Old 02-02-2019, 10:41 AM   #1
1977 31' Sovereign
Sunset Valley , Texas
3D model of '77 Sovereign frame...
Hey gang,
I made this accurate 3D model of my 1977 frame in Sketch Up.
I haven't put in the axle plates or rear skid/tank protectors yet but figured anyone with a mid-late 70's 31' trailer might find this useful for planning purposes. If you want the file, a different view or minor modifications (within reason) just let me know...
Ian
Name:	Screenshot 2019-02-02 10.17.29.jpg
ID:	332827   Click image for larger version
Name:	Screenshot 2019-02-02 10.18.07.png
Iansk is offline   Reply With Quote
Old 02-02-2019, 03:50 PM   #2
New Smyrna Beach Bill
wcronin4's Avatar
1978 31' Sovereign
New Smyrna Beach , Florida
Trailer Design
Ian
Nice work. I've saved these views to show to my welder. These not much left of mine for him to go by
Bill
wcronin4 is offline   Reply With Quote
Old 02-02-2019, 04:40 PM   #3
1977 31' Sovereign
Thank Bill,
If you need a specific part isolated or the measurements of something it’s easy to do.
Glad you can find these useful.
Ian
Old 02-02-2019, 08:11 PM   #4
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Very nice work. Not all that easy in Sketch or any 3D software package.
I see your trailer has a much different rear end crossmember than mine does. Mine was only a c shaped channel, maybe 1 1/2". Maybe Airstream was making some design changes back there by 1977. The key is keeping rain water totally away from the subfloor.
David
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
Old 02-03-2019, 05:52 AM   #5
1977 31' Sovereign
Thanks David.
The program, Sketch UP, isn't that hard to use really. I use it for work quite a bit.
There are quite a few questionable design decisions on my trailer that I intend to improve while hopefully not making anything worse.
Ian
Old 02-03-2019, 11:17 AM   #6
1976 31' Sovereign
Helotes , Texas
Where are the outriggers that set the framing for the steps?
I attached a dimensioned drawing I made for my '76.
glrtex is offline   Reply With Quote
Old 02-03-2019, 11:58 AM   #7
wcronin4's Avatar
1978 31' Sovereign
Thanks for the blue print
Girtex
Thanks for sharing the dimensioned drawing. You and Ian are so far ahead of me with technology. I am assuming that the drawing of your 76 frame would be the same as Ian's 77 and my 78 31'.
Again thanks
Old 02-03-2019, 06:32 PM   #8
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
Is there an archive where the original frame drawings are kept for use such as restoration?
guskmg
Old 02-04-2019, 06:03 AM   #9
1977 31' Sovereign
Updated, now on grass!
There were actually several outriggers missing on the original post. Was using the model for tank placement as I try different size tanks. I've updated the frame and added some key elements.
I noticed on your drawing that the rear most crossmember is the same as all the others, yes? Where do your tank outlets come out?
Ian
Name:	Screenshot 2019-02-04 05.58.40.jpg
Old 02-04-2019, 06:05 AM   #10
1977 31' Sovereign
guskmg
I don't think so. I looked pretty hard for a frame schematic, finally just made my own.
Maybe we should start one?
Ian
Old 02-04-2019, 07:16 AM   #11
AirstreamCSH's Avatar
2016 25' Flying Cloud
Huntington , New York
Trying to learn how to do such a schematic and Visio isnt cutting it. If your willing to post the file, would love to test out sketch up with a useful working base. Looking to document a solar install and the full roof with the curves.
AirstreamCSH is offline   Reply With Quote
Old 02-04-2019, 08:40 AM   #12
1977 31' Sovereign
I'm happy to share the file, though the forum does not support it. I'm happy to email it.
Ian
Old 02-04-2019, 01:47 PM   #13
1976 31' Sovereign
Helotes , Texas
Ian,
I am guessing you have a rear bathroom. That's why you tank valves are in the back. I don't plan on putting a Black water tank in. I will use composting or incinerating toilet. I am still working out tank valve placement. My original had them behind street side wheel well.
I used 2x6 rectangular tubing for rails and cross members. I will post a photo of my progress so far.
I am trying to confirm accurate placement of outriggers that form wheel wells. I think my original had them to close together judging by the bend in the wheel well moulding.
Greg
Old 02-04-2019, 01:53 PM   #14
1976 31' Sovereign
Helotes , Texas
Originally Posted by wcronin4 View Post
Girtex
Again thanks
wcronin4,
I cannot say if the same frame can be used on '76 thru '78. Airstream says they do not archive frame dimensioned drawings. I think that is an evasion.
Just keep in mind bathroom placement with affect some of the cross member placement.
Greg
sovereign
can a frame be repaired without frame off restoration? RhinoWW Repairing/Replacing Floor &/or Frame 12 10-29-2014 11:46 PM
Frame Rot - New Frame jcawley1 Repairing/Replacing Floor &/or Frame 3 09-01-2014 09:30 AM
Advice on gaucho/jacknife frame frame & wall remodel chiefbrody General Interior Topics 0 01-30-2013 05:38 AM
Beatrice era frame experts if you please. Odd frame issue Kevin245 Repairing/Replacing Floor &/or Frame 5 08-25-2012 10:55 AM
Frame Repair or New Frame muddy_hollow Brakes & Brake Controllers 14 09-26-2006 06:55 PM
