Old 01-18-2019, 02:18 PM   #29
wcronin4's Avatar
1978 31' Sovereign
New Smyrna Beach , Florida
correction
I stand corrected, David made the suggestion of standing on the bumper to test for frame separation. Sorry David.
Regardless, the frame members seem like they are in horrible condition. But again, I won't know until I can see underneath better.
bill
wcronin4 is online now   Reply With Quote
Old 01-18-2019, 06:58 PM   #30
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Our 70s (body started in 69) Airstreams are infamous for a poor rear body rain water seal. The rear of the frame is usually the worse. I think the most important aspect of a Airstream rebuild project is the body, The body, (shell), is difficult and expensive to repair. The frame is easier and cheaper. Don't worry, it can be fixed and you can do it.
Here is a rusty mess I found under my Overlander. Misery loves company. I spent about $900 on frame repairs, both materials and the mobile welder cost. My frame is good now.
Those rocker switches have molded retainer "levers" behind them that expand when you push the rocker into the aluminum. Take a thin, narrow putty knife and get behind the switch and push gently while lifting and see if you can get the switch to lift away from the wall. These switches (two position) are available if one breaks. The three position switches are not as easy to find, but I don't remember one in the 70s trailers.
David
Name:	1710 Frame Rust Rear Cross Member 4 (Small).JPG
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
Old 01-19-2019, 03:00 AM   #31
1977 31' Sovereign
Sunset Valley , Texas
The disappointments are when the thread just stops. When the OP is trucking along, doing a great job then all of a sudden... nothing. No more posts. For one reason or another folks either abandon the project or just stop posting.
Though there are the success stories too...
The thread by Minno should be required reading. There are many other great threads as well, but that one in particular stands out to me. As did SneakingUp’s.
Ian
Iansk is offline   Reply With Quote
Old 01-19-2019, 07:00 AM   #32
wcronin4's Avatar
1978 31' Sovereign
Cleco Fasteners
Ian
In my other life, I write novels. My concern will be that I post too much.
To others following the thread:
Today I'm working on removing everything that will interfere with removing the inner skins. Since most of the time I am working alone, I have been looking at these long panels and trying to figure a way that I can remove them without damage or creasing. I had thought about building a stand to hold the panels as they were being removed, and then I ran across something from another thread called a Cleco temporary fastener. I haven't learned yet how to post a link, but I googled Cleco and found them easily. Apparently, as you remove the rivets from the panel, you can use these temporary fasteners as strategic points to hold the panel in place until your ready to pull the panel loose. I also understand that they can be very useful when trying to reinstall the skins.
It sounds good. But are they practical?
Old 01-19-2019, 07:48 AM   #33
1977 31' Sovereign
Clecos are a must. Super handy, you’ll never have enough.
VTS has a good starter kit:
https://www.vintagetrailersupply.com...-p/vts-821.htm
You’ll need 1/8” for the majority of what you’re doing but 5/16” and 3/8” will come in to play as well. You’ll need the pliers as well.
To post a link just copy/paste.
No one will accuse you of posting too much.
Tell me more about your books? I’m an avid reader...
Ian
Old 01-19-2019, 04:04 PM   #34
wcronin4's Avatar
1978 31' Sovereign
Still working interior
January 18, 2018
This is the second day of interior preparations for interior skin removal. Worked about 6 hours removing outlets (DC and AC) wheel well outer covers, wing window trim, and a lot of miscellaneous things attached to the wall, like window shade hardware, lights that light up the compartments. Also, removed the remaining water pipes, AC fuse panel and entrance 30 Amp cable. There was more stuff attached to that wall that had to be removed than I anticipated.
Everywhere where cabinets were attached to the wall there were burrs or remnants of drilled out rivets protruding from the wall. Since I wanted to scrub all the interior skins before they were removed Ė most were covered in grease, mold and only God knows what else Ė these burrs had to be chiseled off with a sharp chisel to smooth out the wall and remove things that would snag a sponge. So everywhere something had been riveted to the wall, there was clean up to be done.
As with most other things in this trailer, the wheel well outer covers were brittle and cracking, and the wing window trim covers were also brittle and cracking. As I was taking off the wing window trim, I noticed that both wing windows have two vertical cracks in them. Ugh - $$$$$.
There was this thing that looked like a light on the back driver corner that I couldnít figure out what it was. When I was removing outlets I notice a junction box and inside was, what I suppose is, a light to indicate whether there is AC power. See pics below. A nice feature when youíre plugging in to shore power, a confirmation that the AC power is on.
In the bummer category, I went to disconnect the fresh water filler tube from the filler cap, and the plastic crumbled away. Same with the breather tube. Pics below. Anyone know whether you can replace this plastic piece? The exterior metal part is great, but the plastic behind it is toast.
So far the continued removal of the interior is progressing without major issues. Nothing that I have done so far in this project required anything more than basic skill. It is like a big puzzle that you have to take you time with and not get aggressive. I am taking plenty of pictures and taking plenty of notes. I have made my own diagram of where all the wires go and where they are used. And I have tried to preserve everything, not knowing whether I will use it, or whether it can be repaired. Iíll make those decisions later.
