2018, 05:12 AM
#440
2020 Globetrotter 25 FBT
2020 25' Globetrotter
Wildwood
, Missouri
I think this is what I’m going to do. If someone asks. E what they are, I’ll be able to tell the story of how bad Andersen is, but if they don’t ask me, hopefully they will think they are the other brand available. They work too well, and throwing them out does nothing to punish Andersen, he’s received the proceeds a long time ago. Why punish myself?
2020 25GT FBT
2012 Toyota Tundra Dbl Cab, 5.7 4x4
Previous AS trailers: (04) 19’ Bambi, and (11) FC 23FB
