Old 10-24-2019, 08:15 PM   #21
Alumaholic's Avatar
2019 27' Flying Cloud
Albuquerque , New Mexico
Images: 36
I hope your neighbor has erected a shrine devoted to DBJ and revised his Will.
I was astounded when I discovered the 1/2" plywood floor in my '76 Sovereign. This unbelievable discovery killed my plans for a dinette. (Who knew that the gaucho was a structural component in the '76 Airstream?)
And Post #16 provoked this flood of suppressed memories of what I found when I removed the rear pan on my '76 Safari 23'. Same exact rusting rear cross-member!
Ken L
2019 Flying Cloud 27FB
2020 GMC Sierra 1500 Crew Cab 6.2L Max Tow
Four Corners Unit WBCCI #5783
Alumaholic is offline   Reply With Quote
Old 10-24-2019, 08:37 PM   #22
1956 22' Safari
Williston , Vermont
Hi David,
Glad I found your new thread. Always enjoy following along with your work. - Mark
Our restoration Blog
steinVT is offline   Reply With Quote
Old 10-25-2019, 07:01 AM   #23
wcronin4's Avatar
1978 31' Sovereign
New Smyrna Beach , Florida
David
I had to extend floor support members into the lvg area when my frame was made. I couldnít believe AS used 1/2 ply.
Some folks on the forum replace the 1/2 with 3/4 and use a router to rabbit the edges to 1/2 to fit into the c channel. I was afraid to do that because the additional 1/2 of floor height would create problems with the fit of interior parts.
I think the ďlightĒ design of the late 70s trailers and super light frames left much to be desired, in my humble opinion.
Bill
wcronin4 is offline   Reply With Quote
Old 10-25-2019, 08:09 PM   #24
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I'm very happy you Airstream Forums friends found my project thread. I'm going to need all the support I can get.
Alumaholic: We Airstream owners enjoy helping each other out. My friend is giving this old man something to do this winter. I need that. You are right that these lightweight 70s trailers are a "river of tears" with rust and other problems. But they are vintage Airstreams and can be made better. I'll guarantee you your 2019 Flying Cloud is much better built.
Wcronin4: I can see now why Airstream thought 1/2" ply would be "goot enuf". The extra frame supports generally leave the plywood bridging maybe 2'x2', except in the rear bath and in the front room. It is way too much work to revert back to 3/4" plywood. My wife's 86 Limited is OSB, that is even a worse subfloor material in my view.
SteinVT: I can never match your restoration of your Safari. But I'm glad you are following along this winter. Your advice is most welcome.
David
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
Link to our 1976 Renovation Project:
http://www.airforums.com/forums/f221...ct-202081.html
Old 10-25-2019, 08:27 PM   #25
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Rusty Riggers
I always wonder why we call the frame outside body supports "outriggers". Without them, the body would fall down around the frame. So they are body supports seems to me. But when in Rome...
We removed the body wraps all around the trailer to expose the rusty outriggers. We have identified 8 of them that need replaced. We don't want our Sovereign's body to ride low like a teenagers pants.
I cut 4 of the 8 rusty riggers off today. I don't understand why the outriggers got so rusty. Maybe the fiberglass insulation around them holds lots of moisture? By the way, the 5th outrigger in the photo was a freebee. It was just hanging in the body wrap, not attached to anything. Airstream error?
We'll get replacements on order. We'll contract a mobile welder to come to my place and make all the frame repairs we will need. We will get this Sovereign's rear end together again, not separated and saggy like it is now, again like a teenager's pants.
This Sovereign has better wheel well construction than my 75 Overlander. They actually fit the upside down "F" channel around the square subfloor cutout to help insulate it from road splash. And there is a piece of aluminum both forward and aft in the wheel well that is flashing to help seal the joint of outrigger to subfloor.
And I noticed the tight rivet spacing pattern of body to upside down "F" channel all round the trailer. This is riveted really tight, and it was well sealed with Vulkem by the Airstream assemblers.
