Old 07-07-2006, 06:22 PM   #1
FT RVing
lebolewis's Avatar
1976 31' Sovereign
Always searching for a place w/low Humidity , FT RVing, N & S, E & W, & in between
Plumbing Vents - Useful Info
I have a new 76 31ft Sovereign and I discovered a leak in a plumbing vent (there are 3 of them). I removed the cast aluminum cover and discovered the problem....cracked/split/deteriorated seal and lots of decayed trash. Cleaned everything out and realized that I was probably looking at the original stuff, 30 years old! Looked at Andy's on-line offerings, seals and fiberglass screens, for $6.50 each, plus shipping (I need 3). Decided to do a little LOCAL shopping. Discovered that LOWES has a 6"X6" piece of red rubber , 1/8" or 1/16" thick, in the plumbing dept, that is perfect for making the gasket. The hardware store gave me a 6" wide strip of aluminum screen. The aluminum is better than the fiberglass in that it can be cut and molded to fit in the "TOP" of the cast aluminum housing (use a little Vulkem to hold it up there) thereby preventing trash from ever getting inside and clogging the drain holes in the aluminum casting. You're welcome, Bill
lebolewis is offline   Reply With Quote
Plastic Plumbing 83Excella Fresh Water Systems 6 05-04-2006 01:16 AM
Winterizing your plumbing 2002 BobbyW Plumbing - Systems & Fixtures 0 11-01-2002 08:23 PM
Gaskets, vents, etc... Chuck Windows & Screens 3 10-27-2002 02:18 PM
GREAT TECH INFO - good advice COArgosy78 General Repair Forum 6 10-11-2002 01:08 PM
Airstream info Rodger Airstream Motorhome Forums 3 07-03-2002 09:15 AM
