Old 09-02-2003, 03:07 AM   #1
1975 31' Sovereign
Bon Air , Virginia
Question Battery Group
Can someone give me a hand? I have just purchased a 1975 Sovereign 31. I am to pick it up on Saturday the 6th. I have been told that it has an electric tongue jack but no battery. He has no idea what group it uses. Can anyone tell me what battery group I need for this unit? Thanks in advance. Mark
BA Sovereign is offline   Reply With Quote
Old 09-02-2003, 06:44 AM   #2
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Probably anything from a Group 27 to a Group 31. I have a 30XHS Trojan in mine.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 09-02-2003, 08:43 AM   #3
gvanman's Avatar
Howell , Michigan
Battery Group
I have a 1974 Sovereign and used a Group 24 maintenance free battery. You could probably go a bit bigger if you needed to.
Other group sizes that are about the same size as a group 24:
(Group 24 = 10 5/8" x 6 3/4" x 8 3/8")
Group 34 = 10 3/16" x 6 7/8" x 8"
Group 78 = 10 3/16" x 6 7/8" x 8 1/8"
My advice would be to go with a maintenance free battery and avoid having to top up with water, but more importantly, avoid the risk of acid spills and the corrosion that goes along with it.
I would also recommend a battery designed for cycling rather than starting - they cost more, but will keep going much longer when you are using the trailer without electrical hook-up.
My choice would be one of the new Exide Extreme Duty Orbital batteries as they have excellent cycle life and a very low internal resistance so you can charge them quickly and also get a lot of power out of them if you need to. You can probably get these at NAPA but they might be 'own-labelled'!
Cheers.
'If you always do, what you've always done.'
'You'll always get, what you've always got!'
http://www.dpharris.com
gvanman is offline   Reply With Quote
Old 09-05-2003, 03:24 AM   #4
1975 31' Sovereign
Bon Air , Virginia
Great! Thanks for all your help.
Old 09-16-2003, 11:28 PM   #5
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
My '77 Excella 500 has 2 battery boxes (one on each side of the propane tanks) and each holds a grp. 27 Delco Voyager which is 12 1/2" long. A Duralast grp. 27 was 1/4" too long to fit in the battery box. What did you finally get?
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
vintage airstream battery wildcat455 Electrical - Systems, Generators, Batteries & Solar 4 07-02-2003 01:50 PM
Battery Exploded wayner1239 Electrical - Systems, Generators, Batteries & Solar 15 05-11-2003 09:43 AM
Installing battery problem flyfisher Electrical - Systems, Generators, Batteries & Solar 2 04-01-2003 06:59 PM
Univolt with Battery Minder COArgosy78 Electrical - Systems, Generators, Batteries & Solar 32 03-10-2003 08:59 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 03:58 PM
