Old 03-27-2017, 08:07 AM   #29
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Anytime you're surrounded by other vehicles on a rural IH you've screwed up. It's really that simple.
Loss of control accidents are the norm. Inadequate TT brakes and poor vehicle dynamics only make things worse.
200' or more from the guy in front of you. And he's moving faster. 700' and all is well.
If intrusion into this space occurs, cancel the cruise control until that 200' is back. And growing.
Under 100' and you'd better be hard on those brakes. Trailer drum brakes fade out pretty quickly.
If you run 62-mph or slower, virtually no problems occur outside of occasional braking space intrusion. It's easy travel.
Run with headlights on.
Test braking distances. What maneuvers you can do and at what speeds. Etc.
Tailgaters are a fact of life. Stupidity level on IH is worse every year. I have an especial love of those who cut in on me far too soon from the left lane because someone faster is behind them. There is no ROW in the left lane.
A combined vehicle with what most around here consider adequate hitch lash-up and running faster than 63 means lane changes plus increased brake and acceleration events. Not good by any measure.
There's no point in running with 63-65/mph truck traffic. And especially not higher with idiot four wheelers running at or around upper limit.
Average travel speed won't increase much with a higher set speed. Mainly an increase in risk over a reduction of time spent traveling.
On a 300-mile day there is no significant time "saved". Measure it for yourself. It ain't rocket science: engine run time versus miles from start to finish.
Plan all stops in advance of the trip. Confirm that GPS isn't going to take you off the biggest road too soon, etc.
Old 03-27-2017, 08:17 AM   #30
Gainesville , Florida
Great post, especially for newbys.
Old 03-27-2017, 09:12 AM   #31
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
Taking all necessary precautions to minimize risks is never a bad idea.
But, fact is towing a travel trailer at highway speeds is inherently risky, and accidents happen.
Sorry as heck for all involved. Prayers for recovery.
boondockdad is offline   Reply With Quote
Old 03-27-2017, 09:14 AM   #32
Llando88's Avatar
2016 30' Flying Cloud
Thanks for this list.
You just can't get too many opportunities to consider making the road a little safer for you and your loved ones, as well as everyone else on the road.
2016 30' Flying Cloud / 2016 Ram 2500 Diesel 4x4
ďCharacter is doing the right thing when nobodyís looking. There are too many people who think that the only thing thatís right is to get by, and the only thing thatís wrong is to get caught.Ē - J.C. Watts Jr.
Llando88 is offline   Reply With Quote
Old 03-27-2017, 09:43 AM   #33
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Space cushioning, following distances always critical and sometimes challenging to maintain. Now add the what distance am I really following at, 300 ft 150 ft or what?
Years ago I did teach motorcycle safety classes and the book required using time between vehicles not estimating distances. When the vehicle ahead passes a fixed object you start one Mississippi two etc.
I checked and looks like still recommended for cars, now just add an extra second while towing. Maybe make it a 3 second space cushion.
https://www.google.com/search?site=&...k1.dgn5sykK2SU
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 03-27-2017, 11:12 AM   #34
Long Island , New York
With drivers getting more distracted by the year, it seems, the old rule of one car length of separation for every 10 MPH is not enough, especially while towing a trailer. Plus, you have to leave enough extra room for all the cars which are following too closely, both ahead of and behind you.
Unfortunately, if you add up all the needed separations [plural], you end up with such a large space that aggressive drivers will use that space to dart in and out of traffic, in order to shift lanes to "get ahead" of things.
A constant struggle! Which is why "slow and steady" in the right lane is often the best path through the maze IMO. Or the middle lane if there are three lanes available on a major Interstate.
Old 03-27-2017, 01:37 PM   #35
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Those numbers in my last post were what I use from radar in big truck.
Old 03-27-2017, 02:51 PM   #36
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
This should be a stickie somewhere and required reading - at least annually - for all forum members.
Outstanding, Slowmover!
Old 03-27-2017, 06:26 PM   #37
jimmini's Avatar
1989 29' Land Yacht
Mesa , Arizona
Images: 43
NEVER trust your GPS as your primary nav. Look at a map before you start Know where your going and use GPS for back up. Look at what happened last week at the Grand Canyon to a girl that followed her GPS down a road that was not there till she ran out of gas. She was lucky she was found 5 days later.
Someone said they had drivers ed.YEP it WAS good BUT most folks did not remember much after that,they come down a on ramps at 30 MPH and try to get in with drivers doing 65 MPH. HAY push on the gas, go down the ramp so you are doing 65 when you get to the traffic.When you get off DO NOT slow on the freeway slow when you get on off ramp, HAY Supped drivers use your turn single.
