Old 10-24-2009, 09:35 AM   #1
1978 31' Sovereign
Montverde , Florida
Last Minute safety questions....First trip.
What we have...
78' Sovereign, 31ft.
Chevy 1500HD, 6.0 liter
Reese Trunnion WD Hitch
Prodigy Brake Controller
1. Drove around through hilly area for 30 minutes to get a handle on how it was going to handle at the speeds we will be driving to our destination (45 minutes away). Transmission ran hotter than w/o towing trailer. Was reaching 160* which is about 30* higher than normal. Is this OK or do I need to replace the tiny Factory transmission cooler? At what temp do I need to stop and let it cool?
2. Did a final test on brakes and to a novice, seems to brake evenly between truck and trailer. Now, I stopped as quickly as I thought it would be safe to test, however, I need opinions on emergency stopping. Say I am going 45 and I see a kid about to run into the road. While stepping on the brake, do I want to use the manual lever to make sure the trailer brakes work harder than the truck in order to prevent a jack knife situation?
3. Sway control...Do I need to use it in around town driving and or county roads with 50mph that max that we will be driving?
Lights...good
Bearings...good
Brakes....good
Tires....good
Anything I am forgetting about?
Thanks again!
la4photo is offline   Reply With Quote
Old 10-24-2009, 09:48 AM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Originally Posted by la4photo View Post
What we have...
Lights...good
Bearings...good
Brakes....good
Tires....good
Thanks again!
For short hauls you can get away with the miniscule tranny cooler, but plan to upgrade soon.
Not sure how you have your Prodigy set up, but IIRC you need to be using a bit of boost to have the trailer lead the truck a bit in braking. I run my pretty close to neutral, but then again my truck out weighs my trailer by close to 1,000 pounds.
I would use the sway control, the only time I don't is for very short distances at low speeds. If I am going on the road, the hitch is fully hooked up.
Aaron
WBCCI #XXXX AIR #2495
Old 10-24-2009, 09:55 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
I question those temperatures if they are from a factory gauge. The transmission without a trailer will generally run at a temperature equal to the air coming off the engine. I think your numbers are low to actual temperature.
Yes is you are going to tow in hills in a warmer area you should consider an after market trans cooler. Even better if your transmission will support it, and older ones do, consider a manual converter locking system. That way the transmission does not build heat while towing and your fuel mileage will be improved.
Short hills at low speed will build more temperature that longer ones at higher speed.
Most brake controllers have adjustment instructions. Mine says to drive at 25 mph and using the manual control adjust the brakes so they no longer skid the trailer tires when full applied with the manual control. This in theroy gives you full braking power without locking the trailer and having it come around and kiss you.
2004 Excursion 4x4
Old 10-24-2009, 10:41 AM   #4
What we have...
Lights...good
Bearings...good
Brakes....good
Tires....good
Thanks again!
1. Install a Hayden transmission oil cooler. Over heating has a negative effect on the transmission parts and the fluid. Pull the transmission dip stick. Smell the oil. If you have a burnt smell, then the transmission oil should already be changed.
2. Making an emergency stop, is just that. I would suggest that your thoughts should be "stopping" at all costs, even if you lock up the brakes.
3. Would you consider, for safety reasons, that it would be ok to run around town, with only 2 wheel brakes on your tow vehicle?
If not, then please don't consider it to be safe, running around town without the sway control. You NEVER EVER will know when some fool will cut you off, or slam on their brakes, in front of you, where you may have to switch lanes faster that you can blink an eye. Even your Colonial Drive, is not a safe place to tow, without a sway control in use.
When it comes to safety, being half prepared, is not worth the potential risks, property damage, or a fatal accident.
Old 10-24-2009, 01:07 PM   #5
2008 28' Safari SE
winter garden , Florida
winter garden? thats where I live, I am over on lake apopka. Have not seen any other airstreams around here, where do you keep it?
bob34787 is offline   Reply With Quote
Old 10-24-2009, 01:25 PM   #6
1978 31' Sovereign
Montverde , Florida
I am on lake Apopka in Montverde. Grew up in Winter Garden on Tilden & Park Avenue. Would love to catch up with you sometime.
Old 10-24-2009, 01:35 PM   #7
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Braking
I can tell you what I do with my Prodigy. For highway, freeway, and downhill driving, I use it in the Boost 2 positing. For slow speed driving I use Boost 1. For stop and go city driving, I usually have the boost off. The only reason, I don't use the boost all the time, is the jerky braking gets annoying.
I'm not saying this is the best way, but it is what works for me.
Regards,
Ken
Old 10-24-2009, 02:07 PM   #8
1986 31' Sovereign
Miami , Florida
Definitely use the anti-sway. My trailer is also a 31' and it tows fine without it (had a mount fail once 40 miles from a replacement so I know first hand)...BUT if I need to do something radical, I want the anti-sway operational. Hate it when he trailer passes me!
I would also invest in a tranny cooler. Pretty cheap in comparison to an overhaul.
Have fun!
mike
Tex's First Trip - Lakeport State Park, MI a couple of newbie questions tksbaskets On The Road... 15 06-29-2009 08:39 PM
Questions after our first long trip - 2005 Classic Wingeezer 2001 - 2005 Classic 15 04-01-2009 06:17 PM
Perry for last minute non-member apolaroid WBCCI Rallies & Events 6 06-26-2007 06:06 AM
Any "last minute" advice on the big trip? Wolf On The Road... 10 07-28-2004 02:46 AM
Questions Resulting from First Big Trip... dmac Our Community 11 07-18-2003 10:51 AM
