Old 02-18-2019, 06:30 AM   #29
1977 31' Sovereign
Sunset Valley , Texas
Here is my proposed frame layout with new tank placement thoughts next to the original frame. Additions in blue.
The tanks are modeled on VTS 21 gallon tanks. I need to figure out if the toilet can live with the hot water heater as that isn't moving.
Name:	Screenshot 2019-02-18 07.24.26.jpg
ID:	333858   Click image for larger version
Name:	Screenshot 2019-02-18 07.22.24.jpg
Iansk is offline   Reply With Quote
Old 02-18-2019, 07:00 AM   #30
dwhitake's Avatar
1972 23' Safari
1978 31' Sovereign
Akron , Indiana
Ian,
As requested, my proposed layout for my 31' Sovereign.
dwhitake is offline   Reply With Quote
Old 02-18-2019, 07:08 PM   #31
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Very, very nice indeed. David
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
Old 03-19-2019, 04:10 PM   #32
wcronin4's Avatar
1978 31' Sovereign
New Smyrna Beach , Florida
Toilet and tanks
Ian
I've been looking over your latest layout of tanks and I have some questions:
You have filled two 24" wide bays (side to side) with gray tanks. Are you showing two VTS 747 tanks in parallel, or just one big tank?
Also in the picture you posted, the toilet is not sitting on top of the black tank in the rendering, but is offset. Is this a function of the CAD program, or are you going to pipe over from the toilet to the tank?
Slowly but surely I'm sneaking up on a tank design.
Bill
wcronin4 is offline   Reply With Quote
Old 03-20-2019, 06:21 AM   #33
1977 31' Sovereign
Hey Bill,
The showing tanks contains 3 of the VTS 21 gal tanks for exploration purposes only and is not my final design. The thought is there is 2 x 21 gal tanks for grey water (color coded grey) that would be hanged together to make a 42 gal system and another 21 gal tank to see if I could use that as a black tank solution (color coded black). As you pointed out, the toilet does not drain directly into the tank as placed and unless I can reorient the toilet over the tank without moving the HWH I’ll have to use a different tank for black. I will only dump straight down into the black tank as any deviation may be pretty poopy in the long run.
Hope this makes sense...
Ian
sovereign
can a frame be repaired without frame off restoration? RhinoWW Repairing/Replacing Floor &/or Frame 12 10-29-2014 10:46 PM
Frame Rot - New Frame jcawley1 Repairing/Replacing Floor &/or Frame 3 09-01-2014 08:30 AM
Advice on gaucho/jacknife frame frame & wall remodel chiefbrody General Interior Topics 0 01-30-2013 04:38 AM
Beatrice era frame experts if you please. Odd frame issue Kevin245 Repairing/Replacing Floor &/or Frame 5 08-25-2012 09:55 AM
Frame Repair or New Frame muddy_hollow Brakes & Brake Controllers 14 09-26-2006 05:55 PM