Back in 1950's truck driver use to be pro drivers now their no better than the other dumb bunnies drivers on the road.
I also hate the stupid people that pass on the right,I guess they missed that class in driver ed.
Remember the road has more BAD driver than good ones.The bad one's do not give a damn about any one but them self,so keep your eye and MINE on the road, stay off your phone and stay alive.
LOL: Only in dumb California where the Government has no respect for the law would they think of make a law to put a lane on their roads for drunk drivers and the drunks would have to stay in that lane.
Jimmini :
AKA : TUMBLEWEED. Just an old buzzard with a itch to yonder.
Cowboys have a way of looking at things a little differently than most folks.Their wisdom is simple and more down to earth.
jimmini is offline   Reply With Quote
Old 03-27-2017, 06:48 PM   #38
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Just one more thing to slowmover's list....and a possible explaination for the accident.
If the vehicle in front of you, or cutting in front of you is a Porsche, Mercedes, Volvo, Bentley, Audi, some VW's or any other Uber sedan, SUV or sportscar, get on the brakes NOW! These cars are equipped with the biggest rotors, multi piston callipers, pre tensioning of brake pads and the biggest stickiest tires.
If they hit the brakes and you haven't.....it's too late. Notice I wrote "hit the brakes", if they throw the anchor out, you haven't got a chance. A Corvette 60-0 is 90 feet!
http://www.motortrend.com/news/20-be...nces-recorded/
Now look at this graph
Speed Perception/Reaction Distance
40 mph 59 feet
50 mph 73 feet
60 mph 88 feet
70 mph 103 feet
In the time that you perceive and react to the Corvette throwing out the anchor, the Corvette is at a dead stop in front of you two feet later; which means you have the original distance between you and the Vette, plus two feet in order to come to a complete stop.
The same would hold true for bikes, but bikers know full well that hammering the brakes in front of 6+ tons is going to end up worse for them. Dead men can't sue.
Food for thought anyone?
Cheers
Tony
ďItís a recession when your neighbor loses his job; itís a depression when you lose your own.Ē "Harry S Truman"
Old 03-27-2017, 07:24 PM   #39
Dazed and Confused
Isuzusweet's Avatar
One more thing that I wanted to post but ran out of time.
An unloaded plain jane cargo Mercedes Sprinter van with one driver will stop from 40 mph in 66.5 feet. A loaded Mercedes Sprinter van with a driver and passenger, towing 4 tons of trailer at 60+ mph will stop in ???????
If a driver or number of drivers cut into line in front of the Sprinter thinking that that lane wasn't slowing down, and then it did. These poor souls didn't have a chance.
Hitch up the trailer, load it and your TV as you would normally. Find a deserted place and set out a flag. Drive at the flag at 60 mph, hitting the brakes as hard you dare once you reach the flag and then measure and do the math; subtract 90.5' for the Vette, leaving you with a 6" buffer and that's the distance you need to keep behind these kinds of cars. Prepare to be shocked.
Cheers
Tony
Old 03-27-2017, 08:16 PM   #40
Dazed and Confused
Isuzusweet's Avatar
Interesting read from an article somewhere on Airforums. Look at the distances on page 3.
http://www.airforums.com/forums/atta...mentid=22096&d...
Cheers
Tony
Old 03-27-2017, 08:21 PM   #41
Boxite's Avatar
2008 22' Sport
"Food for thought, anyone?", you asked...
Well... I can tell you if the fat-wallet in the Beemer cut in front of you and hit the brakes... IF he survives the rear-ending in which he's likely to become involved... He will also find HE IS THE ONE BEING CHARGED WITH THE CAUSE OF ACCIDENT! Courts have found that to be an exception to the rear-end accident scenario.
I suggest you help him lighten his wallet.
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 03-27-2017, 08:29 PM   #42
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
That's not the case in every state. Some still believe the person doing the rear-ending is at fault, no matter what. Hopefully it will change.
My Accident, dealing with State Farm Insurance David Ludwig Insurance & Claims 98 08-22-2016 09:59 AM
airstream accident - fire on oregon I-5? janetbjt On The Road... 26 02-10-2007 08:19 AM
accident bhsl8 General Repair Forum 73 09-11-2003 09:27 AM
Trailer accident Ajrandzin Our Community 2 07-01-2003 01:11 PM
