Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Sovereign > 1974 - 1979 Sovereign
Old 07-22-2016, 09:34 AM   #1
Hattiesburg , Mississippi
Relocating Bathroom 1974 31ft. Sovereign
Has anyone had any experience in relocating the rear bathroom forward in a 31ft. Sovereign? I would like to renovate the floor plan so that the bedroom is in the rear, toilet and sink on the right side and install a shower on the left side. This would be similar to the floor plan on a Classic 30. Is this project something that can be done? Thanks to all for any direction or information on this/
DoubleD49 is offline   Reply With Quote
Old 07-22-2016, 09:56 AM   #2
mandolindave's Avatar
It surely can be done.
But it would take a lot of work and money.
Keep in mind, all drains would have to be pitched.
Water supply lines might need to go under the floor, where they aren't heated, or easily drained over the winter, or accessed if you got a leak.
Venting the plumbing might take some doing. Trying to hide the vent, or make a new hole in the roof for the new vent.
A different shaped shower stall would be needed, and most likely a different shaped vanity.
Would you be moving the black tank. My tank sits on top of the floor with the toilet right above it. You would also have to move the drain valve.
You would have to move, and/or fabricate walls.
Also the problem of not adding too much weight
It might be easier quicker and cheaper to sell it and but what you want
mandolindave is offline   Reply With Quote
sovereign
relocating bathroom tjp Sinks, Showers & Toilets 0 03-25-2014 02:29 PM
Can I? Relocating Bathroom and Such. Katesie Plumbing - Systems & Fixtures 9 08-22-2013 09:41 AM
Will cover for 31ft Classic fit 31ft Sovereign? rv4007 Winterizing, Storage, Carports & Covers 8 08-16-2013 08:34 PM
Bathroom Towel Rack - Relocating Frank&Mike 2006 - 2010 International 6 03-06-2013 08:34 AM
Relocating bathroom to a center position Spitfire78 General Interior Topics 12 06-01-2012 08:04 AM