One of the things that I have found most helpful is making lists. There are so many things that have to be done it is easy to get distracted and waste time. So in the morning, I survey what needs to be done, make a list as I go, prioritize that list, then work the list in order. I donít think about the next task until the one in front of it is completed. These lists will be important, because they will provide general tasks to be done to reinstall everything. I got a spiral notebook, and keep all my notes, questions, and lists in one place. So far it seems to be making me more productive. The other thing it does is reduces the feeling of being overwhelmed. If I keep my eye on the list instead of all the things left to do, I donít let it overwhelm me.
Tomorrow, I give all the skins (they are disgusting) a thorough scrubbing, finish removing the charger/converter, and if time permits, try to number all the interior panels and try to figure out what order they will need to be removed. To be continued . . .
Pics
Wheel well cover in trailer and removed. Note splitting
The outlets used in this camper are a AMP product and are a quick connect variety. Never seen them before
Here is pic of how they are opened
With the outlet opened
Here is the light to indicate AC is on
Old 01-19-2019, 04:10 PM   #35
wcronin4's Avatar
1978 31' Sovereign
Novels
Ian - for you or anyone else who may be interested, you can find my books at Amazon.com. You can search for my name Bill Cronin, or my name with any of the titles below:
Jack McNamara Series (Family Mystery)
The Song of the Mockingbird
Ruby's Story
Letting Go
Joe and the Governor
The Jed McCain Series (Police Crime)
Night Fire
Playing with Fire
Stand Alone Novels
Dial Tone
The Tainted Lady
Old 01-19-2019, 06:53 PM   #36
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Gee, I've never met an author before. Congratulations and thanks for the list of your works. I'll have to try one of your novels.
Cracked wheel well "covers" are very common. This part doesn't have much to do except hold in the insulation over the real wheel "house". I just did a little adhesive repair on the cracks and added some fastener to hold them down and against the wall.
The "AC" light you mention I believe is the wrong polarity indicator. Airstream installed these for years and years as 3 prong plugs were not that prevalent back then. If the light is on, there is a polarity problem that needs addressed. I still remember an old wringer washer we had. We plugged it in and then were getting a little shock off the sheet metal around the tub. Since I am highly confident that my 30 amp power cord and new AC power connect to the trailer are wired correctly with the neutral wire and ground wire. You can buy a little "circuit tester" at the hardware store that plugs into any outlet and tells you if you have any "hot" voltage leaking to neutral or to ground. Don't need a polarity indicator any more.
Clecos are very handy "sheet clamps". You are wise to spend for some, especially when it comes time to reassemble the interior skins.
I use a sharpie and label the parts on their backside as they come off the trailer. It helps when it is time to reassemble them. I also sometimes indicate which way was up, or left and right as appropriate.
David
WBCCI #8607
VAC Region 11
Old 01-21-2019, 06:29 AM   #37
wcronin4's Avatar
1978 31' Sovereign
What to do with the bath?
Still cleaning the interior skins before removal, but looking ahead toward whether to reinstall the old bath or start from scratch. We are concerned about the durability of the old Fiberglas given that everything else has been so brittle from heat.
The thought is, if we paint and reinstall and the tub cracks, or epoxy paint doesnít adhere as it should after everything is redone, then you have a lot of tearing out to do.
Would love to hear feedback on this.
If we started from scratch the most challenging part is to make a shower pan. Iíve searched forums for a how-to but didnít find one. Anyone seen a post on this?
Old 01-21-2019, 07:05 AM   #38
Joyflea's Avatar
1967 26' Overlander
Alpine , Texas
Your doing a great job .
Iím in the progress of doing my bath and Iím kind of worried also but onward thru the fog . Iíve research it and will be soon in the next two weeks if the weather stays warm enough . You can keep up with this progress on my tread .
Good luck , Blue
Joyflea is offline   Reply With Quote
Old 01-21-2019, 03:04 PM   #39
wcronin4's Avatar
1978 31' Sovereign
Cleaning skins and Antenna Issue
Jan 21, 2018
Spent nearly the entire day cleaning interior skins. When completed I had the opportunity to tackle some other things that had to be removed to allow the skins to be removed.
The pic below shows the interior handle to lift and turn antenna. The handle inside was frozen, or so it seemed. But it certainly wasnít operating properly.
The next pic shows the antenna. You can tell by its design that it was something out of the black and white era. It looked normal enough until I started moving it around.
When I found a way to get it loose, it was just flopping around in its hole. When I pulled it out, it was apparent why the mechanism wasnít working, the center part of the plate was destroyed. There is no way this couldnít have been the source of an enormous leak.
Questions:
1. Can you get up on the roof? A permanent repair to the hole in the antenna plate will require me to be able to access it from the top. It seems where there is a support beam, it seems strong enough to support some weight. But 210 lbs? Yes or no????
