Old 09-23-2011, 04:39 AM   #1
1977 31' Sovereign
Manchester , New Hampshire
Images: 33
Fresh water tank drain ?
Ok I am stumped where would this be?
1976 Airstream Sovereign International Landyacht (renovating)(found DOM plate said 1976)
1968 Airstream Caravel 17 footer
2004 Nissan Titan with BT package
K/N Cool intake air
Duel power exhaust
Mrcrowley is offline   Reply With Quote
Old 09-23-2011, 04:57 AM   #2
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
Look between the axles on the road side. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 09-23-2011, 06:43 AM   #3
1977 31' Sovereign
Images: 33
Will it show on outside of belly pan? Underneath?
K/N Cool intake air
Duel power exhaust
Old 09-23-2011, 06:48 AM   #4
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Just run the tank empty by using the pump. You need to flush your holding tanks anyway.
Old 09-23-2011, 06:53 AM   #5
Refurbished 89 Excella
DKDarrow's Avatar
Sugar Valley , Georgia
Between the tires, on the roadside/drivers side of the trailer. It is on the side of the tank facing outward..........a typically white valve..........IT BREAKS OFF SO EASY it is pathetic...........Be careful............God bless.......Dennis
Dennis & Susan
D&D Farms, Sugar Valley, Ga
Registered Boer goats
DKDarrow is offline   Reply With Quote
Old 09-23-2011, 06:55 AM   #6
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
It is hard to find. Almost between the wheels, on the side of the pan that is under the tank, near the wheels. It does show, but you got to be lying down with your head under the trailer just a little to find it. It is only 6" or so from the wheels. Hard to reach too. 1/2 turn opens it.
Old 09-23-2011, 08:37 AM   #7
Alumaholic's Avatar
2019 27' Flying Cloud
Albuquerque , New Mexico
Images: 36
Not On a 1977 Sovereign
I"m pretty sure the 1977 Sovereign 31' did not have a freshwater drain valve. Neither my 1976 Sovereign nor my 1976 Safari had one.
Dwightdi is correct.
Ken L
2019 Flying Cloud 27FB
2018 GMC Yukon Denali XL
Four Corners Unit WBCCI #5783
Alumaholic is offline   Reply With Quote
Old 09-28-2011, 07:01 AM   #8
1977 31' Sovereign
Images: 33
Ok how do you drain tank for winterizing then?
K/N Cool intake air
Duel power exhaust
Old 09-28-2011, 07:05 AM   #9
1977 31' Sovereign
1989 34' Excella
As I posted before: you simply run the tank dry with your water pump and in the process you flush both your black water and gray water tanks. There is a little remaining in the tank and for that you pour in a quart or so of antifreeze. It has worked for me for 17 years of cold Illinois winters.
Old 09-28-2011, 07:32 AM   #10
arodriguez60's Avatar
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 85
On my 73 Safari the low drains for the lines and the freshwater drain are under the sink on the street side. Total 3 drains near the waterpump
Avion C11
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
2004 F250 superduty ext cab
2014 F350 longbed superduty crewcab
arodriguez60 is offline   Reply With Quote
Old 09-28-2011, 07:43 AM   #11
1995 25' Excella
waynesboro , Virginia
Same here, 3 valves under the sink, one drains the FW tank and the drain spout is immediately under the valve.....good hunting
waltero is offline   Reply With Quote
Old 09-28-2011, 07:58 AM   #12
1977 31' Sovereign
1989 34' Excella
The fresh water tank is below the floor and the drains under the sink is well above the tank, so they can not possibly drain the fresh water tank, unless you turn the trailer over. Those drains only drain the fresh water pump and the lines that are above the floor.
Old 09-28-2011, 08:02 AM   #13
Alumaholic's Avatar
Images: 36
dwightdi is Correctomundo (Again)
Tell 'em again, dwight. Perhaps they'll listen this time.
Ken L
Old 09-28-2011, 08:14 AM   #14
1969 25' Tradewind
1983 34' Limited
Images: 85
The drains in mine are very low. I have to reach far down. My tank has drained all the way and have had no problems with freezing . I did have a line freeze on me in the bathroom one year when I thought I had a little time. I got to the lake and turned the waterpump on and I heard the water spraying. But I have never had any issues with draining the tank in 10 years.
Avion C11
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
Fresh Water Tank and City Water ??? tr0y Fresh Water Systems 3 08-29-2011 04:49 AM
Fresh Water Tank Drain Valve greatlakes Fresh Water Systems 28 08-09-2011 11:54 AM
Fresh Water Tank Size and Gauges ednspace Fresh Water Systems 4 05-23-2011 08:19 PM
Fresh Water Tank Drain Jack46 2009-2015 Flying Cloud 3 03-06-2011 01:37 PM
