Old 02-16-2011, 08:59 AM   #15
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Boat Leak
Those tin boats were made to leak by design!
Kind of like a "built-in vacuum". If you have to bail frequently in theory the boat should always be clean.
A set of wings would compliment the props.
Dave
Old 02-16-2011, 09:05 AM   #16
Wayward's Avatar
Cary , North Carolina
we don't need no fancy smancy hitch :)
Originally Posted by Inland RV Center, In View Post
Notice how it's being towed with a 2000 pound hitch.
Weight distribution doesn"t seem a hot topic with boaters generally . I worked my way through school in a marina hauling boats and, setting up new boats and trailers for delivery. Trailers had to be adjusted to the hull shape and distribution of weight in the boat. That was a long while ago but not much has changed except now more high end boat factories sell matched trailers.
Adjustment was never very "scientific", we'd just slide the axle assembly fore/aft to get as much weight on the hitch as possible without bottoming out the customer's TV suspension. Done. If the tongue weight had to be so light the trailer would sway, we'd tell the customer to get the rear suspension beefed up or comeback with a heavier vehicle.
I never experienced WD or sway problems setting up or towing all manner of rigs, unless the trailer was set up too tail-heavy. Boats are heavier for their size compared to travel trailers I guess.
Our marina had a Jeep CJ and a beat'r Chevy 1/2ton with simple flatbar receiver hitches. They'd send us out to pick up everything and anything with those trucks. Lemme tell you, one's towing skills develop quickly when hauling a 28 foot dual engine cabin cruiser, with a 6 cylinder Jeep CJ
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 02-16-2011, 09:38 AM   #17
bredlo's Avatar
1954 22' Safari
Deerfield , Illinois
Send a message via AIM to bredlo
Where's 007 when you need him. That thing is awesome.
bredlo is offline   Reply With Quote
Old 02-16-2011, 12:17 PM   #18
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Tupolev aero sled
This is one of the variants of the Tupolev Areo Sled.
If you are interested in its history, here are a couple links.
Tupolev N 007 Is Ground Effect Aircraft, Boat And A Sled All-in-one - Auto Motto
The remarkable part boat, part sled, part ground-effect Tupelov aerosled
regards,
Ken