David
Name:	1910 Frame  Outriggers Removed-800x600.jpg
ID:	354932   Click image for larger version
Name:	1910 C Channel Rivet Pattern-800x600.jpg
WBCCI #8607
VAC Region 11
Old 10-26-2019, 08:05 PM   #26
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Where to Buy Outriggers
I see my usual sources are "out of stock" on outriggers.
Can you folks recommend an outrigger source for me? Appreciate it.
David
WBCCI #8607
VAC Region 11
Old 10-26-2019, 09:29 PM   #27
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
David
I have three that I donít need. PM me for details
Old 10-27-2019, 05:35 PM   #28
Eric 26 Argo's Avatar
Knoxville , TN
David did you try Out of Doors Mart?
Eric 26 Argo is offline   Reply With Quote
Old 10-27-2019, 08:11 PM   #29
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hi Eric: Yes I did, online. The web page show outriggers out of stock. Same with Inland RV. There is a vendor called SkyHi RV that carries them, but I've never used them and know nothing about them. Their price is quite a bit higher also. I suspect our local Airstream dealer would be the highest price of all.
David
WBCCI #8607
VAC Region 11
Old 10-27-2019, 08:28 PM   #30
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Starting At The Rear
I finished cutting off the rusty riggers. I moved to the rear of the trailer where there is serious trouble.
The 1/2" plywood rotted out between the C channel and the rear cross member. The tie down bolts were rusty loose. There are a lot of subfloor penetrations back there like my 75. Dump valves, shower P trap, low point drains, shore power cord, copper ground wire come to mind. We will configure the plumbing to avoid as may as possible.
The 76 rear cross member is completely different from my 75. I think I like it better. I'll post a photo when I get it cut out of there.
David
Name:	1910 Bath Floor Rot Left-800x600.jpg
WBCCI #8607
VAC Region 11
Old 10-28-2019, 07:44 AM   #31
wcronin4's Avatar
1978 31' Sovereign
David.
Iíve ordered things from SkyHiRV with success. Higher prices but they had something I needed when others were out of stock.
Bill
Old 10-28-2019, 05:53 PM   #32
2016 26' Flying Cloud
Surrey , British Columbia
Good luck!! Canít wait to see pics as you go through this renovation.
Luckylady is offline   Reply With Quote
Old 10-28-2019, 08:53 PM   #33
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Rear Crossmember Out
I continue to make this old Sovereign lighter in weight. I "rough cut" the rear crossmember down. I had to do this to gain access to the rusty frame to c channel bolts. My cutoff wheel wouldn't fit in there.
The rear cross member is a big piece with a lip on top that the infamous aluminum strip and subfloor rests on. The body hold down plate and C channel rests on top of the subfloor. I have more work to do to get the body hold down plate out of there.
I was pleased to see the infamous aluminum strip was corroded all to heck. An eye for an eye. Justice.
The 76 long trailer models have quite a bit larger waste water tanks. The tank compartment is larger. There is a 7 1/2 longitudinal steel floor support from the crossmember under the wardrobe to the rear crossmember, welded both ends. These steel components make up the tank compartment walls. Frame rails, rear crossmember, and center floor support. It is a better design than my 75.
We will have to figure out how to best re-fabricate all this to make a solid rear body attachment.
David
Name:	1910 Frane Rear Crissnenber 2-800x600.JPG
ID:	355198   Click image for larger version
Name:	1910 Rear Aluminum Srip Rear-800x600.jpg
Name:	1910 Rear Cross Member Left Side-800x600.jpg
WBCCI #8607
VAC Region 11
Old 10-29-2019, 09:16 AM   #34
Alumaholic's Avatar
Images: 36
... We will have to figure out how to best re-fabricate all this to make a solid rear body attachment.
David
Nothing a little POR won't "fix"
Ken L
Old 10-29-2019, 01:24 PM   #35
1976 31' Sovereign
Conifer , Colorado
Absolutely! A shrine made of cookies! David is my hero. I am really enjoying doing this project together. I am learning so much. I could not begin to do this without him.