2. Ian/David - Thinking ahead to lifting the body. There are three vents in the roof, not counting where the air conditioner sits. The two furthest vents sit very close to the end caps about 20-21 feet apart. When lifting through these vents with gantries, must there be one continuous beam that runs between these vents? Or can two shorter beams be used? Anyone have any idea what a 31 foot shell weighs? How much interior framing/support is needed? I think I saw a video of someone pulling a long AS off a frame without any.
3. Spinning rivets. It seems like half or more of the rivets I try to drill out spin on me. I tried to put tape over them as one video suggested but that didnít help. Is there a secret here short of chiseling them out?
The preparation to remove the inner skins, and then the end caps, has taken much longer than I thought. I believe I have about 70 hours or more invested so far to this point. Donít know whether thatís good or bad.
David and Ian Ė I notice that you both have ďrivetsĒ under your name that signifies something. What is it?
Old 01-21-2019, 07:59 PM   #40
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
My TV antennae doesn't know it yet, but it is coming down. I did take the one off my wife's 86 many years ago. Yes, you can get on a roof of an Airstream VERY CAREFULLY. And you must not put any weight on the "end caps" front or rear. So what I did was place a 4x4 behind the Zip-Dee awning roll. Then I place a sheet of 5/8" plywood on top of that and resting on top of the roof and extending beyond the "crown" of the roof, or centerline if you will. I screwed the plywood to the 4x4 so it wouldn't slip on me. The plywood was supported on either side by the body "formers", or the hoops that form the body shape. This is where the strength is. I also had a piece of old carpet under the plywood to reduce scuffing. I used this to remove and replace the air conditioner as well as the TV antennae. I did not dent the roof at all. I worked on all fours, I didn't stand up very much at all. The idea is to distribute our body weight over two or three of the "beams" or formers. You can not just step on an Airstream roof.
You can remove the antennae and cut a patch for the roof hole. Make it well sealed and well riveted in place of course.
There are several bracing considerations before lifting the body off the frame. I bet the body weighs over 1000 pounds considering the windows and doors installed. I suspect I would use one long beam inside so all the weight of the body is on the beam being lifted with two hoists. You have to brace the side walls so they don't collapse in when you lift. I just read kristof's thread where he lifted the body off the frame with jacks. You might like to review it.
Bathroom plastics: Very good question. In my 1966 Trade Wind project, I pitched the plastics and built a vanity and shower stall. Cabinet making ain't my specialty. In my 1975 Overlander project, I reused the plastics after I painted them. They were about 3/16" thick and not too cracked up, but some cracks around rivet holes and the like. The tub had been repaired once but it held water with no leaks. Attached are "done" photos of each. Minno in his thread built a whole new bath, but his hobby is cabinet making I think.
Hey, you might really complicate things by building a "mid bath" layout in your trailer since you are starting fresh. A rear bedroom makes more sense to me. I would much prefer this layout. My wife's Airstream is that way so I'm used to it. You can have a vanity and toilet on one side of the aisle, and a shower room on the other. Just a thought.
Spinning rivets are one of the many pleasures of the vintage Airstream hobby. Sometimes I can crack the heads off with a larger 5/32 drill, and then use my center punch to drive the rivet mandrel through the hole. Sometimes I just use my thin chisel and shear them under the head. Sometimes I just come back later in hopes the elves got it overnight.
David
Name:	1507 Bath Layout (Small).jpg
ID:	332130   Click image for larger version
Name:	1811 Bath Molding Done-800x600.JPG
WBCCI #8607
VAC Region 11
Old 01-21-2019, 08:43 PM   #41
Central , Mississippi
The old antenna worked great at pulling in digital TV signals. Plus, kids ask mom and dad "Wuz dat on their roof?"
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 01-22-2019, 04:08 AM   #42
1977 31' Sovereign
“David and Ian – I notice that you both have “rivets” under your name that signifies something. What is it”
The rivets under my name relates to how many posts I’ve made (how active I am on the forum), or it means I am posting on the forum instead of actually working on my trailer. A procrastinator indicator if you will...
I think at 500 posts you become a Rivet “Master” as it were.
As for real world rivets spinning away, I be done everything from channeling my chi to channeling my rage. I’ve found that a narrow flexible tape/putty knife can be used to either get under the edge of the rivet and hold it static as I drill or just shear it off with it or a chisel via a couple taps of a small hammer. I keep a small (8 ounce I think) Eastwing hammer handy as it keeps me from doing too much damage. Drill bit sharpness and pressure can also be a factor.
Ian
shell off, sovereign
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
wcronin4
Frame Rust 1978 Sovereign 31" TGRIMM Repairing/Replacing Floor &/or Frame 4 12-04-2018 07:17 PM
Frame off vrs. Frame on RedRdgRnr Repairing/Replacing Floor &/or Frame 19 05-15-2018 07:31 PM
1978 31' 1978 Airstream Sovereign Land Yacht - South Florida JoshuaSteven Airstream Classifieds 0 08-12-2015 07:58 PM
can a frame be repaired without frame off restoration? RhinoWW Repairing/Replacing Floor &/or Frame 12 10-29-2014 10:46 PM
Frame off or not off... till Repairing/Replacing Floor &/or Frame 16 11-19-2003 05:20 AM
