09-23-2011, 04:39 AM
1977 31' Sovereign
Manchester
, New Hampshire
Fresh water tank drain ?
Ok I am stumped where would this be?
1976 Airstream Sovereign International Landyacht (renovating)(found DOM plate said 1976)
1968 Airstream Caravel 17 footer
2004 Nissan Titan with BT package
K/N Cool intake air
Duel power exhaust
09-23-2011, 04:57 AM
1981 27' Excella II
mays landing
, South Jersey
Look between the axles on the road side. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
09-23-2011, 06:43 AM
1977 31' Sovereign
Manchester
, New Hampshire
Will it show on outside of belly pan? Underneath?
K/N Cool intake air
Duel power exhaust
09-23-2011, 06:48 AM
1977 31' Sovereign
1989 34' Excella
Johnsburg
Just run the tank empty by using the pump. You need to flush your holding tanks anyway.
09-23-2011, 06:53 AM
Refurbished 89 Excella
1988 29' Excella
Sugar Valley
, Georgia
Between the tires, on the roadside/drivers side of the trailer. It is on the side of the tank facing outward..........a typically white valve..........IT BREAKS OFF SO EASY it is pathetic...........Be careful............God bless.......Dennis
Dennis & Susan
D&D Farms, Sugar Valley, Ga
Registered Boer goats
09-23-2011, 06:55 AM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
It is hard to find. Almost between the wheels, on the side of the pan that is under the tank, near the wheels. It does show, but you got to be lying down with your head under the trailer just a little to find it. It is only 6" or so from the wheels. Hard to reach too. 1/2 turn opens it.
09-23-2011, 08:37 AM
2019 27' Flying Cloud
Albuquerque
, New Mexico
Not On a 1977 Sovereign
I"m pretty sure the 1977 Sovereign 31' did not have a freshwater drain valve. Neither my 1976 Sovereign nor my 1976 Safari had one.
Dwightdi is correct.
Ken L 2019 Flying Cloud 27FB
2020 GMC Sierra 1500 Crew Cab 6.2L Max Tow Four Corners Unit WBCCI #5783
09-28-2011, 07:01 AM
1977 31' Sovereign
Manchester
, New Hampshire
Ok how do you drain tank for winterizing then?
K/N Cool intake air
Duel power exhaust
09-28-2011, 07:05 AM
1977 31' Sovereign
1989 34' Excella
Johnsburg
As I posted before: you simply run the tank dry with your water pump and in the process you flush both your black water and gray water tanks. There is a little remaining in the tank and for that you pour in a quart or so of antifreeze. It has worked for me for 17 years of cold Illinois winters.
09-28-2011, 07:32 AM
2008 27' Classic FB
1959 22' Flying Cloud
fairview
, New Mexico
On my 73 Safari the low drains for the lines and the freshwater drain are under the sink on the street side. Total 3 drains near the waterpump
Avion C11
1959 Flying Cloud 1969 Tradewind
1973 Safari
1983 34 ft Limited
2004 F250 superduty ext cab
2014 F350 longbed superduty crewcab
09-28-2011, 07:43 AM
1995 25' Excella
waynesboro
, Virginia
Same here, 3 valves under the sink, one drains the FW tank and the drain spout is immediately under the valve.....good hunting
09-28-2011, 07:58 AM
1977 31' Sovereign
1989 34' Excella
Johnsburg
The fresh water tank is below the floor and the drains under the sink is well above the tank, so they can not possibly drain the fresh water tank, unless you turn the trailer over. Those drains only drain the fresh water pump and the lines that are above the floor.
09-28-2011, 08:02 AM
Albuquerque
, New Mexico
dwightdi is Correctomundo (Again)
Tell 'em again, dwight. Perhaps they'll listen this time.
09-28-2011, 08:14 AM
2008 27' Classic FB
fairview
, New Mexico
The drains in mine are very low. I have to reach far down. My tank has drained all the way and have had no problems with freezing . I did have a line freeze on me in the bathroom one year when I thought I had a little time. I got to the lake and turned the waterpump on and I heard the water spraying. But I have never had any issues with draining the tank in 10 years.
Avion C11
1973 Safari
1983 34 ft Limited
08-12-2019, 05:25 PM
1981 27' International
Lodi
What is the capacity of the fresh water tank in my 27ft International 1981 trailer?
11-27-2019, 07:00 PM
1978 31' Sovereign
New Smyrna Beach
Drain
On my 78, there is no drain per say, but there is a cover that can be removed on the street side that once removed exposes a 1 1/2” fitting with a plug that can be moved to drain the tank. Pain to get to, but it is a drain. Easier to pump it out.
11-27-2019, 08:34 PM
1994 34' Excella
Warren
, Manitoba
Thee is no tank drain on a 1976 Sovereign International. I know, as I had one!! Pump tank till no water comes out, disconnect pump from inlet side and pump anti freeze throught the system. The little bit of water remaining in the tank will freeze and nothing gets hurt. Where I live we see -40 degrees an a regular basis. Never had a single problem in over 10 years I owned it.
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