- Cort
Cvliv is offline   Reply With Quote
Old 10-29-2019, 02:15 PM   #36
Alumaholic's Avatar
Images: 36
Hmmm. Sounds Yummy
I may have to make another pilgrimage to Conifer to visit that shrine.
Ken L
Old 10-29-2019, 07:06 PM   #37
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Now What?
Cort and Alumaholic: You know there are so many Forums members who have removed the body, built new frames, do all their own cabinet work, and end up with a beautiful trailer. I enjoy reading their project threads. Me, I'm just an old retired guy trying to stay busy.
I got the rear end of the frame all cut apart. Now what?
The rear body mounting plate was rust beyond repair. Like my 75 Overlander, the rear C channel was also fractured at the frame rails. Here is a photo of the "stack of parts" at the rear of the trailer. On the bottom is the big crossmember, then the aluminum strip, then the 1/2" plywood, on top of the wood is the body mounting plate, and finally the C channel. We will fabricate new pieces and weld them to the frame rails and other frame parts.
The body mounting plate measured about 38" long. The distances between the rear end cap "formers" that the rear cargo door and large rear window is 48". The body mounting plate had about 10 rivets in it holding the body exterior skin to the body plate. Not enough in my view. We plan on making this part longer and getting the body plate under those "formers" to better support the rear body.
We have quite a bit of rear end floor rot to repair too.
David
Name:	1910 Frame Rear Body PLate-800x600.jpg
ID:	355253   Click image for larger version
Name:	1910 Frame C Channel Fracture-800x600.jpg
Name:	1910 Frame Rear Parts Stack-800x600.jpg
WBCCI #8607
VAC Region 11
Old 10-30-2019, 08:03 AM   #38
1966 24' Tradewind
Frankfort , KENTUCKY
76 refurb
Hello,
I'm relatively new to the Forum. Love what you're doing with the 76 restore and will definitely keep track (music to my ears - resonates in my soul!) We recently purchased a 1976 Excella 500 and, like you, wanted a winter project to bless our daughter when she graduates from college this spring. I'm in the middle of ripping everything out and trying to decide how far I'm willing to go. We own/restored a 1966 Land Yacht a few years ago and we love these things....Airstreams are very addictive! We take it everywhere (I'm blessed with a wife that loves to camp). keep the posts coming!
blessings,
Rick
AlmnmSloop is offline   Reply With Quote
Old 10-30-2019, 08:37 PM   #39
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Welcome Rick: Glad you found our thread and glad to hear you are on a similar project this winter. Sounds like you have experience renovating these vintage Airstreams.
Maybe your Excella 500 (top of the line trailer in 76) has many of the same problems the Sovereign has. I think your trailer has better cabinetry and more amenities. Maybe you have a photo or two of the thing, especially the interior. I'd be interested to see the difference.
David
WBCCI #8607
VAC Region 11
Old 10-31-2019, 07:17 PM   #40
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Left Right Outriggers
Does anyone know why Airstream designed a left side outrigger and a right side outrigger. The two parts are mirror images of each other. I understand the flange at the top of the outrigger would always face forward. I understand why you need it at the wheel well front and back. But I don't understand why you need a left and a right down the sides of the trailer.
David
WBCCI #8607
VAC Region 11
sovereign
Digging in as a new owner of 1978 AS Sovereign renovation project epsasser Member Introductions 6 10-09-2017 09:16 AM
Wanted Vintage Trailer, center bath, 28 ft+ for renovation project britta315 Airstream Classifieds 0 05-04-2017 03:34 PM
My First Renovation Project: a Simple Shower Head clicknathan Sinks, Showers & Toilets 2 01-14-2013 08:18 AM
Any red flags on buying a renovation project? hankyknot General Repair Forum 23 05-17-2011 08:49 PM
Renovation Project: where to begin? spz Upholstery, Blinds, Walls & Interior Finishes 7 02-28-2010 05:39 PM
